I am complexed about how many "Mechanics" just don't get it... I work with two guys older than myself, I am no spring chicken but not old either.. One of the guys had a car with a p0171 as most know a very common code lean bank 1.
He had replaced the o2 sensors two weeks ago on a Saturday a day I don't work.. The customer came back with the same code IMAGINE THAT ! So they asked me to take a look at it with the other mechanic, I had shown this guy about fuel trims a few weeks ago. I hooked my scanner up looked at 02 data , maf , long and short term fuel trims.. at idle the LTFT was high 19 not high enough to set the code, and the O2 showing what you would think low voltage (lean).
I raised the rpms and noticed the maf readings still low and the LTFT rising. At which point I put the car in drive and the LTFT really started to rise at idle and maf stayed low, I raised the rpms the car hesitated and the LTFT kept climbing..
I asked the guy what he thought he had no Idea.. So I told him pop the hood the air induction hose is broken between the maf and the throttle body.. He thought I was joking, He opened the hood and was in shock "how did you know that"? I told him simple I know what I am looking at and how things work, but my question to him was how come he did not know that. He looked like a deer in headlights..
He replaced the induction tube, at which point I hooked the scanner back up to show him that now we can prove our repair was good.. I asked him what he would think would happen he had no Idea. so I pulled up all the same items and told him to watch the LTFT and that it will fall quickly and the O2 would come to life.. Sure enough it did in fact the LTFT went a little negative -5 I asked him why he thought that happened he had no Idea, I explained it had been adding fuel for so long it is probably saturated and there is probably a lot of fuel still in the engine and exhaust manifold.. it would clean out as time goes by but that proves the repair is good. At which point I unplugged the scanner and that was that..
now today same lean code on a different car the guy looked at me I said remember what we did ? He said yea, I went over after about half an hour and he had not figured anything out.. in fact he had all kinds of not needed data up on the scanner.. I shook my head pulled up the fuel trims did a few easy checks noticed that the fuel trims went back in the good range with the rpms raised told him to look for a vac leak . HE found one I showed him the fuel trims again and how it verified the repair was good...
He still has no Idea of what we went over! is it me or is there a need for a lot of learning to be done .. do some people just have the knack and others are just destined to be guessers and parts changers?
Some people don't get it as easy others. Next time hand the guy the scanner and let him drive. Then coach him by asking questions not giving him the answers. It takes a little more time and can be a little challenging in coming up with the right questions but I have found this approach a better way of training techs.
I see your point and agree to a certain extent.. The thing is I am not trying to train these guys. I have even found problems and scrolled the problem to the top of the scanner on the data or just added in a couple other data reading to the problem and they still can't figure it out. They are older than me and been at it longer than myself.. I have been doing this for 26+ years, but was very young when I got into the business just 17 (kicked out of high school went to LTI) . It seems to be a very common thing that these guys just throw parts at cars hoping to fix them and not doing any testing after the repair to make sure they fixed the problem.  Sure back 20+ years ago there wasn't much in the way of diagnostics that needed to be done.. but that is a very very different story now a days.. These are the guys that continue to give good mechanics a bad name, not to mention I have over heard them talking about just plugging their scanner in and they would know the problem.. Well if you can find a scanner like that I would love to have one.. This is part of the reason i think that mechanics are underpaid for what they do.. you get the guys throwing parts guessing etc.. sure why pay a diagnostic for that.  But the ones that do it correctly are the ones that suffer..
  • 4 months later...
In my automotive education program, I learned how to take an excessive number of daily breaks - that was about it.  I was in a Toyota accredited program at a community college.  ASE exams are so easy to pass (under 70% correct is passing)  and the dealerships will hire anyone who knows how to change oil - the industry as a whole has low standards of qualification.
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
      The TRUTH About Business Coaching That Companies Don't Wants You to Know!
