Hello everyone
I am new to the service side of the retail auto industry having worked in sales for 5 years. I am now the mechanical department manager of a Carstar collision repair shop. In addition to the usual insurance work, I am starting to take on more customer pay repairs. An issue I keep running into is that because I am located in Canada (South Ontario not far from Detroit) many of the vehicles we work on are severely rusted underneath and many bolts have siezed in place. Many require torches, cutting, drilling, and other unusual disassembly of adjacent components to remove. For example right now I am having a starter replaced on a caravan, and the lower engine mount needs to be removed but is siezed. We needed to apply heat but because it is so close to the rad fan shroud, ended up having to remove the shroud and other items nearby just to attempt to heat and remove the bolt. This ultimately didn't work, and we are now cutting it and drilling it out. Often times using heat causes damage to components. We needed to use heat to cut into a suspension knuckle to remove it after it was damaged from a curb, and ended up destroying a wheel bearing. Abs sensors also commonly need to be snapped off and drilled out because they are just so fused in place. Obviously this gets expensive.
This happens all the time, and as a result the times I am using from shopkey pro and mitchell are not reflective of how long these jobs actually take. On one hand I don't feel it is fair to the customer to charge 2.6 hours for the starter replacement, and another 3 hours to attempting multiple ways to get a bolt out, heating, removing adjacent components, fan shroud R+I... turning a 2.6 hour job into 5.6 hours. On the other hand I understand that this is just the reality of working on vehicles older than a couple years in this part of the country and the customer should be paying for it.
What would you consider standard practice in this situation? I don't want to be eating all this extra time, but I also don't want to have to charge customer hours upon hours additionally because we have to figure out how to unsieze everything.
Edited by Savage
I'm in Prince Edward Island, so we have it even worse than you.  Not only do we have road salt in the winter months, we are surrounded by salt water!  We add time for these things regularly, depending on the car.  If it's especially rusty looking my techs will usually give the SA a heads up that there may be extra time involved, and this is relayed to the client.  They have gotten pretty good at spotting something and letting us know that it may cause some extra time the vehicle.  That said, the rust doesn't often slow my guys down much, aside from wheel alignments.  One trick we use for those tight spots such as your fan shroud.....keep a few various sizes of tin laying around the shop to use as a heat shield between the part you are heating and the part you do not want to burn/melt.  Works great.  Also, Wurth makes a spray gel designed to protect things from welding sparks, that can be sprayed on plastic or other pieces that helps them withstand heat better.  I can send you a picture of the product tomorrow from the shop if you like.
Jeff
If we identify the problem before the repairs we let the customer know there will be additional labor if we run into this issue, if we don't have any problems we don't bill for it. We also call and get additional labor time if it happens during the repair and additional time is needed. I would rather be over prepared than under bill.
A tool that works really great for seized bolts and nuts is an induction heater. They are faster and there’s no open flame. Of course they don’t fit every situation but they really work super. I use mine a lot. I believe mine is the “Bolt Buster “
Problems such a seized nuts/bolts/sensors can often be anticipated on a job based on past experience and then be explained to the customer up front. When it comes as a surprise I always call the customer and explain the situation that the anticipated labor charge will increase due to unforeseen complications. I find that keeping the customer in the loop and informed prevents trouble. I feel that if I fail to inform the customer then I don’t deserve compensation for the added labor but if I take the time to inform the customer and allow him or her to be part of the decision making process then there are no surprises, no hard feelings and the CUSTOMER pays for the additional labor repairing his or her vehicle. A seized, rusted or broken bolt is not my problem unless I allow it to be.
Our labor guide marks up the standard labor by 30%, so a starters that pays 1 hour becomes 1.3. Some jobs take longer some less but it all pretty much works out. Some jobs like a starter on a 5.3 trailblazer require bending the tranny lines out of the way. We quote new lines on a job like this because you just aren't bending them without a leak. Remember an estimate is just that, as soon as you realize your going to lose stop and call the customer. It's a balance between too many conversations and just getting the job done, so by starting out with a bit of a cushion your life gets easier.
      In this episode, we’re diving into the powerful concept of creating a shared vision and how a lack of clarity could be holding your shop back from real growth.
      I’ll walk you through what I learned in a deep dive after my own leadership team challenged me to cast a vision that reaches every level of our company. We’ll talk about how to get out of the “small thinking” trap, how to define your goals with laser precision, and why your employees need to see, feel, and believe in the same future you do.
      Plus, I’ll share real tools, like how to craft your vision statement, how to communicate it across your team, and how to create a business where everyone’s pulling in the same direction.
