Battin a Thousand - - Mechanics have to step up to bat and hit it out of the park every time
Battin' a Thousand
tp.gifThe batter steps up to the plate, takes a hand full of dirt
and rubs his hands and the bat.  He takes a few scrapes with
his feet from the batter’s box while digging in with his cleats.
He then gives the pitcher the evil eye and sets his bat ready
to take whatever the pitcher is going to throw at him. The
catcher gives the signs, the pitcher nods his head.  He takes
a quick look to first base makes his wind up and then lets the
ball fly to home plate.  The batter takes a swing... “Pop” the
ball is in the catcher’s glove.
tp.gif“Steee---rike!!!” yells the umpire.
tp.gifSomewhere there is an announcer telling the crowd the
count while a statistician is writing down the results of the
pitch, and calculating the batter's average. With baseball if
you can manage to get a hit 5 out of 10 times you’re up to bat…
you’re doing outstanding.  Achieving a perfect hitting record
on the other hand, may never happen in baseball, but in the
auto repair business (and most every other field of play)
batting a thousand is not a goal it's a requirement.
tp.gifEvery job that comes into the service bay is another attempt at keeping that perfect score.  Come-backs, bad diagnosis, faulty parts and the like are not what any service person wants to deal with.  To keep that perfect score going you have to overcome those obstacles and get the job done right before sending the customer’s car around the bases.  Unlike the highly paid professional ball player who is never going to achieve that perfect score the highly trained mechanic has to knock it out of the park each and every time.
tp.gifThere's a lot of talk in the industry about how some service advisers/writers and shop owners want a quick “off the cuff” diagnosis and repair rather than waiting for the results of a lengthy-time consuming diagnostic procedure.  A mechanic may have a general idea of what is wrong but it still takes proper testing to determine the correct course of action to make the repair.  I don't know where this idea came from that every mechanic has the correct answer to ever problem simply by listening to the description given to them by the customer or service writer.  It's not like we (mechanics) know what kind of pitch is being hurled at us each and every time.
tp.gifI'm sure the pro ball player could “up” his stats if he knew exactly what kind of pitch was coming across the plate.  As it is, he has to make a quick decision, make the right swing, and make contact.  In the repair world, analyzing the pitch is the key to a successful outcome.  Diagnostics is what makes the difference.  Especially on today's vehicles with their interconnected systems, multi-layered computer controls, and the occasional “oops” from a previous botched repair, these all have to be sorted out before the repair is made.  This takes time, diagnostics takes time, and time is money.
tp.gif When I hear that a shop isn't charging for diagnostic time it tells me they are either under estimating the value of proper diagnostics or believe they are good enough to read the catcher’s signals and in some way already know what pitch is being thrown.  Taking a couple of swings at a repair and not diagnosing anything is like standing in the batter’s box blindfolded.  I'd call that a foul ball waiting to happen for sure.
tp.gifIt’s important to examine a problem, diagnose as needed and not swing at every pitch that you’re given. In the long run, from the consumers standpoint, a shop that takes the time to diagnose a vehicle correctly may sound more expensive at first when you walk up to the service counter, but chances are you won’t be picked off at 2nd base because you have to spend more cash, buy even more parts that you probably didn’t need, while trying to solve the problem at those shops that don’t see a need in proper diagnostic time.
tp.gifA new player entered the field; it was a job from one of the body shops I do business with. This 2013 Ford Escape was almost ready to go home, however the air bag light wouldn't go off.  That's when I was called to plate.
tp.gif“We can sell this job today if you can get this taken care of.  We’ve struck out so far,” the owner of the body shop told me.
tp.gif“I’ll see what I can do,” I told him.
tp.gifThe first thing I did was check out what codes were in the system.  There was only one code.  B0095-11 (Right front impact sensor fault – sub code “shorted to ground”).  Since it was in a front collision I took my first swing up to bat by checking to see if the wires were smashed or cut.  Strike one... the wires are fine, wrong colors though, need to check that a little further.  OK, let's try something else... is the connector damaged or the sensor itself in anyway a problem.  Strike two... now this is getting serious.  Did the module fail?  Is there more to this story?  Where's the next pitch coming from?
