In the market for a new lift. Looking for something that will work well for low vehicles but can still handle light trucks. 2 post, clear floor 10k lbs capacity range. I see a lot of manufacturers offer a bi-symmetrical lifts now. I've never used one. Thoughts? What do you have and like? I had mohawk's for the last 20 years, exploring other brands. Not going to get full time shop usage. Looking for the best bang for the buck but not anything that isn't ALI certified.
What do you have that you like and can easily get sports cars on (a problem for my asymmetrical mohawk without blocks of wood to drive on)
I Have Bendpak and Rotary in my shop. Depends on what you want to spend. .  I think the xpr10a-LP might be what you want. Or the Rotary Trio which is around $1,000 more. . You can check them out on their websites. Hope this helps.
That bendpak seems pretty nice, looks like it will do what I need. The only one I found that is lower is the tudedo/ideal TP10KAC-DX with 1/2 inch more clearance at the pad. Both are ALI certified. The bendpak is the better brand name for a few hundred more, probably worth it.
Thoughts on screw up pads? They are an option on both lifts, I've never had a lift with them, just drop in adapters.
I just have the drop in adapters. . I wish I had the screw up/ adjustable pads. . If you have a car where the plastic side skirt/Lip is lower than the body seam you need to lift against , then you will be clad to have the screw pads . . I would not put a tuxedo in my shop. . Id rather have Atlas lift if you need cheap. . . Spend a little more now will save you A lot more later. . . My Bendpak is definitely worth its money. Its great how I can lift either symmetrically or asymmetrically depending on what vehicle I'm lifting. I picked the Bendpak over the Challenger and have no regrets. hth
So I ended up getting the Bendpak XPR-10AS-LP with screw up pads. Overall I like it. For others that are looking at this there are a few things about it that I don't really like and should be noted. The worst is the height of the first lock. If you want to get a car only a foot or so off the ground you can't do it with the car on the locks. The first lock puts the car like three feet in the air. This means that engine pull that takes all day and has the car up and down a dozen times isn't on the locks when its low. I also I like to put a car up a foot or so when doing engine work on a low car to save the back not on this thing and low cars were my primary driver to get this lift. Or a timing belt on a transverse engine where you need to be above and below all the time. A stool and and the lift up 18" is perfect, can't do it on this machine though, it won't be on the locks. That being said when I just did that a few days ago the lift didn't budge even though it was off the locks for a few hours, but that isn't recommended usage.
A few other things that should be noted, the effort you need to release the lock lever is impressive. My installer said it would wear in after a while but if you're on this lift all day your hand will hurt where you press on the lock release. You have to put body weight into it. I'm going to contact bendpak about that one, doesn't seem right, but it's all installed right.
Lowering speed is SsssssLOW, I mean really slow, especially when the weight of the car isn't on it, that last few inches could take 15 seconds, which seems like a lifetime when you're watching the water boil
The arms could be longer. We installed in the wide position so it probably wouldn't be an issue in the narrow setup. Getting some vehicles with full frames and therefore inboard lifting points is difficult, you have to jockey the car around to get it to reach. I haven't had one the didn't work yet but I can see this being a problem with some trucks.
None of those these things are a problem with the Mohawks but the bendpak is much lower and I really like the single side safety release. Plus the bendpak was way cheaper.
      This week on Business by the Numbers, Hunt Demarest, CPA with Paar Melis and Associates, breaks down the latest market news and legislative updates that directly impact auto repair shop owners. From the return of the BOI (Beneficial Ownership Information) report to evolving tax policy discussions and IRS processing delays, Hunt provides a no-nonsense analysis of what’s happening and how it could affect your business.
      In This Episode, You'll Learn:
      ✔️ The BOI Report is back—what it is, why it matters, and the March 21st deadline you can’t ignore.
      ✔️ Trump’s tax proposals—what’s being discussed, what’s likely to pass, and what it means for your shop and your customers.
      ✔️ IRS struggles & refund delays—why tax processing is slower than ever and what to expect if you’re waiting on an Employee Retention Tax Credit (ERTC) refund.
      ✔️ Interest rates & the economy—why rates aren’t moving much (yet), and what this means for your financial strategy in 2025.
      ✔️ The state of small businesses & consumer spending—how last year’s trends impact this year’s outlook, and why customer financial health affects your shop’s profitability.
      Closing your shop on Saturdays might sound like a risky move, but could it actually improve your business? In this episode of Business by the Numbers, Hunt Demarest, CPA, explores the real financial and operational impact of shutting down on Saturdays. Is it worth it? What factors should you consider before making the switch? Whether you're thinking about a 5-day workweek, reducing hours, or making strategic changes to your shop’s schedule, this episode is packed with insights to help you make an informed decision.
      Key Topics Covered:
      ✅ Why auto repair shops are moving away from Saturday hours
      ✅ The financial impact of closing on Saturdays—and how to make up for lost sales
      ✅ How to determine if your shop can afford fewer workdays
      ✅ The role of employee preferences in business hours
      ✅ Attracting top talent by offering a 5-day workweek
      ✅ Strategies to transition customers from weekend scheduling
      ✅ Real-life case studies of shops that successfully cut their Saturday hours
    • By DUFRESNES
      In this episode, Craig is concise as he reflects on the timeless wisdom of Martin Luther King Jr. and how his principles of nonviolent conflict resolution remain highly relevant today. Inspired by recent readings of King’s works, specifically his iconic Letter from Birmingham Jail, Craig explores how these lessons can be applied to resolving conflicts in everyday life—even in situations as modern as addressing negative reviews.
      This thoughtful discussion acknowledges the historical context of King’s writings while highlighting their enduring value in promoting understanding, negotiation, and meaningful resolution.
      Key Points Discussed:
      Craig’s Appreciation for MLK’s Legacy: Acknowledging King’s brilliance as a leader, communicator, and writer, Craig emphasizes the enduring relevance of his concepts and principles. The Four Steps of a Nonviolent Campaign (as outlined in Letter from Birmingham Jail):
      Collection of Facts: Ensure injustices are present and verified. Negotiation: Open dialogue with a willingness to find common ground. Self-Purification: Prepare yourself to act constructively and maintain the ability to return to negotiation. Direct Action: Take deliberate action aimed at fostering a return to negotiation.
      The Word of the Day:
      Unfettered.
      Adj - Not controlled by anyone or anything.  Uninhibited
      Modern Applications:
      Craig draws parallels between these steps and common missteps in conflict resolution today, such as skipping fact-gathering and jumping straight to retaliation—like leaving a low review without understanding the full story. He discusses how these missed steps can lead to escalation rather than resolution.
      Takeaways for Listeners:
      People care about how much you know only after they know how much you care. Applying MLK’s principles to situations like resolving a customer complaint or an unjust review can model constructive engagement and encourage others to seek facts, negotiation, and resolution.
      This episode is a thoughtful tribute to King’s enduring legacy and a practical guide for applying his lessons to resolve conflicts with empathy and integrity.
      Links & Resources:
      Letter from Birmingham Jail by Martin Luther King Jr.
      Join Craig as he unpacks these timeless lessons and their power to transform the way we approach conflicts in our personal and professional lives.
    • By DUFRESNES
