Battin a Thousand - - Mechanics have to step up to bat and hit it out of the park every time
Battin' a Thousand
tp.gifThe batter steps up to the plate, takes a hand full of dirt
and rubs his hands and the bat.  He takes a few scrapes with
his feet from the batter’s box while digging in with his cleats.
He then gives the pitcher the evil eye and sets his bat ready
to take whatever the pitcher is going to throw at him. The
catcher gives the signs, the pitcher nods his head.  He takes
a quick look to first base makes his wind up and then lets the
ball fly to home plate.  The batter takes a swing... “Pop” the
ball is in the catcher’s glove.
tp.gif“Steee---rike!!!” yells the umpire.
tp.gifSomewhere there is an announcer telling the crowd the
count while a statistician is writing down the results of the
pitch, and calculating the batter's average. With baseball if
you can manage to get a hit 5 out of 10 times you’re up to bat…
you’re doing outstanding.  Achieving a perfect hitting record
on the other hand, may never happen in baseball, but in the
auto repair business (and most every other field of play)
batting a thousand is not a goal it's a requirement.
tp.gifEvery job that comes into the service bay is another attempt at keeping that perfect score.  Come-backs, bad diagnosis, faulty parts and the like are not what any service person wants to deal with.  To keep that perfect score going you have to overcome those obstacles and get the job done right before sending the customer’s car around the bases.  Unlike the highly paid professional ball player who is never going to achieve that perfect score the highly trained mechanic has to knock it out of the park each and every time.
tp.gifThere's a lot of talk in the industry about how some service advisers/writers and shop owners want a quick “off the cuff” diagnosis and repair rather than waiting for the results of a lengthy-time consuming diagnostic procedure.  A mechanic may have a general idea of what is wrong but it still takes proper testing to determine the correct course of action to make the repair.  I don't know where this idea came from that every mechanic has the correct answer to ever problem simply by listening to the description given to them by the customer or service writer.  It's not like we (mechanics) know what kind of pitch is being hurled at us each and every time.
tp.gifI'm sure the pro ball player could “up” his stats if he knew exactly what kind of pitch was coming across the plate.  As it is, he has to make a quick decision, make the right swing, and make contact.  In the repair world, analyzing the pitch is the key to a successful outcome.  Diagnostics is what makes the difference.  Especially on today's vehicles with their interconnected systems, multi-layered computer controls, and the occasional “oops” from a previous botched repair, these all have to be sorted out before the repair is made.  This takes time, diagnostics takes time, and time is money.
tp.gif When I hear that a shop isn't charging for diagnostic time it tells me they are either under estimating the value of proper diagnostics or believe they are good enough to read the catcher’s signals and in some way already know what pitch is being thrown.  Taking a couple of swings at a repair and not diagnosing anything is like standing in the batter’s box blindfolded.  I'd call that a foul ball waiting to happen for sure.
tp.gifIt’s important to examine a problem, diagnose as needed and not swing at every pitch that you’re given. In the long run, from the consumers standpoint, a shop that takes the time to diagnose a vehicle correctly may sound more expensive at first when you walk up to the service counter, but chances are you won’t be picked off at 2nd base because you have to spend more cash, buy even more parts that you probably didn’t need, while trying to solve the problem at those shops that don’t see a need in proper diagnostic time.
tp.gifA new player entered the field; it was a job from one of the body shops I do business with. This 2013 Ford Escape was almost ready to go home, however the air bag light wouldn't go off.  That's when I was called to plate.
tp.gif“We can sell this job today if you can get this taken care of.  We’ve struck out so far,” the owner of the body shop told me.
tp.gif“I’ll see what I can do,” I told him.
tp.gifThe first thing I did was check out what codes were in the system.  There was only one code.  B0095-11 (Right front impact sensor fault – sub code “shorted to ground”).  Since it was in a front collision I took my first swing up to bat by checking to see if the wires were smashed or cut.  Strike one... the wires are fine, wrong colors though, need to check that a little further.  OK, let's try something else... is the connector damaged or the sensor itself in anyway a problem.  Strike two... now this is getting serious.  Did the module fail?  Is there more to this story?  Where's the next pitch coming from?
tp.gifA little more snooping around and a bit more in-depth studying of the wiring diagram I think I've got the answer.  Very close to the impact sensor is another sensor with the exact same type of connector.  The real tell-tale was the wire colors.  It looks like when they put the car back together they inadvertently switched the two connectors.  (Pretty dumb to have the same type of connectors so close together under the hood... but it ain't the first time I've seen a curve ball like this.) I switched the leads and then went back into the system to clear the code.  (With most of these newer systems you not only have to clear the code but you also have to “reboot” the computer by turning the key off before attempting the next “at-bat”.)
tp.gifWell, this batter is ready, the catcher has thrown down the sign, the computers and connections on the playing field are ready to go.  All that's left is the pitch.  I turned the key and the pitch is on its way. The warning lights come on, the air bag light stayed on for its required amount of time and then.... went off.  No codes present and the rest of the systems checked out fine.  Yep, I took my swing, and it’s a long, long high flyer… it looks like…yes… yes it is… it’s a “HOME RUN!”
tp.gifHere's a perfect example of the diagnostics taking longer than the actual repair.  The way I see it, diagnostic is the mechanics swing at bat, and it's just as important as the actual repair.  After spending the time to research a problem only to find out that it was a simple connector doesn’t diminish the time already spent to find out it was just a connector.
tp.gifMechanics get paid to fix a car, that’s what we do, diagnosing a problem is part of it, and good diagnostic work will keep ya battin’ a thousand.
good story so true..  With the good long time customers the diagnostics fee is never an issue, but with the new arrivals from 90% - 95% you still get the "why do I have to pay for diagnostics I can get that done free at the parts store" (when pertaining to check engine lights) ...
