Drain the Swamp - Sometimes you're asked to repair a car...not count the alligators along the way.
Drain the Swamp and Count the Alligators
Occasionally the customer has more confidence in you than you do yourself.
         The old farmer tells his hired hand, “Get down there and drain that swamp today.”
         The hired hand says, “Looks like there’s a heap of alligators in there.”
         “Don’t ya never mind about them gators, you just get that swamp drained!” the old farmer explains.
         Some days I feel like the hired hand.  I’ll get a job in, and I already have the feeling there is going to be a whole heap of alligators between me and draining that swamp.  This time around it’s a 2004 Nissan 350z with a non-functioning convertible top.  The top was up, but wouldn’t move, other than unlatching the rear (5th bow) window section of the top.
         Jim is an old customer who loves his little Z car, and was well aware of a few of the alligators lurking under that deck lid.  How did he know?  Easy, he already tried to get it repaired at a convertible top shop, but they weren’t up to the task of taking on this alligator infested swamp.
  Jim’s only comment to me was, “I don’t care how many problems you find, just get it working for me.”
         After gathering all the TSB’s, wiring diagrams, procedures, and any other bits of info I ventured out into untested waters to see what I could find out. All the test procedures started out by checking pin-out voltages and resistances at the convertible top ECM, and guess where that is?… under the very same deck lid that isn’t moving… hmm, imagine that.  The trunk is the only option.  You’ve got to crawl in there and find the cables to release the deck lid manually.
          You could tell somebody else had already been working on it; the emergency cables were nowhere to be found.  I looked like some sort of contortionist trying to get down into the small little opening at the bottom of the trunk with my bore scope. I had to wiggle it around in there, until I found the very thin wire cables that would release the latches. (They were pushed back under the lining of the storage area, which is not accessible from the trunk area)  Ugh, I haven’t even moved the top yet and I’m already swimming with the gators… what could be next?
Once I got the deck lid up I could then remove the interior trim and test the ECM to see what needed to be done.  The output voltage for the 5th bow actuator motor was coming out of the ECM, so unless the wires are broken or disconnected the motor must have failed.  Ok, now crawl out of the storage area and wrestle my way into the passenger compartment, then pull the trim piece on the back window up to expose the 5th bow motor.  The motor brushes were shot.  Lucky for Jim, I just happened to have some brushes that were a perfect fit.  Might as well replace the brushes and see if it will work.
         I gave it a try.  With a flip of the control button the 5th bow swung up into perfect upright position, but the top wouldn’t move.  What now!?!?  Back to the ECM and check the stop switches and motor voltages to the top.  This time the alligator is in the ECM. Inside the ECM I found the circuit board lead to the top motors was burnt in two. Ok, fix the circuit board and try again.  The top moved smoothly through its folding process.  As the top closes the 5th bow actuator has to rotate in the opposite direction, so it will sit flush inside the convertible top storage compartment.  As the bow moved to its next position the whole thing quit again.  Oh come on… enough already… more alligators?!?!   Yes, more alligators.  Another trip back to the ECM, this time I found the stop switch for this position wasn’t working.  Somebody had bent the micro switches so far out of whack there was no way most of them were ever going to work.    By now I’ve called Jim at least a dozen times to keep him informed of what I was up against… his only answer, “Keep draining the swamp” Ok, Ok, I got it… I’ll put my waders on and crawl upside down and sideways to get this thing working… but…man these alligators… they’re everywhere.
         If you counted the different movements from completely up to fully down there are 12 separate electrical/mechanical operations the top has to go through, AND they all have to work in the correct sequence.  One micro switch out of position and something else begins to move at the wrong time.
         I thought I was done with my alligator counting by the time I had the last micro switch in place, but the first time I got the top to fold up and drop into the storage area, it would stop about an inch or so from completely going down.  Seriously? More gators on the prowl?  What did I miss this time?  I went thru all the electrical and mechanical diagrams again… Nothing, every step was correct, but there had to be something missing.  Then I found the answer on one page.  One short reference to some elastic straps that connect the 2nd bow to the 3rd bow.  These straps spring the 2nd bow towards the rear of the car to allow for clearance, so the canvas and all the linkage arms can drop that last inch or so into the storage compartment.
         I did some more searching and found the part number 97150-CE01B “strap, elastic, convertible top”. I called the dealer and gave them the number…
“Yea, it’s a good number, but we’ve never sold any.”
   I’m shocked. From what I found out lots of these convertible tops had the same problem. I figured they would have changed hundreds of these.   It looks like it’s a common alligator in this part of the swamp; seems to me every top should probably have these replaced with the new part number, (know somebody with one?… give them that part number).
   “Well, get me a set of them.”
