Geek With Attitude
tp.gifNow I realize I'm only a mechanic, and not an
Ivy League scholar, and I may not qualify as the
next inductee into MENSA, but I’m still a pretty
smart guy.  Oh, I may not know all there is to know
about every single make and model out there, but
I have enough background and technical ability to
solve just about anything that goes wrong with the
modern car.  But, for some people the mere
thought that a mechanic might actually have a
few brain cells just baffles them to no end.
tp.gifA few weeks ago I got a call from a guy, who
(to the best of my dim witted abilities could tell),
was having a problem with his truck.  He told me
that he pulled all the fuses, and was still having a
battery drain issue he couldn't find.  He even took
it to another shop and wasn't happy with their
results, so he was going to give me a chance at it based on a friend’s recommendation.
tp.gif“Bring it in tomorrow, and I'll get it checked out for you,” I told him.
tp.gifThe next day a 98 Nissan pickup with 150,000 miles on the odometer was waiting for me.  After getting the owner’s information, I went over what he wanted me to do.  Little did I know this guy had all the answers already.  Not only the answers, but several ideas as to what was causing his problem.  This particular guy was a full-fledged computer geek with more than a little attitude to go along with it. Not only did he think he was dead right about everything, but that every mechanic out there was nothing more than a knuckle dragging grease monkey with the IQ of a walnut.  The more he told me about the problem the more I knew I was in for a long afternoon.  Seems everything that was ever wrong with the car from the day he bought it was leading up to the moment the battery went dead.  But, of course, it's not dead now... that takes a month before it would happen.
tp.gif“A month?” I asked.
tp.gifOh, he had an answer for that too.  It all started with the front crankshaft seal. The seal was leaking, and it leaked all over the alternator, so he had the seal changed along with a new alternator and battery.  (Both the alternator and the battery came from one of those cheapo depot places; imagine where the seal came from.)  A month went by before the car wouldn't start again.  The seal was leaking too, but not nearly as bad.
tp.gif“Hmm,” I said, sitting at the service counter thinking this whole thing through, “You say it takes a month before it won't start?  Are you driving it much?”
tp.gif“Yes,” he said, “Every day.”
tp.gifThis didn't add up, something else is wrong with the car.  As I tried to explain to him that if a car is driven every day, and starts perfectly fine, but then all of a sudden it goes “click-click” it tells me there is something else wrong, and it's probably not a battery drain issue.
tp.gif“Leave it with me, and I'll check it out,” I told him,
tp.gifApparently, Mr. Geekdumb doesn't have a clue how a car works, other than where to put the gas and which way the key turns.  Not that I’d hold that against him, a lot of people don't know a thing about their transportation.  It's just that most people don't try to sound like they do, especially while standing in front of somebody that just might.
tp.gif   Once I had the truck in the shop it turned out to be a classic problem; the battery bolts were tightened down as far as they could go, but I could easily pull the cables off the battery without any effort at all.  The charge output and parasitic draw tests showed no signs of any problems. As for the seal leak. Well, if you've been around cars with high miles and poor maintenance you've probably seen this before.  The PCV valve was clogged.  Without that, no ventilation for the lower end, and of course, a back pressure builds up and that pressure has to go somewhere... usually out a seal, and the front seal is one of the usual places for it to go.
tp.gifExplaining all this to the computer nerd turned out to be a whole lot tougher than I thought possible.  How one person can act and think that they are so smart, but can't see the logic behind the explanation is beyond me.   The more I tried to explain, the more this guy asked even more bizarre questions.
tp.gifI gave him the run down on the battery clamp issues, “Yes, a loose battery clamp can make the car not start.  Sometimes you'll get one quick turn of the starter then nothing, not even a dome light. Other times you'll get a “click” which is what your car sounds like.  This can also stop or restrict the alternator charge output from entering the battery.”
tp.gif“So, that’s why my dash lights don’t work?” he asked.
tp.gif“There's no relationship between the charge output and the dash lights.  That's a separate problem. Most likely the rheostat,” I said.
tp.gif“Well, what about the switch on my dome light, it doesn't work. I’m positive that is due to the front seal and the PVC you mentioned.”
tp.gif“Sir, it's a PCV not PVC, “Positive Crankcase Ventilation” is what it stands for, and no, it has nothing to do with your dome light.”
tp.gif“So I have two PCV’s in the car?”
tp.gif“No, just one.”
tp.gif“So where's the PVC?”
tp.gif“That would be in your house most likely. Most homes have PVC plastic piping.”
tp.gif“So, now you're telling me I don't have two PCV’s?”
tp.gif“I never said you had two.”
tp.gifThis went on, and on.  My frustration level was getting to my MAX level, and I'm about to tell this guy just where he can put his PCV and his PVC.  But, after lengthy deliberations he eventually decided to have me at least fix something...one thing…change the battery clamps.  He had the solution for the dash lights, dome light, PCV, and the front seal. I apparently don't understand, or fail to comprehend how all his other problems are related to the dead battery.
tp.gifHe showed up later that day to pay for the clamp replacement, and it wasn't hard to tell this guy had an ego driven “micro” chip on his shoulder. He wasn't about to have some lowlife mechanic explain the physics of the internal combustion engine to such an astute individual as himself.
       His parting comments as he walked out the door said it all.
tp.gif“I work on highly technical and advanced systems on home and business computers that are far above the complexities of anything you’ll ever see.  I'm better off fixing my own car, because I have a degree, and my intelligence level is far superior than any mechanic.”
tp.gifReally? That's the best you got?