      If you want to stop playing small and start building something truly great, this episode is for you.
      Thank you to our friends at RepairPal for providing you this episode. RepairPal will help you grow your auto business and you can learn more at RepairPal.com/shops.
      Declined repairs don’t have to be lost revenue. AppFueled’s call center schedules follow-up calls and equips your team with everything they need to close the deal. Get started now at appfueled.com
      EOS One
      Vivid Vision: A Remarkable Tool For Aligning Your Business Around a Shared Vision of the Future - Cameron Herold
      The Vision Driven Leader - Michael Hyatt
      Stop Delaying Your Dreams: Time to Take Action
      Introduction and Sponsors (00:00:01) Overview of the podcast and thanks to sponsors RepairPal and App Fuel. Creating a Shared Vision (00:00:10) Brian discusses the importance of establishing a shared vision for the company. Leadership Team Meetings (00:01:13) Details about offsite leadership meetings and the exercise called "the one thing." Feedback and Growth (00:02:08) Brian reflects on receiving feedback from his leadership team and its impact on personal growth. Shifting Mindset on Growth (00:03:07) Brian shares his fears about growth and how he overcame them to embrace larger ambitions. Disney's Service Model (00:04:17) Comparison of Disney's customer service model to his company's approach to client service. Processes and Procedures (00:05:26) Discussion on the importance of processes in maintaining service quality while growing. Inbound Marketing Strategy (00:07:25) Brian explains the effectiveness of inbound marketing in attracting clients. Outbound Sales Shift (00:09:26) Introduction of outbound sales strategies and the team's initial reactions to the change. Creating a Shared Vision Deep Dive (00:10:34) Brian's focus on developing a shared vision after receiving feedback from his leadership team. Researching Shared Vision (00:11:42) Challenges in finding resources on creating a shared vision and discovering related literature. Book Recommendations (00:12:42) Brian reviews two books on vision creation and his thoughts on their content. Simplicity of Creating Vision (00:13:34) Brian concludes that creating a shared vision is simpler than expected, emphasizing clarity. Vision, Mission, and Values Explained (00:14:45) Brian differentiates between vision, mission, and values with a practical example. Big Dreams and Ambitions (00:15:45)  Brian discusses the importance of dreaming big and outlines a fictional company's ambitious goals. Vision, Mission, and Values (00:16:48)  He explains the significance of having a clear vision, mission, and values for a successful organization. Sponsor Message: RepairPal (00:17:48)  Introduction to RepairPal and its services that help auto repair shops attract tech-savvy customers. Sponsor Message: App Fuel (00:18:48)  Overview of App Fuel's customer loyalty app designed for auto service shops to enhance customer retention. Core Values and Their Importance (00:19:57)  Brian shares his realization of the value of core values in decision-making and company culture. Litmus Testing New Hires (00:20:59)  He describes how to evaluate potential hires against the company's vision, mission, and values. Understanding What You Want (00:21:55)  Brian emphasizes the importance of defining personal and business desires beyond just financial goals. Creating a Clear Vision (00:23:51)  Discussion on the necessity of a detailed, clear vision for a business to guide its direction. Proximity to Your Dreams (00:26:56)  Encouragement to immerse oneself in environments that inspire and reflect personal dreams and aspirations. Crafting Your Vision (00:28:50)  Brian advises on the process of creating a vision, emphasizing the need for time and space away from routine.  The Importance of a Clear Direction (00:29:46)  He compares running a business without a clear vision to aimlessly shooting an arrow, highlighting the risks involved. Creating a Target (00:30:41)  Discusses the importance of having a detailed vision as a target for business goals. Vision Details (00:31:37)  Explains the components of a business vision, including specifics about services and operational metrics. Dream Big (00:34:25)  Encourages thinking big without worrying about how to achieve those goals initially. Historical Example: JFK (00:35:32)  Uses JFK's moon landing vision as an example of effective goal-setting and inspiring leadership. Sharing the Vision (00:37:33)  Stresses the need to communicate the vision clearly to the entire team for buy-in. Selling Down the Ladder (00:38:27)  Describes the process of sharing the vision, starting with leadership and moving downwards. Feedback and Buy-In (00:39:19)  Highlights the importance of receiving feedback and fostering genuine buy-in from team members. Repetition of Vision (00:40:12)  Discusses the necessity of repeatedly communicating the vision to ensure team alignment. Crafting the Vision (00:42:20)  Brian reflects on his personal goal to create a detailed vision for his organization. Importance of Shared Vision (00:43:34)  Concludes with the significance of a shared vision for team alignment and achieving business goals.
      Revolutionize Your Shop
