Hello Everybody,
We use Alldata Managment system and I'm trying to build packages using "Custom Jobs" then "Job Description". The problem is that it limits you to 255 characters which isn't nearly enough for most any job..
For example, I'm trying to make a custom job for a pre-purchase inspection but, again there isn't enough room to list everything we'd inspect during a prepurchase inspection..
Can anybody familiar with Alldata give me any hints on what I can do? How do you do it?
Thanks in Advance
I'm not using all data online
click shop jobs
click new
then it pops up the select new job items page
there are 5 tabs the far left one is notes
type what you want click add item
if you use up the space in that note add more notes
maybe brake the notes up as engine, suspension, interior and so on
You can try to add a second labor line to the job. That will give you more space to add description, if you filled the space in the initial labor line.
Thanks for the replies , but, what I'm trying to do is add a "Canned Job" a "Package" to our system that all we'll need to do is click on the job to print it on the invoice automatically. Meaning I know I can do it manually, but, there just has to be a way to have it automatically come up as a canned job.
Below for example, is a draft of our pre-purchase inspection. It is 725 characters too much to fit in a pre-packaged job. I've spent hours looking into this with Alldata and they seem bewildered. I'm assuming and hoping there are other Alldata users out here that can tell me how they do it.
Thanks Again
Perform Visual Maintenance Inspection of the following components:
Drive/ Serpentine Belts - Battery Cables - Air Filter (If easily Accessible) - Air Intake Tubes/Hoses- Cooling System Hoses, Rotate tires ( as needed), C.V. Axles- Boots, Brake Pad/Shoe Thickness ( front and rear) , Underhood Fluids (As Needed/ Possible), Note any Fluid Leaks, Shocks and Struts, Suspension Linkage, Steering Gear, Tire Condition and Tire Wear, Exhaust system, Wiper Blades, Note Fluid Leaks, Exterior lights, Test Battery, Note Timing Belt interval, Radiator, Transmission fluid (if applicable dip stick type only) , Note Transmission Operation,
Tire Condition, Dash Warning Lights, Inspect for Signs of Rust and or Major Collision Damage.
my bad i get my right and left mixed up. notes in on right side, passenger side i copied and pasted your words and it fit in to notes. then i added some labor time. i named it prepurchase inspection. In the description i put some like inspect costumer's potential new car. save it. grabed a random car from my list and add this generic job and saved as a pd but not sure how to up load the image. but it works.
You do not need all that on the invoice. Use a separate inspection sheet with tech notes and recommendations you can hand over with the invoice.
      Thanks to our Partners, Shop Boss, and 360 Payments Recorded at the 2024 Automotive Aftermarket Retailers of Ontario (AARO) Business Management and Lindertech Training Trade Show, Murray Voth explores the idea of transferable skills for automotive shop owners making the shift from technician to business owner. He highlights how their technical knowledge can be applied to efficiently use shop management software and offers strategies to overcome any intimidation they may feel. By adopting a structured approach to learning key performance indicators (KPIs) and generating business reports, shop owners can gain the confidence needed to manage their businesses. Voth encourages them to use their diagnostic abilities to analyze business metrics, ultimately improving their effectiveness in running their shops. Murray Voth, RPM Training. Listen to Murray’s previous episodes HERE. [email protected] Show Notes: Watch Full Video Episode Automotive Aftermarket Retailers of Ontario (AARO): https://www.aaro.ca/ Intimidation with Software (00:00:29) Shop Management Software Overview (00:02:08) Transferring Diagnostic Skills (00:03:36) Key Business Metrics (00:05:20)
      Thanks to our Partners, Shop Boss and 360 Payments Shop Boss – Shop Management Software built by shop owners for shop owners. It works the way you need it to, right out of the box. Find on the web at https://shopboss.net Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/             Click to go to the Podcast on Remarkable Results Radio
      'Our shop managers, our shop owners, they don't know what they have, and because they don't know what they have, they don't know how to use it to the fullest extent.' This episode is packed with valuable advice for shop owners who want to maximize their Shop Management System and ensure their business runs seamlessly and profitably. Learn More About: Maximizing Your SMS: Many shop owners underutilize their SMS, treating it merely as an invoicing tool. Inventory Control: Effective inventory management is crucial. Discover how simple tweaks can save you money and improve service efficiency. Labor Matrix: Track and analyze labor efficiency with ease. Implement strategies that can lead to increased profitability. Recommended Services: Tap into the maintenance market. Present recommended services effectively. Don't miss this engaging and informative discussion! Jon Luttrell and Ben Dexter, NAPA TRACS Show Notes
