I was actually going to post something else but Autoshopowner saved this post that I was going to post a couple weeks ago..... guess I forgot to post it lol.
Has anyone had a bad day? I knocked down 3 beers after work and finally getting to a point where I'm not pissed. I am usually a really positive and upbeat and let things slide.
Had a tech do a oil pan gasket. Car came back, got it on a lift and saw within 3 seconds it was missing an oil pan bolt. Careless error- really out of the way for the customer to have to come back.
Same tech allowed master cylinder to run dry on a Ford. I literally spent the day bleeding that thing- from taking the master cylinder off to bench bleed to removing the lines to the HCU. I went through 2.5 gallons of brake fluid in all. I typically don't work on cars anymore, if I do, then either we are really busy or we have a problem.
Yesterday I ordered a TPMS sensor at 3:15.  This dealer can usually deliver in 30-60 minutes.  They called at 5:42pm to say that their driver didn't show up for work.  Ended up putting a rubber valve stem in temporarily to get customer on their way.  At least the customer was understanding.
That is a pretty amazing customer
Not a fantastic day today. I was supposed to be working on my boat, but we had a problem child. Ford E-350 we put a transmission in, the supplier said we had to install the latest flash on the PCM. We recently started using the Drewtech remote programming service and it's been pretty seemless so far. Not today. The truck has a few aftermarket items installed and Drewtech thinks one of them (gps tracking unit or magnet operated antitheft system) may be interfering with the CAN bus. Anyway, after screwing with it all day long, they bricked the computer. Ford dealer says 7-10 days. Ordered a reman, wasn't even close to the right part. Found another reman that will be here in the morning. May or may not be the right one.
This is my most profitable fleet customer's box van. I need this thing to go down the road and soon.
That sounds terrible!  Have you thought about a boneyard PCM?  Then you can experiment with flashing on a disposable one instead of burning up a new one.
Anderson, sorry to hear about the bad day. There are too many of those. Not to rain on the bad day but this opens up a discussion that needs to be had IMO. From what I have been told, this Drew tech thing is subscription based, does not have full coverage (lines) and does not have full operation (only does ECM's). I think there are 2 problems created by using this resource. First off, it could limit a techs ability to understand the entire workings of the network by plugging in a unit and letting someone else deal with it. If the tech gets to the point of knowing it needs to be reprogrammed and then plugs in the unit and it works (or not in your case) limits the desire/ability to do it all in shop. (I hope that thought makes sense). Kind of like a shop that does brakes but has no idea how ABS functions.
Second, why limit the ability of the shop by using a generic tool like that as opposed to the factory unit. A IDS only costs 1k or so to purchase and a years subscription to Fords tech site is only $850. By doing it all in house it requires tech ability and knowledge and there is less room for error. I would think in a shop your size you would already be equipping it with factory stuff as opposed to the generic.
I would think as shops grow in size and revenues (or specialize if smaller) they would seek out OE solutions to the technological problems we are being faced with. The further behind we fall the more outdated our abilities will become.
Edited by Wheelingauto
The Drew Tech box is not a subscription, but a per use fee. They gave me the box for free, and if I decide I don't like it, then I simply send it back.
The main reason for getting it was that while I can program just about anything with my PassThru Pro, it's a big time consumer. Seems like every time we flash a vehicle, there's some sort of update that needs to be done, consuming lots of tech time doing it. Then there's the matter of us not doing enough flash jobs for any of them to get good at it. While we're a big shop, we still only do 4-5 flash jobs a month. Now spread those 4-5 jobs among 6 techs, and all the different makes and models, and there's no way for a tech to really get good at any of them. So they burn a lot of time updating software before it will allow them to flash the car, then they have to remember how to actually get the flash software from that particular manufacturer, then remember our user name and password to that manufacturers web site. Seems like every manufacturer has different rules for user names and passwords, so none of them are the same and most make you change it regularly. Then start flashing the vehicle. In all, my techs were spending a couple hours jumping through all the hoops to get a simple flash done.
Then there's the economics of it aside from my tech's time. I have a new WiTech that I bought 1 year ago. I have to purchase an annual license just to own the WiTech, then I have to purchase a subscription for the flash software. In all, a couple grand a year, plus the tool which was not cheap. I flash maybe 10 chryslers a year. There's absolutely no ROI in it. The Drew Tech box doesn't do chrysler yet, but when it does, and assuming it does them well, you can bet I won't renew my WiTech license.