tp.gifA little more snooping around and a bit more in-depth studying of the wiring diagram I think I've got the answer.  Very close to the impact sensor is another sensor with the exact same type of connector.  The real tell-tale was the wire colors.  It looks like when they put the car back together they inadvertently switched the two connectors.  (Pretty dumb to have the same type of connectors so close together under the hood... but it ain't the first time I've seen a curve ball like this.) I switched the leads and then went back into the system to clear the code.  (With most of these newer systems you not only have to clear the code but you also have to “reboot” the computer by turning the key off before attempting the next “at-bat”.)
tp.gifWell, this batter is ready, the catcher has thrown down the sign, the computers and connections on the playing field are ready to go.  All that's left is the pitch.  I turned the key and the pitch is on its way. The warning lights come on, the air bag light stayed on for its required amount of time and then.... went off.  No codes present and the rest of the systems checked out fine.  Yep, I took my swing, and it’s a long, long high flyer… it looks like…yes… yes it is… it’s a “HOME RUN!”
tp.gifHere's a perfect example of the diagnostics taking longer than the actual repair.  The way I see it, diagnostic is the mechanics swing at bat, and it's just as important as the actual repair.  After spending the time to research a problem only to find out that it was a simple connector doesn’t diminish the time already spent to find out it was just a connector.
tp.gifMechanics get paid to fix a car, that’s what we do, diagnosing a problem is part of it, and good diagnostic work will keep ya battin’ a thousand.
good story so true..  With the good long time customers the diagnostics fee is never an issue, but with the new arrivals from 90% - 95% you still get the "why do I have to pay for diagnostics I can get that done free at the parts store" (when pertaining to check engine lights) ...
That being said you still find some places that are a little overboard.. Had a little old lady (one of my good customers) who's husband died a couple of years back , I always dealt with the husband, but she now has no option but deal with me LOL.. anyway she was going to go out of town just for a night but she has a 300 mile drive and wanted to make sure her car was good to go.. she was a little afraid since her check engine light had come on .. So it being a newer toyota she went to the dealer for the lifetime oil change and the check engine light.. then she came to me with the results since she didn't have the time to fix it and wanted to know if it was okay to drive the car, they said it would need more testing.. so I looked at here paperwork, p0442 (small evap leak) diagnostic charge 180.00 bucks, will need smoke test 156.00 customer declines any further diagnostics at this time.. I said well small leaks can be hard to find but sometimes it is a simple as a loose gas cap sure enough I took a look her gas cap was just set in place.. tightened it cleared codes and sent her on her way.. no charge . I understand sometimes more diagnostics are needed , but if you are charging 180 bucks at least do the basic diagnostics before trying to get an extra 156 bucks..
      Timestamps:
      (00:00) – Intro
      Quotes
      Tools & Resources Mentioned:
      Final Thoughts:
      Thanks to our Partners, NAPA TRACS, and Today's Class Recorded at the 45th annual Mobile Air Climate Systems Conference (MACS 2025) in Orlando, Florida, this conversation explores the transition of leadership within the MACS Association. Outgoing chairman Andy Fiffick and incoming chairman Aaron Becker reflect on the organization’s history, its future direction, and the critical role of continuous education in the automotive industry.
      They discuss the necessity of adapting to technological advancements, particularly in thermal management for electric vehicles, and emphasize the invaluable networking opportunities offered by MACS and similar industry events. The conversation also highlights the increasing complexity of vehicle systems and the growing influence of AI in automotive businesses.
      Discover expert perspectives on emerging refrigerants, the integration of technology in vehicle maintenance, and the challenges and successes that have shaped MACS over the years.
