What are you guys using as lubrication between the abutment shims and the caliper bracket.  I live in the rust belt and the main cause of premature brake pad wear here is frozen pads.  I was using a cold galvanize corrosion inhibitor spray but it didn't work well at all(maybe a year).  Now I'm using green grease, and it has been working better but I'm starting to see cars coming back with sticking pads after like 2 years.  MOPAR 04796269 works really well but it costs more then caviar.  Just curious if there is something affordable out there that won't have me reaching for the file every brake job.
I do use sil-glyde on all the rubber parts but wanted something a little more robust for the metal parts that trap salt water and corrode.  I'm looking at Jet-Lube Marine Moly 65005 or MolyKote 3400A.
Thanks for the replies.  I just ordered some Pastelube 2400 from gwrauto.com  and he's throwing in some Ceramlube 2800, which the Permatex stuff is based on.
      When it comes to keeping your customers loyal and engaged, technology might be the missing piece in your shop’s success. In this episode, we’re joined by Jeremy Glassco, founder of AppFueled, an innovative tool designed to disrupt customer behavior and redefine loyalty in auto repair.
      You might think AppFueled is just another CRM, but it’s actually so much more. Today, we’ll explore how its features—from branded call centers to custom loyalty programs—are setting new standards for customer experience. We’ll also dig into what it means to “disrupt” customer behavior in a way that keeps your clients coming back to your shop instead of drifting to the competition.
      Whether you're new to customer relationship tools or already running a CRM, we think you’ll find something valuable in today’s episode. Let’s dive in!
      Appfueled.com - Appfueled
      https://shopmarketingpros.com/ep-106-part-2-customer-retention-series-service-advisor-role/ - Customer Retention Series – Service Advisor Role
      How To Get In Touch with the Guest
      https://appfueled.com/jeremy - Jeremy Glassco
      AI Voice Scams Using A CEO's Voice #podcast #autorepairbusiness #automotivebusiness
      Are Employees The Main Source of Stress For A Business Owner?