I guess the point I am making is I think it is our best interest to fully understand the technology we are faced with. Generic tools only allow partial understanding like using a snap on scanner VS that witech. Huge difference. I know ROI is weak if not non existent, but I have always believed in having the knowledge within my business. I would think it would benefit you to have one or two techs take the time (paid of course) to maintain the tools and passwords, understand the technology and be leaders in the shop when it comes to this.
I could be wrong but I feel there is a difference in using the generic tool vs the oe. And I want that for the top car lines I serve.
Not every tech needs to be proficient at BMW but if you're going to work on them at least one must be familiar with them.
    • By Jay Huh
      Long story short, been in business about 2 years and started mobile. Current location for about a year, just opened up a second location about 3 weeks ago- HUGE step for me.
      In my area, auto shop locations are REALLY REALLY RARE. There'll be months before a single shop will pop up for lease.
      Well.. I was looking for auto equipment on craigslist and stumbled upon a listing of a shop moving and selling all his lifts. Found the location on loopnet- 5 bays, previous business extremely successful, great location, great price too....
      1st location hit record sales this past week, 2nd new location held its own (divided by week, came out on top after expenses). I got both stores running self sufficiently. I am pretty much maxed out and I hate taking out loans but I have a line of credit available.
      Am I crazy to want to do this?
      As a business owner, the fast pace of entrepreneurship can feel overwhelming, but when do you give yourself permission to slow down? In this episode, we delve into The Art of Slowing Down—what it means, why it’s important, and how to make it a reality in your daily life.
      From intentional daily practices to creating systems that allow you to step away, this episode shares actionable insights and personal experiences to inspire you to find balance. Whether you’re planning for the future or simply trying to catch your breath, this conversation will encourage you to rethink how you manage your time and energy.
      Hit play now to learn how slowing down could help you build a healthier, more sustainable approach to business and life!
      Thank you to our friends at RepairPal for providing you this episode. As shop owners we were part of RepairPal’s Certified network and you can learn more at RepairPal.com/shops.
      Introduction to the Episode (00:00:01)  The host introduces the podcast and the topic of slowing down in auto repair business ownership. Discussion of New Features (00:00:46)  The speakers mention the potential of live streaming their podcast on Facebook. The Importance of Slowing Down (00:01:59)  The co-host emphasizes that slowing down doesn't mean being lazy or complacent. Target Audience Clarification (00:02:16)  The host clarifies that the episode is not for new business owners who are still growing. Personal Experiences with Surgery (00:05:30)  Kim shares her experience of recovery after back surgery and the need for slowing down. Planning for Recovery (00:06:56)  Kim discusses the importance of planning and preparing for recovery from her surgery. Building Trust in the Team (00:09:59)  Kim reflects on how stepping back built confidence in her team and their abilities. Easing Back into Work (00:12:33)  Kim talks about her gradual return to work and the importance of giving herself grace. Avoiding Extreme Situations (00:13:25)  The host encourages listeners not to wait for extreme situations like surgery to slow down. The Importance of Slowing Down (00:14:32)  Kim discusses the brutal nature of automotive conference seasons and the need for downtime. Personal Time and Routine (00:15:25)  Kim shares her Friday routine, emphasizing quiet time, workouts, and relaxation. Work-Life Balance for Entrepreneurs (00:16:14)  Kim reflects on the stress of entrepreneurship and the importance of not working excessively every day. Freedom of Time and Finances (00:18:22)  Kim highlights the reasons for becoming a business owner, focusing on achieving freedom of time. Daily Slow Time (00:18:38)  Brian talks about integrating intentional slow time into daily routines, even during work trips. One Minute Pause Technique (00:19:28)  Brian introduces a one-minute pause app for quick moments of mindfulness during busy days. Creating Healthy Leadership (00:20:30)  Brian emphasizes the need for leaders to be emotionally and physically healthy for their teams. Encouragement to Slow Down (00:21:25)  Kim encourages listeners to consider slowing down and reflects on building a supportive team. Conclusion and Thanks (00:22:29)  Kim and Brian thank their sponsors and invite listeners to tune in next week.
      Episode 197 - Used Parts & Bad Practices In Auto Repair With Jeff Compton & Keith Perkins
