Curios to hear what other shops are doing for headlight restoration services. We used to just wet sand then polish with a bottle of some turtle wax headlight cleaner. They looked great when we finished, but the problem was it didn't last. We then started using a product called Light Rite. It takes much longer to use this product since you are having to tape off a good bit of the surrounding area when you spray on the clear coat. It looks great most of the time, but we've had issues with it flaking later one, or not going on real evenly. It's also difficult to charge enough and still come out ahead time-wise.
So I'm curious, what is everyone else doing and what are you charging? What kind of warranty are you offering on the service? I'm to the point that today I told the guys we are not selling the service anymore until we find a better way.
We do not ever talk about cleaning the headlamps. We tell the customer that they will be able to see MUCH BETTER at night if we replace the headlamp assemblies, and we sell a butt load of headlamp assemblies.
Just 2 weeks ago we installed a set in a Chevy Equinox for around $770.00 and the client was absolutely delighted to see her new lamps in place. Last week we installed a pair in a 2007 Impala, and today I
ordered a pair for a 2006 Dodge Caravan. These replacements make for a very high profit job and a very satisfied client!!
GREAT POST!  We also stock the Lite Brite System - seems to be the only one that actually works.  And like you, I have a hard time selling the job and making any money.  Especially if it is cold and cloudy out and we have to use the UV lite to make things dry.  And I have a shop around the corner with a sign out front doing the 3M job for like $39.95 with a "Lifetime Warranty".  I think I may change my tactics and sell more headlights.  :-)
We used the Lite Brite system for a couple of years.  Some cars did really well, others we had to redo, some more than once. And as already stated, you can't do it on cloudy days without the UV light.
We eventually decided that is wasn't something we wanted to offer and we stopped doing them in house. We have technicians in the shop and not painters.  We do quote Factory headlight replacement and sell a few here and there. We also have made arrangements with a local body shop and send all of the restorations to them. Every single one they do looks better than any restoration we have ever done.  They put a lifetime warranty on the service and we have had zero warranty issues in the 3 years we've been using them.  They give us a discount if we bring them the vehicle or charge full retail to the customer if they bring it (that way the price is the same to the customer so we don't look like we are "overcharging").  This has worked out great for us and in this business it is always good to have a relationship with a body shop!
Unfortunately, we work on a lot of luxury vehicles. I've seen a RX350 set of headlights cost over $2,000 just for the parts, not counting labor, so selling a new set is out of the question sometimes 😬 and I'm over the comebacks. At this point, we've stopped selling the service. Until we can find a better solution that is profitable and doesn't have as many comebacks, we're going to continue holding off.
We have experimented with several products (brush and spray) and I can't even remember the names of most. We have all the 3M buffing kits and products (which we no longer use except for the sander). All you really need to make it faster is the small 3" DA sander and make sure the the adjacent painted surfaces are masked off to prevent sanding damage. We charge $99 and just mask off the lamps,  sand them with 500-600 grit paper and spray them with spray can clear which works as well as any of the products we have experimented with. We inform the customer that they will last 1 -2 yrs at best. Yes over time they will sometimes peel , and the results will not be as good as headlamp replacement, but if you inform the customer up front it's not an issue. They know they are getting a temporary fix. We give the price for the alternative and that usually seals the deal.  They are typically delighted with the finished product. We are also located in South Texas so getting them to dry is not an issue.
And if you're thinking about using aftermarket lamps I would not recommend it. I also have a Collision Shop and pretty much they are the standard for insurance replacement if it is not a current year model car or if you don't have an OE rider on the policy. Those things are absolute junk from the quality and fitment.  I can't tell you how many failures and lamps we warranty out. They are cheap and that's what some people want. Just understand what you're selling.
Don't know why we didn't think to use a DA. I have one laying in the shop, just collecting dust. Any particular brand clear coat you recommend? And are your guys spraying 1 coat, or multiple coats?
I was charging $147 and still dreaded selling the service.