Better luck insulting me next time, fella…leaving is probably the smartest thing you’ve done so far… don’t let the door hit ya on the way out.
Now a days with YouTube, google and the parts houses it’s not just the geeks it’s just about everyone 🤪
  • Haha 1
I find the real harm is in customer/repair shop relationships.   If you start your relationship at the repair shop with, "I already know what's wrong, and I know how to fix it... you just do what I tell you to." Is not a good way to begin.  This guy, well, he was probably the worst I had to deal with over the years.... because... he made it a point to tell me... straight to my face.... that I was subordinate to his refined education level.  If I was any less of a gentleman, and not an upstanding business owner... I would have reached across the counter and showed this guy the alternative uses for my extra large box end wrench.
  • Haha 1
very true,  but now you see even more of the ones you would not expect like the older women with a emissions fail in hand with the code on it or the parts store print out , saying they know what is wrong and hand you the paper and ask how much to fix it, when I tell them there will be a diagnostic charge, then I can tell them how much, they get angry and start saying things like " fine you don't want my business I will go somewhere else " or " your trying to rip me off I already know the problem it is here on the print out " I can go on and on but I won't LOL..  I am getting to the point where I tell them what the diagnostic will be and if they want me to look at it drop it off and at that point I have said my peace and go back to work..  Of course you always get the ones that " I have a tiny problem " and " let me show you something " ... I always tell them I have done this a long time and you aren't going to show me something I haven't seen before. So .......... " if you want me to look at it drop it off "
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
      Want to make your shop’s marketing stand out this May? Join Brian Walker and Caroline LeGrand as they break down creative ways to engage your audience, plan your content, and connect with your community.
      In this episode, they’ll share creative campaign ideas, fun social media prompts, and practical ways to highlight your team, engage customers, and boost brand awareness. Plus, get inspiration for using national holidays like National Skilled Trades Day, Road Trip Day, and even Pizza Party Day to keep your content fresh and relevant.
      Don’t miss this opportunity to simplify your marketing and make a real impact. Tune in now and start planning content that connects!
      Days of the Year
      National Calendar
      Introduction to the Episode (00:00:01)  Brian and Caroline introduce the podcast and thank RepairPal for their support. Preparing for May Marketing (00:01:16)  Discussion on planning marketing strategies for May, emphasizing the importance of advance preparation. General Marketing Themes (00:02:00)  Overview of summer-related topics, tax return spending, and pre-trip inspections for vehicles. Motorcycle Safety Awareness Month (00:03:17)  Highlighting the importance of motorcycle safety and tips for drivers and riders. Military Appreciation Month (00:03:39)  Encouraging auto repair shops to give back to military personnel throughout May. Teacher Appreciation Week (00:04:34)  Ideas for showing gratitude to teachers, including small gestures and discounts. National Pet Week (00:05:50)  Encouragement to engage customers by sharing pet photos on social media. Celebrating Various Appreciation Weeks (00:07:05)  Discussion on multiple appreciation weeks in May and the importance of selecting key themes. Learn to Ride a Bike Day (00:08:04)  Suggestions for community engagement by helping kids learn to ride bikes. National Skilled Trades Day (00:09:00)  Promoting skilled trades and hosting events to educate youth about automotive careers. Star Wars Day (May the 4th) (00:10:26)  Fun marketing ideas related to Star Wars Day for engaging customers. National Odometer Day (May 12th) (00:11:42)  Ideas for a fun contest involving vehicle odometer readings to engage customers. RepairPal Certification (00:13:14)  Discussion on becoming RepairPal certified and the benefits for auto repair shops. App Fueled Introduction (00:14:18)  Overview of a customer loyalty app designed for auto service shops. National Lost Sock Memorial Day (00:14:54)  Encouragement for creative engagement ideas related to this fun holiday. Military Appreciation Month (00:15:06)  Suggestions for acknowledging military families and providing discounts. National Dance Like a Chicken Day (00:15:59)  Call to action for engaging with customers through fun activities. Check Your Wipers Day (00:16:27)  Importance of checking wipers before summer travel and educating clients. National Pizza Party Day (00:18:05)  Highlighting the fun of pizza party day and community engagement. Armed Forces Day (00:18:28)  Ideas for honoring military personnel and their contributions. Memorial Day Awareness (00:18:46)  Discussion on the solemn nature of Memorial Day and appropriate observances. National Road Trip Day (00:19:34)  Emphasis on preparing vehicles for summer road trips and inspections. National Rescue Dog Day (00:20:13)  Celebrating rescue pets and their connection to the auto repair community. World Marketing Day (00:20:48)  Encouragement to appreciate and promote effective marketing efforts. Paws and Pistons Campaign (00:22:41)  Combining pet care with auto services for community engagement. Prepping for Road Trip Day (00:24:51)  Continued focus on educating customers about road trip preparations. Engagement Ideas (00:25:34)  Encouragement to share personal stories and engage customers creatively.
      Auto Repair Marketing Mastermind (00:26:01)  Invitation to join the Facebook group for sharing marketing ideas and support.
      Matt Fanslow and Margaret Light, a Licensed Marriage and Family Therapist and Certified Sex Therapist in the state of Minnesota, discuss a recent murder-suicide within the automotive community. They discuss the alarming statistics surrounding such events, emphasizing the significant role of domestic violence as a predictor. The conversation explores risk factors, including untreated mental illness, access to firearms, and the dynamics of control within relationships. Finally, they offer practical advice and resources for identifying warning signs and seeking help for individuals at risk.