      A Better Road to Success: Navigating Your SMS and Customer Rapport [RR 945]: https://remarkableresults.biz/remarkable-results-radio-podcast/e945/ Common Issues with SMS (00:02:05) Widespread issues among shop owners regarding their lack of knowledge about shop management systems. Understanding Labor Matrix (00:02:30) The importance of understanding and utilizing the labor matrix feature in SMS. Realization of SMS Capabilities (00:03:17) Ben describes the moment when shop owners realize SMS can influence profitability beyond invoicing. Owner's Role in Learning SMS (00:05:15) Discussion on the necessity for shop owners to be knowledgeable about their SMS and not delegate responsibility. Absentee Ownership Challenges (00:06:25) The dangers of absentee ownership in effectively managing shop systems and ensuring accountability. In-Person Training Benefits (00:11:54) Ben highlights the advantages of in-person training for accommodating different learning styles. Key Features of NAPA TRACS (00:12:28) Ben discusses top features of NAPA TRACS that excite shop owners, including inventory control and labor matrices. Inventory Control Insights (00:13:25) Ben emphasizes the significance of proper inventory management in enhancing shop profitability. Proactive Inventory Management (00:16:02) Discussion on the importance of maintaining appropriate inventory levels based on market demand. Client Service Rep's Role (00:16:43) Jon discusses the value of having a knowledgeable client service representative to assist with inventory management. Choosing the Right SMS (00:18:58) Emphasizes the need for local representation in selecting and customizing shop management systems. Reflecting on 2023 (00:20:05) Encourages shop owners to assess their previous year and consider changes for improvement. Profitability and Productivity (00:21:12) Explores the relationship between profitability and productivity in shop management systems. Understanding Pricing and Labor (00:22:06) Discusses the importance of pricing strategies for parts and labor to increase shop profitability. Utilizing Parts Matrix (00:23:30) Introduction of parts matrix profiles to simplify pricing. Reporting and Accountability (00:25:01) Highlights the importance of reporting tools for tracking productivity and sales performance. Dashboards for Quick Insights (00:26:45) Describes the use of dashboards to visualize performance metrics and accountability. The Role of a Profit Coach (00:27:57) Stresses the necessity of having a profit coach for business accountability and growth. Templates for SMS (00:29:09) Discussion on the availability of templates for parts and labor to aid new users. User Control Over Features (00:30:57) Explains user flexibility in activating or deactivating features in the shop management system. Human Element in Pricing (00:32:02) Discusses balancing scientific pricing with human judgment in service pricing. Recommended Services (00:32:59) Focuses on effectively communicating recommended services to customers. Maintenance Awareness (00:35:41) Encourages understanding the necessity of regular maintenance for vehicle reliability and safety. Embracing SMS Tools (00:36:33) Concludes with the importance of actively using shop management systems for business success. The Importance of User Feedback (00:36:53) Discussion on how passionate users have guided the development of the application. Maximizing System Utilization (00:37:27) Encouragement for shop owners to explore and fully utilize their shop management systems. Commitment to Training (00:37:53) Emphasis on knowing the SMS for effective shop management. Acknowledgment of Sponsorship (00:38:18) Thanks to NAPA TRACS for sponsoring the podcast at an upcoming training event in North Carolina. ASTA EXPO: https://astaexpo.com/aste-classes/
      Thanks to our Partner, NAPA TRACS NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Thanks to our Partner, Auto-Fix Auto Shop Coaching Proven Auto Shop Coaching with Results. Over 61 Million in ROI with an Average ROI of 9x. Find Coach Chris Cotton at AutoFix Auto Shop Coaching on the Web at https://autoshopcoaching.com/ Thanks to our Partner, Today's Class Optimize training with Today's Class: In just 5 minutes daily, boost knowledge retention and improve team performance. Find Today's Class on the web at https://www.todaysclass.com/Connect with the Podcast: -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on X: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections
