Picture This ---- I learned a little something when I was teaching a little something
Picture This
(A lesson learned while teaching)
Years ago my younger brother came to work for me. He didn't know a thing about cars, but was willing to learn all he could. Teaching new techs is an art that most shop owners have to learn to do, but teaching your little brother can be a chore and can test your patience. I muddled thru it all and taught him what I could. I was sure at some point in time the two of us would butt heads like brothers will do, and he would take his new found skills and move up in the rank and files of the automotive technical world, but in the meantime it was his turn to learn from his older brother.
When he first started I would walk him thru each step of how to diagnose a certain system in a car. A lot of times he would have questions, and I'd do my best to answer them. He learned quickly and was really sharp at picking up some of those little details that are harder to teach, because you tend to forget to mention them while you're teaching. Mainly because you are trying to get to the solution as efficiently as possible, and you neglect to bring it up. Such as: "always test your test light connection before testing what you're testing, or don't forget to check for all your tools before you pull the car out of the shop…." Things like that.
One day we had a truck come in with dual fuel tanks on it. The gas gauge wasn't working and needed some attention. This was a perfect opportunity for Junior to learn a few of my short cuts on these old models. It was an older Ford, in which the tank gauge ran thru the tank switchover button. It was rather easy to pull it out of the dash and connect to the gauge from the back of the switch.
Luckily it was the typical problem I've seen a hundred times in the past. The switch connections would melt and the tank wouldn't switch from the front tank to the rear, and of course the gauge wouldn't move either.
After locating the correct leads to the gauge and to the tanks I decided to show him how the gauge worked. I hooked up the one of the tanks to the crossover lead that would supply the signal from the tank to the gauge.
"Ya see this, that's the lead to the fuel gauge in the dash, and this is one of the tank wires. I'll connect these together and we should get a reading on the dash," I told him.
He was watching intently, taking in all the wiring diagram information, the location of the wires, and how I was bypassing the switch. He was fascinated with the flow of the current and the way the gauge would respond. I even went as far as moving the gauge from full to empty by opening and closing it to a ground signal. While I had his attention I filled him in on the two types of gauges that were used back then (bimetallic and magnetic) and how low resistance on a bimetal type gauge would read near a full tank, while a magnetic gauge would read close to empty. Change the resistance and the gauge would/should read accordingly.
"So, if we put gas in the tank the gauge should move right? That way we could check the sending units in the tanks too," he asked me.
"Great idea, grab a gas can and let's add a few gallons," I said, excited that he was so interested in the project.
He grabbed a can of gas and poured a few gallons in the tank. I was watching the gas guage carefully, but there was no movement. I knew I was on the right wires, but nothing was happening. Now what? Are there more problems?
"Crawl under there, and check to be sure the wire color is correct," I yelled from the cab to him.
"Yep, it's the right wire on the tank."
"Well, we might have to pull the tank; it's not changing the gauge readings up here."
"Before we do that let's add some more gas, maybe we didn't add enough," Junior tells me.
I thought I better go back and help hold the funnel, while he poured the gas in the tank. Unknowing to me, all this time my wife (who was the office manager) was listening in on the whole thing. She likes to keep tabs on me, and make sure I'm not going into one of my usual rants or having a fit because I had to explain something over and over again to little brother. This time she was standing at the corner of the shop just behind the truck with a camera. "CLICK", I heard the camera shutter go off and she was back there laughing like there was no tomorrow.
"What's so funny?" I asked her.
"You two idiots have been putting gas in the wrong tank. You're on the front tank, and you're putting gas in the rear tank," my wife answers, laughing hysterically.
About then the camera "clicked" again… this time it was an action shot taken at precisely the exact moment when these two idiots had that dumb struck look on their faces and realized what they just did. The shot had both of us on our knees, one holding a funnel and the other with the half empty gas can, and both of us staring right into the camera lens. Couldn't have set it up any better if you tried. The picture clearly showed the side of the truck with both fuel tank doors visible and there was no doubt which tank we were putting in the extra gas. I guess it was one of those things I should have mentioned when we were checking the tank senders… make sure we are both on the same tank.
For years that picture hung over her desk, and anytime I thought I was so smart she would point at the photo. Usually with that typical smirk, usually shaking her finger at me and of course the laugh… she had to laugh, but it wasn't all that funny until she had me laughing about it too. Ok, Ok, I'm not perfect... and now my little brother knows it too. These days he's a top notch tech at a dealership, and I have to call him on occasions for some help on how to solve things once in a while. Oh the photo… uhmmm… what photo?? Somehow it's missing… haven't seen the darn thing in years. But I guess I really don't need to see the photo … the wife has a pretty good memory... she reminds me just how smart I think I am every chance she gets.
sometimes you so caught up in teaching you forget to make sure your doing everything  right! Probably one of those instances!
  • Haha 1
      Getting involved in your community is powerful, but how do you share your efforts without sounding boastful? There’s a fine line between successful and selfish self-promotion, and in this episode, Brian and Kim Walker discuss how to highlight your work with authenticity and gratitude—not ego.
      We’ll discuss framing your message to focus on the cause, aligning community service with your company culture and purpose, and sharing stories that connect and inspire rather than just promote. Plus, we’ll share real-life examples—like our team’s work with Our Daily Bread Food Bank—and how to encourage others to get involved.
      Tune in now to learn how to support your community while staying humble and making a real impact!
      Start with Why - By Simon Sinek
      Commission Mankind
      Introduction to the Episode (00:00:10) Brian introduces the podcast and the topic of community involvement. Topic Suggestion Acknowledgment (00:00:34) Brian mentions Doug DeLuca's suggestion for the episode topic. Sponsor Acknowledgment (00:01:00) Brian thanks RepairPal for sponsoring the episode. Technical Issues Discussion (00:01:30) Brian and Kim discuss technical issues and Brian's experience with braces. Community Involvement Concerns (00:03:44) Kim shares a friend's hesitation about promoting community involvement due to fear of appearing boastful. Successful vs. Selfish Promotion (00:05:44) Discussion about the fine line between effective promotion and self-promotion. Promoting Community Engagement (00:07:24) Kim emphasizes the importance of spacing out promotional posts about community involvement. Starting with Gratitude (00:07:46) Kim suggests starting messages about community involvement with expressions of gratitude. Importance of "Why" (00:09:09) Discussion on the significance of explaining the reasons behind community involvement. Examples of Community Involvement (00:09:15) Brian and Kim share experiences of their community service activities. Promoting Community Work (00:11:25) Brian discusses the importance of promoting community service to demonstrate business values. Messaging about Community Involvement (00:12:21) Kim provides examples of how they communicate their community involvement on social media. Team Engagement in Community Work (00:14:20) Brian reflects on the team's connection with community members during service activities.  Closing Sponsor Acknowledgment (00:15:14) Brian thanks RepairPal again for supporting the episode. Community Engagement Strategies (00:15:26)   Discussion on how RepairPal helps auto shops gain customers through certification and fair pricing. Customer Loyalty Apps (00:16:25)  Introduction of App Fueled, a customer loyalty app designed for auto service shops. Highlighting Community Work (00:17:11)  Tips on emphasizing organizational missions instead of personal achievements in community involvement. Authentic Community Involvement (00:17:54)   The importance of sharing community efforts without seeking personal recognition or return. Sharing GoFundMe Campaigns (00:18:51)  Encouragement to promote charitable causes without boasting about personal donations. Industry-Specific Support (00:19:16)  Discussion on giving back to the auto repair industry and local communities. Respecting Privacy in Sharing (00:19:39)  The balance between sharing community involvement and respecting the privacy of those served. Educating Marketing Teams (00:22:43)  The need to guide marketing teams on how to portray community involvement authentically. Collaborating with Other Organizations (00:24:17)  Benefits of partnering with local businesses for community service efforts. Celebrating Local Teams (00:25:38)  Highlighting local sports teams and community events to promote goodwill. Telling the Story of Donations (00:27:40)  Importance of sharing the personal connection behind charitable contributions. Personal Anecdotes from Mission Trips (00:28:28)  Sharing impactful stories from mission trips to illustrate the importance of community support. Personal Anecdote on Community Support (00:29:29)  Kim shares a personal story about supporting organizations that assist her brother with disabilities. Encouragement to Join Facebook Group (00:30:44)  Kim invites listeners to join their Facebook group for further engagement and community building. Request for Podcast Reviews (00:31:03)  Brian asks listeners to leave reviews for the podcast, emphasizing the importance of feedback. Closing Remarks and Sponsorship Acknowledgment (00:31:36)  Brian concludes the episode, thanking sponsors and encouraging listeners to tune in next week.
    • By Jay Huh
      Long story short, been in business about 2 years and started mobile. Current location for about a year, just opened up a second location about 3 weeks ago- HUGE step for me.
      In my area, auto shop locations are REALLY REALLY RARE. There'll be months before a single shop will pop up for lease.
      Well.. I was looking for auto equipment on craigslist and stumbled upon a listing of a shop moving and selling all his lifts. Found the location on loopnet- 5 bays, previous business extremely successful, great location, great price too....
      1st location hit record sales this past week, 2nd new location held its own (divided by week, came out on top after expenses). I got both stores running self sufficiently. I am pretty much maxed out and I hate taking out loans but I have a line of credit available.
      Am I crazy to want to do this?