      Aaron Becker, President, AirSept. Aaron’s previous episodes HERE
      Andy Fiffick, CEO Rad Air, 10-locations, franchise. Listen to Andy’s other episodes HERE Show Notes Watch Full Video Episode TST Big Event, March 29th, 2025: https://www.tstseminars.org/ MACS Training Event & Trade Show: https://macsmobileairclimate.org/ National Automotive Service Task Force (NASTF): https://wp.nastf.org/ Koura: https://www.kouraglobal.com/ Honeywell: https://www.honeywell.com/us/en Introduction to the Episode (00:00:00) Andy Reflects on His Tenure (00:01:44) The Impact of the Housing Crash (00:02:18) Transition of Leadership (00:04:39) Aaron Becker's Introduction (00:05:01) The Importance of Thermal Management (00:07:29) Thermal Management's Role in Modern Vehicles (00:09:03) Technology Specialists and Thermal Management (00:10:02) Aaron's Innovative Approach (00:11:40) Evolution of Products at AirSept (00:12:07) Adapting to Changing Technology (00:15:31) Reflections on Industry Changes (00:16:04) Understanding Vehicle Technology (00:16:55) Embracing New Technologies (00:18:20) AI Integration in Business (00:19:27) Networking at Events (00:24:18) Continuing Education (00:29:33) Encouragement to Join MACS (00:31:02)
      Thanks to our Partner, NAPA TRACS NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Thanks to our Partner, Today's Class Optimize training with Today's Class: In just 5 minutes daily, boost knowledge retention and improve team performance. Find Today's Class on the web at https://www.todaysclass.com/ Connect with the Podcast: -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on X: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Parker Branch of Branch Automotive joins the conversation to discuss shop culture, leadership, storytelling, and business growth in the diesel specialty repair industry. Learn about the importance of employee buy-in, boosting productivity, and ways to build customer trust through thoughtful use of technology. Parker shares his journey from technician to business coach, offering personal experiences and proven strategies for success. Parker Branch, Branch Automotive, Littleton, CO. Show Notes Watch Full Video Episode TST Big Event, March 29th, 2025: https://www.tstseminars.org/ The Institute of Automotive Business Excellence: https://www.wearetheinstitute.com/ Introduction to the Summit (00:00:00) Keynote Insights (00:02:07) Importance of Storytelling (00:04:08) Parker's Background (00:04:52) Business Growth (00:05:12) Culture in Business (00:06:02) Self-Assessment in Leadership (00:08:27) Team Accountability (00:09:27) Lean Practices (00:10:26) Building Trust with Customers (00:11:27) AI in Automotive Communication (00:13:33) Motivation and Resources (00:17:26) Attracting and Retaining Talent (00:18:14) Growth vs. Loss (00:18:40) Creating a Positive Culture (00:19:34) Dealing with Toxic Employees (00:20:19) Accountability After Conferences (00:22:22) Cultural Engagement Strategies (00:23:41) Networking and Collaboration (00:24:23) Productivity Challenges (00:28:00) Quarterly Performance Evaluations (00:28:31) Inspiring Change vs. Forcing Change (00:30:20) Seasons of Business (00:31:16) Creating Momentum in Business (00:33:14) Commitment to Success (00:34:21)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
      Thanks to our Partners, NAPA TRACS, and Today's Class Recorded at the 45th annual Mobile Air Climate Systems Conference (MACS 2025) in Orlando, Florida, Honeywell experts explore the advantages of retrofitting older 134A systems with 1234YF refrigerant, highlighting its significantly lower global warming potential. They also discuss the growing complexity of thermal management in EVs, where efficient cooling for batteries and electronics is essential, and the ongoing search for standardized, high-performance refrigerants. Gain insights into the environmental benefits of transitioning to 1234YF, the challenges of EV thermal management, and the critical need for education and training in the automotive aftermarket.
      Curtis Vincent, Honeywell MaryJo Vandenbrink, Honeywell Show Notes Watch Full Video Episode TST Big Event, March 29th, 2025: https://www.tstseminars.org/ MACS Training Event & Trade Show: https://macsmobileairclimate.org/ National Automotive Service Task Force (NASTF): https://wp.nastf.org/ Koura: https://www.kouraglobal.com/ Honeywell: https://www.honeywell.com/us/en Panel Introduction (00:0:00) MaryJo's Background (00:02:14) Curtis's Background (00:02:40) Thermal Management Discussion (00:03:12) EVs and Thermal Management (00:04:01) Heating Vehicles in Winter (00:04:43) Industry Trends Warning (00:06:27) Technician Challenges (00:06:57) Training on Refrigerants (00:07:21) Retrofit Solutions Discussion (00:07:59) Environmental Impact of Refrigerants (00:08:40) Flammability Concerns (00:09:32) Market Adoption of New Refrigerants (00:09:59) Discussion on Refrigerant Changes (00:11:01) Future Refrigerant Options (00:11:57) Standardization Challenges (00:12:37) Timeline for New Refrigerant Standards (00:13:44) Continuous Education Emphasis (00:16:26) The Impact of Refrigerant Usage (00:17:55) Environmental Implications (00:18:59) Transitioning to Electric Vehicles (00:19:55) EPA Approval Process (00:22:10) Flammability of Refrigerants (00:22:41) Refrigerant Retrofitting (00:23:10) Consumer Awareness (00:27:09) EV Thermal Management (00:30:20) Charging Experiences of EV Owners (00:33:19)le.
