Hello Everybody,
We use Alldata Managment system and I'm trying to build packages using "Custom Jobs" then "Job Description". The problem is that it limits you to 255 characters which isn't nearly enough for most any job..
For example, I'm trying to make a custom job for a pre-purchase inspection but, again there isn't enough room to list everything we'd inspect during a prepurchase inspection..
Can anybody familiar with Alldata give me any hints on what I can do? How do you do it?
Thanks in Advance
I'm not using all data online
click shop jobs
click new
then it pops up the select new job items page
there are 5 tabs the far left one is notes
type what you want click add item
if you use up the space in that note add more notes
maybe brake the notes up as engine, suspension, interior and so on
You can try to add a second labor line to the job. That will give you more space to add description, if you filled the space in the initial labor line.
Thanks for the replies , but, what I'm trying to do is add a "Canned Job" a "Package" to our system that all we'll need to do is click on the job to print it on the invoice automatically. Meaning I know I can do it manually, but, there just has to be a way to have it automatically come up as a canned job.
Below for example, is a draft of our pre-purchase inspection. It is 725 characters too much to fit in a pre-packaged job. I've spent hours looking into this with Alldata and they seem bewildered. I'm assuming and hoping there are other Alldata users out here that can tell me how they do it.
Thanks Again
Perform Visual Maintenance Inspection of the following components:
Drive/ Serpentine Belts - Battery Cables - Air Filter (If easily Accessible) - Air Intake Tubes/Hoses- Cooling System Hoses, Rotate tires ( as needed), C.V. Axles- Boots, Brake Pad/Shoe Thickness ( front and rear) , Underhood Fluids (As Needed/ Possible), Note any Fluid Leaks, Shocks and Struts, Suspension Linkage, Steering Gear, Tire Condition and Tire Wear, Exhaust system, Wiper Blades, Note Fluid Leaks, Exterior lights, Test Battery, Note Timing Belt interval, Radiator, Transmission fluid (if applicable dip stick type only) , Note Transmission Operation,
Tire Condition, Dash Warning Lights, Inspect for Signs of Rust and or Major Collision Damage.
my bad i get my right and left mixed up. notes in on right side, passenger side i copied and pasted your words and it fit in to notes. then i added some labor time. i named it prepurchase inspection. In the description i put some like inspect costumer's potential new car. save it. grabed a random car from my list and add this generic job and saved as a pd but not sure how to up load the image. but it works.
You do not need all that on the invoice. Use a separate inspection sheet with tech notes and recommendations you can hand over with the invoice.
      Early 2018 our host, Craig O’Neill attended multi-day training session by Dennis McCarron
      In this episode - Craig invites Dennis to highlight one of his favorite takeaways from that training.
      Of course - the takeaway is an acronym…
      A.P.A.C.
      Acknowledge
      Probe
      Answer
      Confirm
      APAC is a pragmatic model for solving problems that can be applied in nearly every walk of life.
      From taking an upset client and solving their problem - to taking a routine interaction and arriving at the right conclusions, Dennis explains how APAC is what happens, eventually, no matter what… it is just the most efficient way to accomplish what needs to happen anyway!
      You’ll want to carve out the time to hear Dennis and Craig go deeper into human behavior models and tackles topics such as trust, and engagement and understanding how we are always assessing the people we are serving how they are engaging their environments.
      Listeners will find that APAC is a pragmatic approach to communication in the shop and all walks of life…
      And you’ll find that our Word of the Day today also happens to be “Pragmatic”
      prag·mat·ic-/praɡˈmadik/adjective
      Dealing with things sensibly and realistically in a way that is based on practical rather than theoretical considerations.
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network In the fifth installment of the "Unstoppable Framework for Auto Shop Owners" series, Maryann Croce, a coach from Small Biz Vantage, shares her expertise on building resilience and effective planning for automotive professionals. Maryann emphasizes the importance of a resilient mindset, proactive planning, and continuous improvement. She offers practical tips, such as creating contingency plans and regularly assessing business processes. Maryann Croce, Small Biz Vantage. Maryann’s previous episodes HERE. Show Notes Watch Full Video Episode Unstoppable Framework for Auto Shop Owners Part 1: Core Values and Vision [RR 997]: https://remarkableresults.biz/remarkable-results-radio-podcast/e997/ Unstoppable Framework for Auto Shop Owners Part 2: Mastering Your Finances [RRR 1004]: https://remarkableresults.biz/remarkable-results-radio-podcast/e1004/ Unstoppable Framework for Auto Shop Owners Part 3: Optimize Processes and Empower Your Team [RR 1012]: https://remarkableresults.biz/remarkable-results-radio-podcast/e1012/ Unstoppable Framework for Auto Shop Owners Part 4: Stay Customer Focused and Flexible [RR 1020]: https://remarkableresults.biz/remarkable-results-radio-podcast/e1020/ Here is the downloadable worksheet link: https://bit.ly/4b0Qvtw Welcome Maryann Croce (00:00:00) Building a Resilient Mindset (00:02:34) Embracing a Growth Mindset (00:04:25) Continuous Improvement (00:11:11) Creating Contingency Plans (00:12:27) Planning for the Unexpected (00:16:33) Daily Practices for Building Resilience (18:32) Creating Daily Habits (19:08) Importance of a Support Network (20:17) Key Lessons from Previous Episodes (22:31) Growth Mindset and Contingency Planning (23:49) Emotional Awareness in Leadership (26:04) Practical Application in Business (27:00) Inclusivity in Learning (28:00) Conclusion of the Series (29:04)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
    • By marxautocenter