      Lessons Learned from Opening a New Shop #podcast #autorepairbusiness #automotivebusiness
      Thanks to our Partners, AAPEX, NAPA TRACS, and Automotive Management Network Scott Brown shares his profound journey through significant health challenges, specifically his battle with bladder cancer. Scott reflects on the lessons learned from his experiences, emphasizing the importance of living in the moment and preparing for the future. He discusses the emotional impact on his family, the illusion of control, and the necessity of succession planning. Scott’s story is a powerful reminder of life's unpredictability and the need to cherish each day, encouraging listeners to take proactive steps in their personal and professional lives. Scott Brown, Cardinal Plaza Shell, Springfield, VA. Scott’s previous episodes HERE Show Notes Watch Full Video Episode The Illusion of Control (00:03:25) The Diagnosis Revelation (00:04:21) Assessing Succession Plans (00:06:52) Health Challenges and Recovery (00:07:41) Living One Day at a Time (00:08:25) The Impact on Loved Ones (00:10:56) Long-Term Family Planning (00:12:10) The Copper Beech Tree Metaphor (00:14:05) The Importance of Values and Legacy (00:16:07) Succession Planning in Business (00:20:36) Competitive Advantage Discussion (00:22:28) Emotional Impact of Health Challenges (00:26:24) Busyness as an Idol (00:28:39)
      Thanks to our Partners, AAPEX, NAPA TRACS, and Automotive Management Network Set your sights on Las Vegas in 2024. Mark your calendar now … November 5th-7th, 2024. AAPEX - Now more than ever. And don’t miss the next free AAPEX webinar. Register now at http://AAPEXSHOW.COM/WEBINAR NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on X: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections             Click to go to the Podcast on Remarkable Results Radio
      Thanks to our Partners, AAPEX, NAPA TRACS, and Automotive Management Network Recorded at the 2024 Automotive Aftermarket Retailers of Ontario (AARO) Business Management and Lindertech Training Tradeshow, discover how simply attending meetings can significantly improve net profit, the impact of cost management, and tips on leveraging technology for business efficiency. Murray Voth, RPM Training. Listen to Murray’s previous episodes HERE. [email protected] Show Notes Watch Full Video Episode Automotive Aftermarket Retailers of Ontario (AARO): https://www.aaro.ca/ Importance of Attendance (00:02:04) Discussion on how missing educational events can lead to lost opportunities and profits. Value of Showing Up (00:03:05) Murray emphasizes the connection between attendance and improved business performance. Networking and Community (00:04:39) The significance of in-person meetings for building relationships and sharing knowledge. Learning from Group Sessions (00:05:23) Murray shares insights on the benefits of participating in group coaching sessions. Addressing Intimidation in Coaching (00:07:50) Discussion on how some individuals feel intimidated and hesitant to participate in coaching. The Need for Continuous Learning (00:10:59) Carm stresses the importance of seeking expert guidance and accountability in business. Coaching Styles and Techniques (00:11:53) Murray contrasts different coaching approaches and their effectiveness in the industry. Utilizing Technology for Coaching (00:13:28) Murray discusses the transition to online coaching and the importance of Google Business Profile. Engagement in Virtual Meetings (00:14:17) The effectiveness of screen sharing and virtual meetings in enhancing learning experiences. Introduction to Collaboration Tools (00:15:54) Discussion on using screen sharing and collaboration tools for knowledge sharing among automotive shop owners. Resources for Business Improvement (00:18:58) Introduction to automotive management network resources such as SOPs and checklists for business advancement. Note-Taking and Organization (00:20:00) Personal experiences with note-taking and strategies for managing notes effectively in a business context. Using Google Docs for Accountability (00:23:22) How Google Docs can facilitate accountability by allowing team members to log and review action plans collaboratively. Networking and Community Support (00:27:02) Encouragement for members to utilize networking tools like Slack for better communication and support among peers. Understanding Employment Law (00:30:33) Insights into Canadian employment law regarding severance and the importance of having employment contracts to protect business owners. Understanding Severance Costs (00:32:12) Discussion on the financial impact of severance costs and the importance of understanding net income. Calculating Impact on Sales (00:33:13) Exploration of how to calculate necessary sales to cover losses in the automotive industry. Networking and Sharing Solutions (00:34:11) Importance of sharing experiences and solutions among peers in overcoming business challenges. Expense Management Insights (00:35:09) Discussion on the need for better focus on expense management in business operations. Insurance and Expense Comparisons (00:36:02) Sharing strategies for managing insurance and other recurring expenses effectively. Planning Expense Discussions (00:37:35) Proposal to plan discussions on key expenses in future meetings for better financial management. Setting Budgets and KPIs (00:38:27) Discussion on the importance of setting budgets and KPIs for various business expenses. Normalizing Income Statements (00:39:18) Explanation of how to clean up income statements for accurate financial analysis.
