I am wondering if anyone has any tips for organizing estimates. We use Alldata Manage and I know how to do the estimates in there, but there are many times a day that people call for a quick estimate for something and it doesn't seem worth the time to enter all their info into the system and do an official estimate in the program. But I still like to keep the estimates for a while in case they call back a couple of weeks later and want the work done.
Right now I have a folder with handwritten estimates in it, but going through it is a pain. I am thinking I might get a binder and put the estimates in the binder in some type of order. Not sure if it would be better to organize by name so if they tell me their name I can easily find the estimate - or by date of estimate so its easier to go through it every once in a while to clear out old ones that are taking up space.
Thoughts or suggestions?
I would use manage. The use of the matrix is well worth the extra work and results in higher profit. We don't estimate a job over the phone or walk in unless it's very common. We want to inspect the vehicle, provide prioritized estimates that show every single issue the vehicle has! This also allows you to keep up with deferred work. "Mr. Customer, we see last month we recommended *said service*, would you like us to include this work while the vehicle is in for service today?".
Edited by ncautoshop
I agree with ncautoshop to limit phone or walk in estimates except for common work. I use our shop management program for all estimates (except common work). The estimate is retained as a quote for that customer, for that car, until the job is completed or I manually clear it. I have the option of giving a customer a printed estimate, emailing the estimate or sending an estimate by text all within my shop management program (BayMaster). This works well, requires no hand written folder of papers and can be recalled in seconds at any time. Another advantage is that we have the occasional person who requests estimates but never has the work completed. Since all estimates remain available they start to accumulate indicating to us that this customer is a "tire kicker" and more than likely will not follow thru with the repairs. I sometimes have customers call and request an estimate and see that I had already completed a quote for the same work the month before. Big time saver at that time since the estimate is already completed, quick review and all done.
When someone who is not a client calls us for an estimate (other than tires or alignment), we use that opportunity to set an appointment for them to come in. We do not give price estimates over the phone because we have not seen the vehicle, checked, diagnosed, or tested it. If they set an appointment and show up, fine. If they don't set an appointment, that's fine too.
If they are a client, the same thing applies with a few exceptions.
I hand write out the estimate, complete with customer phone number, vin number and all with a date, I then take a picture of it and add it to the notes app on an iPad mini. Then if a customer calls months later it's a couple of key strokes in the search function.
I use Alldata and I understand what you are saying, don't worry getting their adress or last name just get their first name and phone number. Don't worry about their tag number either just get the yeah make ,model and engine size. Work the estimate n save it, you can also ask them if you can call them back with the estimate and do it on your own time so you don't mess up the estimate or feel in a rush since you have the person on the phone.
Why not just get the tag number, phone and name? Then you don't need to spend as much time on data entry as it puts the car in by vin.
For phone shoppers we get their first name and phone #. we use the date as a last name. the last name can always be change later. this way every so often i can delete names of costumes that never come in very easily. if it is a customer that doesn't state that they've been here before than when the come in for that service we just save the job as a shop job and than use that shop job on the existing car. I feel that this makes it easier to root out shopper from customer in our customer list. then just delete the unassigned cars and now we have an accurate list of what make, models we see here.
What is the point in wasting your time with a phone estimate? Are they sure they need said repair? Who told them? Did they self diagnose? If they did why don't they fix it themselves? If someone else diag'd why didn't they do the repair with them? How can they trust their diag was correct if they cant trust that person to do the work? What is it they are looking for? Best price? Best quality? How are they determining whether to use your services? Is it based solely on price? Is that they type of customer you want?
I can keep going but there goes the reason why we don't give random estimates. It is a colossal waste of time and if you really get down to the soup and nuts most of the people you are giving estimates to you probably wont see and if you are seeing them you are probably charging too little.
Estimates are good. Keep it quick, simple, and be sure to state its only an estimate. I'd get name, phone #, and car info. I wouldnt push for tag and vin. How many customers actually know this info upfront?? I don't want them to feel like they have to work just to get a quote... They're already frustrated by having to fix their car. The note pad method works if you don't get that many. Otherwise save it in your manage system as a quote as long as it's searchable by name later. Learning to give a QUICK estimate is the key. Definitely a good idea to try to get the diagnostic appointment to make sure the repair is needed. But nowadays with you tube, many folk try their own diagnostic. That's fine too. Give the estimate, do the work, when it doesn't solve issue, offer paid diagnostic for the 2nd time, and move forward. All in the presentation. Not all price shoppers are bottom feeders. Many have been to shops that have ripped them off so theyre apprehensible. Try for 60 seconds rough estimate and label it as such and keep it moving with a smile
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
      Craig O’Neill, welcomes his friend and communications expert, David Boyd, as our guest.  Listen up to hear the thoughtful conversation between David and Craig across a variety of topics and questions related to the phones skills of your staff, AI use in the world today, and the outlook for the future.
      A key question:  “Will the job of the service advisor still exist?”
      As AI solutions seem to become more and more sophisticated - the question has career advisors wondering this aloud.
      The conversation should be encouraging for anyone who takes their professional role as a service advisor seriously, and the future, according to David and Craig, appears bright.
      According to David, the service advisor is the person we should be empowering further, and developing, as this is the role focused on building relationships.
      The conversation draws on additional points related to what we learned during Covid and the real value of actual connection, as well as some of the pitfalls for what occurs when a productive technician is forced to answer phone calls.
      Listeners will walk away with some practical advice from this episode, and more clear vision for a coachable front counter that is focused on connecting!
      The WOTD Today:
      Affable
      Noun-
      Friendly - good natured - easy to talk to
      Email Craig O'Neill: [email protected] Watch Full Video Episode Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters
    • By marxautocenter