That being said you still find some places that are a little overboard.. Had a little old lady (one of my good customers) who's husband died a couple of years back , I always dealt with the husband, but she now has no option but deal with me LOL.. anyway she was going to go out of town just for a night but she has a 300 mile drive and wanted to make sure her car was good to go.. she was a little afraid since her check engine light had come on .. So it being a newer toyota she went to the dealer for the lifetime oil change and the check engine light.. then she came to me with the results since she didn't have the time to fix it and wanted to know if it was okay to drive the car, they said it would need more testing.. so I looked at here paperwork, p0442 (small evap leak) diagnostic charge 180.00 bucks, will need smoke test 156.00 customer declines any further diagnostics at this time.. I said well small leaks can be hard to find but sometimes it is a simple as a loose gas cap sure enough I took a look her gas cap was just set in place.. tightened it cleared codes and sent her on her way.. no charge . I understand sometimes more diagnostics are needed , but if you are charging 180 bucks at least do the basic diagnostics before trying to get an extra 156 bucks..
      April 15th is behind us — but your tax strategy shouldn’t stop there. In this episode, Hunt Demarest, CPA at Paar Melis, shares exactly what auto repair shop owners need to be doing based on how their tax season wrapped up. Whether you filed early, waited until the last minute, or punted with an extension, Hunt helps you take the right steps now to avoid penalties, reduce next year’s bill, and keep your shop’s finances dialed in.
       In this episode, you’ll learn:
      Why filing an extension isn’t always a problem — but failing to plan ahead is The costly myth about tax extensions that trips up even seasoned shop owners What to do now if you owed a big tax bill or got a refund The IRS’s rules on estimated taxes and why ignoring them leads to penalties Smart financial habits every shop owner should adopt after tax season ends
      Bonus Episode - Creating Chaos Through Impulsive Business Decisions With Tannar and Kassiady Markham
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Recorded at the 2025 Institute Summit, workplace culture expert Dr. Jessica Kriegel discusses her data-driven framework for boosting business performance through clarity, alignment, and accountability, anchored by her "Results Pyramid," which highlights how beliefs and experiences shape outcomes.
      The discussion unpacks what truly defines organizational culture, the power of storytelling to inspire change, and challenges common generational stereotypes in the workplace, advocating instead for a focus on individual motivations and behaviors. Dr. Jessica Kriegel, Chief Strategy Officer of Workforce and Labor for Culture Partners Dr. Jessica Kriegel is driven by data and defined by results.  She transforms corporate culture for success.  As seen on CNBC, MSNBC, CNN, NBC, FOX Business, New York Times, Wall Street Journal, Forbes, and more,  Jessica is a household name for all workplace, labor, leadership, women in the workplace, and job markets. Her renowned “Culture Equation” was acquired by Culture Partners in 2021, where she is currently Chief Strategy Officer of Workforce and Labor. https://www.jessicakriegel.com/ Show Notes Watch Full Video Episode The Institute of Automotive Business Excellence: https://www.wearetheinstitute.com/ Overview of Dr. Jessica Kriegel (00:00:00) Three-Step Change Equation (00:02:47) Accountability in Business (00:03:31) Results Pyramid Explanation (00:04:11) Beliefs and Experiences (00:05:09) Defining Workplace Culture (00:06:50) Hospital Story for Illustration (00:12:02) Transformative Change Through Storytelling (00:14:09) Culture of Caring (00:15:09) Storytelling in Meetings (00:15:58) Generational Dynamics (00:17:51) Technology Adoption Across Generations (00:20:37) Connecting with Dr. Kriegel (00:22:23)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Margaret Palango, CEO of Autoshop Solutions, shares her unexpected diagnosis of acute myeloid leukemia (AML) in May 2023. In this powerful episode, she shares the emotional and physical hurdles she faced, the intensity of her treatment, and how she stayed grounded through it all with a positive mindset. Margaret highlights the critical role of a strong support system and how her team, resilience, and leadership helped her navigate one of life’s toughest battles. Her story is a moving testament to the strength of the human spirit. Don’t miss this inspiring conversation filled with motivation, hope, and meaningful life lessons. Margaret Palango, CEO Autoshop Solutions. Margaret's previous episodes HERE Show Notes Watch Full Video Episode Introduction and Celebration (00:00:00) Margaret's Introduction (00:02:18) Understanding AML (00:02:30) The Importance of Positivity (00:06:18) Treatment Navigation (00:07:32) Listening to Your Body (00:08:18) Advocating for Health (00:09:50) Teamwork with Medical Staff (00:12:35) Managing Side Effects (00:18:25) Bone Marrow Transplant Journey (00:19:56) Importance of Remission (00:20:50) Mental Strength During Treatment (00:24:00) Support and Positivity (00:28:34) Team Dynamics and Leadership (00:30:08) Planning for the Unexpected (00:36:20) Lessons in Trust and Growth (00:37:00) Support from the Team (00:40:12)