   Once the parts came to the shop, installing them was a piece of cake compared to everything else I had to do.  At least now I could see the bottom of this swamp.  No more alligators, no more swamp to drain… I’m done. I found 20 different problems in the top mechanisms and electrical components.  That’s a total of 20 alligators that were lurking in this swamp. What a job!
         It took a lot of effort to solve all the problems that I found. It didn’t matter much to Jim how many things needed taken care of, the smile on his face as the 350z top worked like new made all that gator wrestling worthwhile.  I almost gave up on it several times, but Jim insisted that I keep at it… I’m glad I did.
         So the next time I take on one of these gator infested jobs, I know exactly what I’m going to do.  Ignore the difficulties, and do just like the old farmer told his hired hand to do.
 “Drain the swamp, and don’t pay no mind to all those alligators”.
Old story, busy week.  Ran out of time to complete a new story.  But, this one came to mind after working with the students at the college.  They seem to spend a lot of time telling me what they think is a problem or something they've done in the past that's wrong with the cars instead of fixing what they're supposed to do.  (The college cars are never going to see the road again these cars have been torn apart so many times they should have been held together with velcro instead of screws LOL).
I tell them all the time, "Don't count the alligators...just drain the swamp."
yes, just keep an open mind when working on anything, even if it's been through the "butchers" and your the next guy working on it!
  • Thanks 1
 Had this job been assigned to a tech, how would you want that person to have handled it ? Obviously it would be impossible for the tech to catalogue each and every problem before he estimated what it would take to get the top functioning properly.
A real problem would have been to estimate it.  As it was, ..... More time was in it than what was billed.   I've seen jobs, repairs, and cars that were given up on because an estimate wasn't possible.  If the customer is understanding, like this one it can be done.  If they are not, well.... It ain't going to happen.  I still made a buck on the job, but it should've paid more, maybe not for hours but for the difficulty and not so much for the actual hours.
      Check out their podcast here: https://autorepairmarketing.captivate.fm/ If you would like to join their private Facebook group go here: https://www.facebook.com/groups/autorepairmarketingmastermindIn
      In this episode of "The Weekly Blitz," host Chris Cotton is joined by special guests Caroline Legrone and Kim Walker from Shop Marketing Pros to delve into the critical necessity of having a robust marketing plan for auto repair shops. The discussion centers around the pivotal role that a well-structured marketing strategy plays in the success and sustainability of these businesses.
      Chris, Caroline, and Kim explore the multifaceted aspects of marketing planning, emphasizing the importance of leveraging historical data to gain insights into the business's performance over time. By analyzing this data, shop owners can pinpoint slow periods and develop proactive marketing strategies that align with local events and seasonal trends, thereby optimizing their outreach efforts.
      Caroline Legrone underscores the significance of understanding past performance metrics, which can provide invaluable information for future planning. She explains how historical data can reveal patterns and trends that are crucial for making informed marketing decisions. This approach not only helps in identifying potential challenges but also in capitalizing on opportunities that may arise.
      Kim Walker, on the other hand, offers practical insights into the creation of a comprehensive marketing calendar. She shares her expertise on how to systematically plan marketing activities throughout the year, ensuring that the shop remains visible and engaged with the community. Kim's advice includes tips on scheduling promotions, aligning campaigns with local happenings, and maintaining a consistent presence across various marketing channels.
      Throughout the episode, the conversation is geared towards empowering shop owners to take control of their marketing efforts. By doing so, they can ensure sustained growth and foster stronger community engagement, even during traditionally slow periods. The episode serves as a call to action for auto repair shop owners to prioritize their marketing strategies, highlighting the long-term benefits of a well-executed plan.
      Introduction and Importance of Marketing (00:00:09)
      Chris Cotton introduces the episode and emphasizes the need for a marketing plan in auto repair businesses.
      Guest Introductions (00:01:11)
      Chris welcomes Caroline Legrone and Kim Walker from Shop Marketing Pros to the podcast.
      Discussion on Car Count Issues (00:01:48)
      Chris expresses concern over shop owners complaining about low car counts and the lack of planning.
      Identifying Seasonal Trends (00:02:32)
      Kim discusses common excuses for slow periods and the importance of recognizing seasonal trends.
      Understanding the Marketing Calendar (00:04:23)
      Caroline explains the significance of analyzing past performance to create an effective marketing calendar.
      Proactive Marketing Strategies (00:06:11)
      Kim shares insights on developing marketing plans based on historical data and identifying slow periods.
      Creative Marketing Solutions (00:07:25)
      Kim describes a unique marketing strategy developed around the local state fair to attract customers.
      Importance of Planning Ahead (00:09:27)
      Kim emphasizes the necessity of proactive planning rather than reacting to slow days.
      Timing for Event Promotions (00:12:30)
      Discussion on how far in advance to plan marketing strategies for events like the state fair.
