I don't really know what heading to put this under, but I see this as a marketing advantage.  I am the first shop in my area to have a no-charge loaner car program, but now I am one of two.  So it's really a marketing advantage, so here I am, posting under Advertising and Promotions.
I am in the process of replacing my loaner car.  I would like real world advice from my fellow techs and shop owners.  We all have our preferences and we all see certain vehicles in our shops more than others.  Shop A might see very few imports while Shop B might see a mix.  So Shop B could have more insight into what imports have problems and what those problems might be than Shop A.
Okay, now the conditions I have for my loaner, I have wanted a minivan since I put my first loaner into service.  I have had a very few customers decline the use of the loaner because they needed more than 5 passenger seating.  I have had customers decline the loaner car because their driveway was uphill and we are in Northern Lower Michigan where snow is a consideration, so I have wanted AWD too.  My first loaner was a Mercury Sable, replaced by an immaculately maintained Honda CRV so I at least got the AWD I wanted, even though it was not a important while I have had it as it was when I had the Sable.
I know that anything I have will be a compromise for my customers at times.  Even if I had a car, a truck, a minivan and a full-sized van, all with AWD, chances are the specific one the customer would want would be out, so compromise it will be.  That and I am too small to float the expense of too many loaner cars.  So what I am asking is, within the following parameters, what would each of you recommend for a reliable, low cost of ownership vehicle?  What would you put into your fleet if you were working within my parameters?
  • I want to spend about $10,000
  • No new vehicle leases
  • NO, and I mean NO European brand/influenced models
  • AWD would be preferable but not required
  • Easy to understand operation of such things as lights, windows, ignition, etc.  My current CR-V has window switches on the dashboard instead of the door, the ignition has that funny turn-off, stop, push in and turn to lock and the rear hatch has to have the glass released then the door opens like a door.  All of this confuses some customers.
My average loaner car usage is between 6,000-8500 miles a year so a higher mileage specimen would not be out of the question.  Thank you for all for your time and suggestions.
