ASOG Podcast Ep 15 - Finally Finding & Fixing Your Problem - Part 2 - w/ Jim Cokonis, Sr Curriculum Developer at Carquest Technical Institute
In our previous episode, David & Lucas were joined by Jim Cokonis, a Senior Curriculum Developer at Carquest Technical Institute.
We discussed the principles behind six sigma and the Toyota way and we found the conversation to be one of the most important we’ve ever had on the podcast.
Typically the second portion of the conversation is reserved for All-Access Patrons, but some of the things Jim had to say were too important to keep from everyone.
If you haven’t listened to episode 14, stop and listen to that first, then come back to this episode for the second half.
Support the show (https://www.patreon.com/AutoShopOwnersGroup)
      Episode 208 - Training Hurdles & Reputation Challenges in Auto Repair With Tim Iezzi & Ira Waldman
      Episode 207 - Kathleen Callahan Discusses Right To Repair and Industry Advocacy
      Episode 206 - Stellantis's Circular Economy Innovations To Reduce Waste With Alison Jones