      Community Calendar Considerations (00:14:09)
      Caroline advises checking community calendars to align marketing efforts with local events.
      Adjusting Marketing Budgets (00:16:19)
      Kim discusses the importance of reallocating marketing budgets based on seasonal trends.
      Applicability to Different Locations (00:16:27)
      Chris challenges the notion that marketing strategies are only relevant to local events, encouraging broader application.
      Yearly Planning for Marketing (00:17:09)
      Caroline stresses the importance of yearly planning for marketing strategies, even if starting late.
      Setting Holiday Schedules (00:18:49)
      Chris shares his approach to planning marketing around holiday closures as a starting point for the year.
      Here are the extracted timestamps and their corresponding titles from the podcast episode transcription segment:
      Importance of Planning (00:19:14)
      Chris emphasizes the need for shop owners to have a structured marketing plan.
      Blocking Time for Planning (00:19:40)
      Kim advises shop owners to set aside undistracted time in October for planning.
      Using a Big Calendar (00:20:17)
      Kim suggests using a large calendar to visualize important dates and events affecting marketing.
      Analyzing Performance Data (00:22:25)
      Kim discusses breaking down historical data to identify busy and slow times for better planning.
      Setting Realistic Goals (00:24:20)
      Caroline stresses the importance of setting achievable marketing goals based on past performance.
      Understanding Marketing Budgets (00:26:17)
      Kim explains how to determine an appropriate marketing budget based on desired growth.
      Plan with the Pros Conference (00:28:49)
      Caroline introduces the "Plan with the Pros" event aimed at helping shop owners create marketing plans.
      Event Success and Expansion (00:31:01)
      Kim shares the success of last year's event and plans for expanding this year's attendance.
      Facebook Group for Marketing Support (00:33:15)
      Caroline details the Auto Repair Marketing Mastermind group for shop owners to connect and share insights.
      Final Thoughts on Marketing (00:37:02)
      Caroline encourages shop owners to create marketing calendars and utilize available resources for success.
      Do It Scared (00:37:51)
      Encouragement to start marketing despite fears of making mistakes or not knowing how to begin.
      Getting Started (00:38:11)
      Emphasis on taking action; "done is better than perfect" and scheduling time away from the shop.
      Perspective on Fear (00:38:22)
      Discussion on the urgency of creating a marketing calendar to avoid business decline.
      Final Thoughts and Thanks (00:38:41)
      Closing remarks and encouragement to utilize marketing pros for effective growth strategies.
      Sponsorship Shout-Out (00:39:11)
      Promotion of Shop Marketing Pros as the recommended marketing partner for auto repair businesses.
      Closing Remarks (00:39:11)
      Encouragement to maintain a positive mindset and a farewell from Coach Chris Cotton.
      940-400-1008
      YouTube: https://bit.ly/3ClX0ae
      Email Chris: [email protected]
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Recorded at the 45th annual Mobile Air Climate Systems Conference (MACS 2025) in Orlando, Florida, Rob Bollinger shares the unique story of his third-generation family business, emphasizing their commitment to personal service and the legacy of his grandfather, who invented the overflow bottle system. The discussion also touches upon industry trends, the challenges of price competition, the evolution of AC systems with electric vehicles, and Bollinger's future plans for the business. Rob Bollinger, ABC Radiator, Baltimore, MD. https://www.facebook.com/abcradiator401 Show Notes Watch Full Video Episode MACS Training Event & Trade Show: https://macsmobileairclimate.org/ National Automotive Service Task Force (NASTF): https://wp.nastf.org/ Koura: https://www.kouraglobal.com/ Honeywell: https://www.honeywell.com/us/en Introduction to MAC Conference (00:00:00) Guest Introduction: Rob Bollinger (00:02:17) Rob's Family Business Legacy (00:02:52) Personal Touch in Deliveries (00:03:52) Customer Engagement During Deliveries (00:04:30) Rob's Background in the Business (00:06:08) Regrets About Family Business (00:06:22) Coolant Reservoir Bottle Invention (00:07:40) Patenting the Invention (00:08:25) Legacy of the Invention (00:09:48) Cash vs. Cashless Transactions (00:10:05) Honesty in Business (00:15:46) Future of Specialty Shops (00:16:20) Customer Outreach (00:16:30) Changes in Radiator Industry (00:16:54) Hiring Challenges (00:18:11) Golfing and Business Balance (00:18:39) AC Industry Challenges (00:20:10) Leak Detection Methods (00:20:57) Future Plans (00:21:50) Real Estate and Business Stability (00:22:28) Family Support (00:23:33) Training and Industry Updates (00:24:26) Vendor Interaction at Conferences (00:25:08) AI Repair Discussion (00:25:55) Reflection on the Conversation (00:26:09)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