Use a small 3" DA, it's easier to handle than the 5 or 6". We've used Krylon, or Rust Oleum. Doesn't really matter. It's whatever the hardware store had. Usually 2 coats.  Just don't use "frosted" clear...lol We're not particular fond of doing them either.
      The Weekly Blitz is brought to you by our friends over at Shop Marketing Pros. If you want to take your shop to the next level, you need great marketing. Shop Marketing Pros does top-tier marketing for top-tier shops. I’d like to give another shoutout to our sponsor, Shop Marketing Pros. They are the only marketing company I recommend, and they handle all of the marketing for my own shop as well. If you’re serious about growth, you need strategies that actually work: better websites, higher Google rankings, and ads that bring real customers through your doors. Visit ShopMarketingPros.com/chris to partner with a team that understands your business. Because every great shop deserves marketing that’s just as great. Check out their podcast here: https://autorepairmarketing.captivate.fm/ If you would like to join their private Facebook group go here: https://www.facebook.com/groups/autorepairmarketingmastermind
      In episode 205 of "The Weekly Blitz," host Chris Cotton delves into the themes of personal growth, overcoming guilt, and the pursuit of one's goals. Throughout the episode, Chris opens up about his own experiences, sharing the challenges and triumphs he faced while juggling multiple responsibilities. As a shop owner, Chris had to manage the day-to-day operations of his business, ensuring everything ran smoothly and efficiently. At the same time, he made the courageous decision to return to college, determined to complete his degree and fulfill a long-held aspiration.
      Chris discusses the delicate balance he had to maintain between his professional duties and academic commitments. He candidly talks about the guilt he initially felt for dedicating time to his studies, fearing it might detract from his business or family obligations. However, through this journey, Chris learned the critical importance of self-care and the necessity of prioritizing one's own dreams and aspirations. He encourages listeners to pursue their goals with determination and to not let guilt stand in the way of their personal development.
      Reflecting on his journey, Chris highlights the profound sense of fulfillment that comes from achieving personal goals. He notes how this accomplishment not only boosts self-esteem but also has a positive ripple effect on overall well-being, enhancing both personal and professional life. By sharing his story, Chris aims to inspire others to take bold steps towards their own dreams, reassuring them that it is possible to balance responsibilities while pursuing personal growth.
      The episode wraps up with a sponsorship mention for Shop Marketing Pros, a company that specializes in providing marketing solutions tailored specifically for auto repair shops. This partnership underscores the episode's focus on professional development and growth within the auto repair industry.
      Introduction to the Episode (00:00:00)
      Chris Cotton introduces the podcast and its purpose, highlighting its focus on auto repair business insights.
      Sponsorship Mention (00:00:59)
      Details about Shop Marketing Pros and their services for auto repair shops are discussed.
      Reflection on Vision 2025 (00:01:03)
      Chris shares his experience at the Vision 2025 event, noting the busy atmosphere among shop owners.
      The Importance of Self-Care (00:02:00)
      Discussion on the necessity of taking time for oneself as a shop owner without feeling guilty.
      Overcoming Guilt (00:03:04)
      Chris addresses the guilt shop owners often feel and the importance of prioritizing personal well-being.
      Personal Journey to Education (00:05:02)
      Chris reflects on his decision to return to college after many years, motivated by personal goals.
      Completion of Degrees (00:06:03)
      He shares the timeline of his and his daughter's graduation, emphasizing the significance of finishing what you start.
      Lessons in Persistence (00:08:26)
      Chris discusses the importance of completing tasks and setting an example for his daughter.
      Final Thoughts and Call to Action (00:10:30)
      Encouragement to pursue personal goals and a reminder of the podcast's sponsor, Shop Marketing Pros.
      chris autofixsos.com
      940-400-1008
      YouTube: https://bit.ly/3ClX0ae
      Email Chris: [email protected]
      Why Auto Shops Are DITCHING Aftermarket Parts in 2025?
