I recently bought an A/C recovery machine. I've heard plenty of horror stories of these machines being destroyed with stop leak.  I spent the money on a "stop leak" detection kit. Just had a car come in my shop that is full of stop leak.  Didn't even move the ball in the test kit.  Asked customer about it and they have been putting in cans of freon from every source around for months.  I'm sure some with stop leak.  Obviously it's not working as the system is still leaking. My question is how do other shops handle customers that have tried this cheap do it yourself fix, failed... and then put my investment in equipment at risk?  Replace everything in the A/C system?  Is there some kind of flush that will remove that cr**p?  Call the customer and tell them it's now a winter vehicle only?  Not sure where to go in this situation and can't really seem to find an answer on the almighty google thing.
I can't speak with great authority, maybe I can point you in a general direction.   I purposely selected my RRR machine (CPS FX134a) because it uses ball valves instead of solenoid valves and is much less prone to sealant damage.  Downside is there are way more techs that can repair Robinair machines than CPS.    AirSept makes a filter, called RecycleGuard, that filters out sealants.  One of these filters can be seen here:  https://airsept.com/Products/Details/12
With sealants, there is a seal swelling kind and a hardening kind.  I think, but don't know, that most sealants sold today are the swelling version.   The test kits should be able to test for the type of sealant.   If the sealants are the reason for the failure, then replace everything (lines and all) is the solution.  Otherwise it repeats the cycle after repair.   It seems that only the hardening sealers are the machine killers.
I've been looking for clear answers on the risks of proceeding with seal swellers, but there's no consensus.   In other technical HVAC forums, I've seen the debate rage from change it all to flush the heck out of it and use the RecycleGuard to protect your machine.
If you proceed, at least document the risks that the Stop Leak may cause a future unwarrantied outage.   For sure, I wouldn't do this without changing compressor, condenser and expansion valve.  Then flush the evaporator and lines thoroughly.  Hope this helps a little.
Thanks for the information. I've ordered one of the Recycle Guards.  Can't be to safe with my investment in equipment.
Well... I thought I had ordered one.  Just got notice that they don't have them in stock and have no idea if or when they will be able to get them. Will try to contact the company directly in the morning. Robinair shows a similar product, but it lists as discontinued everywhere I can find.
We always ask if they have added any refrigerant themselves, if so we ask to see the can to check for sealer. If it does have sealer we do no service them due to the possible damage that can occur to our a/c machine.
I use this kit on every system.  The one I had that proved to have sealant I asked the customer about it and he was sure he had never put stop leak in the system. They had added canned refrigerant themselves several times, but the leak had gotten bad enough it only lasted a day or two.  He wasn't aware that about half those walmart cans have stop leak in them.  I don't trust the customer with my equipment investment, and even if they meant no harm, there is no way to know if my customers kid or husband or even another shop had ever added the stuff.  I highly recommend this kit.  https://rotunda.service-solutions.com/en-US/Pages/ItemDetail.aspx?itemID=122683#:~:text=Neutronics QuickDetect™ A%2FC,before attempting recovery or repair.&text=Sealants can void warranty.
I use a Yellow Jacket "trap" (38080) on every car I recover. I'm running a Robinair 34788 NI-H and have not had any trouble in 5 years.
I recover from low side ONLY (less oil come out) and the trap has not missed a drop. The machine never recovers oil.
I intentionally recover my own cars without the trap to test the machine once a year. Oil recovery works fine then. The machine needs a tiny amount of oil to keep the solenoid seals lubricated.
I believe 90% of the vehicles I service have sealant in them. The little test kits are not worth the trouble IMO. I do not use them. They are not accurate enough for me and take too long to test.
It is difficult to find straight refrigerant in the DIY auto stores. Almost everything has oil and sealant...
I have NEVER seen the sealant fix a leak but I have seen the sealant take systems out. The usual culprit is a membrane that the American manufactures like to use as a debris screen.
The tiny holes in the membrane get clogged with the sealant and you find ALL of the oil in the system on the feed side of this membrane. GM SUVs with rear AC are the worst culprits.
The tiny screen is inside the liquid line at the bulkhead fitting in the rear. Most techs don't know it's there as it is not a normally changed part (and it should be). A Murray part # for the little screen is 39335.
It looks like a 1/4 scale orifice tube screen. The liquid line front to back has enough volume for the entire oil charge. If you have a plugged one and you don't change it you will have a comeback within a year. Rear AC will be wimpy as well.
GM condensers with a replaceable dryer cartridge (Cadillac SRX) also have a super tiny membrane inside the dryer that will clog. Symptoms are low pressures on both sides, piss poor cooling, and a viciously hot discharge line. There is a TSB regarding this.
If you refuse to service your customers cars because they might have sealant you are destroying your relationship with those customers. We have to service the systems and educate the customer.
Occasionally I hit a system that has been massively over oiled. The sealant is everywhere. I will commonly replace compressor, condenser, orifice/TXV, dryer/accumulator, and discharge line. I will over flush remaining lines and evaporator and offer NO warranty.
I haven't had a comeback on ANY of those but I believe I have been lucky.
Customers will seldom pay to have the entire system replaced and see the shop as an "over charger". They will not come back to you for the other things they need.
My Robinair machine's manual states "any leak sealers found inside the machine voids all warranties"...
I run a shop in Texas that specializes in AC repairs.
@RickD Thanks for the very thorough information. I'm in Northern Minnesota. A/C repair isn't of quite as high demand here I'm sure.  Probably just as often as repairing A/C problems, we need to recover to perform other work on the vehicles easier.
I bet you have a bunch more heater repairs than I do...
One thing I left out.
My machine has a line flushing feature for use with hybrids. It burns 1.5 lbs of filter life (limited by Robinair to 150 lbs before filter change).
I do use this feature when I hit a bad one AFTER I'm done with the job.
I clear the lines immediately after I'm finished...
One thing that's cool is when I get a a massively over oiled one and the trap has 8 oz of oil in it the oil bubbles like a coke for 2-3 hours and the 8oz drops to 6oz
The oil has liquid refrigerant in it.
This phenomenon is useful when you have to open a system. It will "out gas" for a couple of hours AFTER recovery.
If you tightly plug the lines it will "pop" when you pull the plugs days later, sometimes it will blow the plugs off (bad). Often I will use a balloon on one side to allow for expansion.
If your system is outgassing when you plug it and the plugs stay in the dryer does not get poisoned with ambient humidity and I will commonly re-use the dryer.
If I can I leave the systems in vacuum overnight (machine hooked up but turned off) and re-pull in the AM. This vastly reduces the moisture in the system.
      What if your auto repair shop is losing money every single day — and you don’t even know it? In this episode, Hunt sits down with Alex Saladna, CEO of Wicked File, to talk about the hidden financial leaks happening in shops just like yours and how AI is helping owners plug those holes fast. From missed parts and uncredited returns to unauthorized purchases, we dive deep into how real shop owners are using Wicked File to save thousands of dollars and hundreds of hours every month.
      Whether you're a single-location shop or managing multiple rooftops, this episode shows you why "doing it manually" might be costing you way more than you think.
      Alex Saladna, WickedFile
      In this Episode, you'll learn:
      How Alex's family-owned shop lost $180,000 in just 6 months — and what sparked the creation of Wicked File The real financial leaks you're probably missing — and why statement reconciliation isn’t enough Why even large, well-staffed shops fall behind on parts reconciliation How AI-powered tools like Navigator help shop owners instantly spot problems and improve profitability What one multi-shop owner did to increase net profit by 15% in just one month
