Hello all,
After two years, Our shop would like to start servicing TPMS services lights preset on most vehicles we encounter at our facility. I can't even imagine how much income we lost from not thinking about this earlier.
What scanners do you use to scan\flash TPMS sensors and how much do you charge?
Thanks in advance for your thoughts and opinions.
Nick
Just yesterday I was using our Autel TS601 for the first time (I haven't worked in the shop in a long time, but were short handed right now). Absolutely love the thing! I replaced 2 sensors on a Lexus ES350 and it was such a breeze. Installed new sensors, walked around and scanned each sensor in the tire, plugged it in, and it automatically writes the sensor IDs to the car.
We've used it before to diagnose faulty sensors for other shops. The other guys in the shop had nothing but good things to say about it too.
It was included when we bought our Autel Maxisys pro
I'd say go with the top model. It's a one time purchase you're going to use for years. Spend the little extra so there are no regreta later on. What's the price difference?
You might want to check into the Wurth TPMS reader and their universal sensors. We are primarily a Euro shop, and we switched from OEM sensors to the Wurth ones, and we use their tool to read and register to the vehicle. They've saved a lot of time and money, and they work on everything from Audi to VW
I agree with Dave, the NAPA sensors worked out well for us using the NAPA tool and my Snap-On Solus Edge scanner when needed. Unfortunately all NAPA stores in our area changed over to CarQuest so we needed a new supplier. One of our wholesale tire suppliers had a special that included a free Smart Sensor Pro tool with the purchase of (8) Smart Sensors. So far the tool and sensors have worked great, they are clonable and have very good coverage. I had a few questions initially and their support is very good. Another bonus - updates are free for life. The Smart Sensor Pro has an OBDII connection useful not only when replacing sensors but also for TPMS resets post rotation which is required on many vehicles. In the rare case we use an OEM sensor then we use the Solus Edge to introduce the new Sensor (if required).
Our shop uses the TS401 to read the sensors. It will tell us which sensor is faulty (will not activate it if it is faulty) and will show the PSI & ID for each sensor that responds. The scanner is pretty good. Then to replace the sensor we use the clone tool from Napa which you use on their brand TPMS sensors. With that you type in the ID from the faulty sensor (usually printed on the sensor) and then type it in on the napa device and it writes it to the new sensor. All in, for both pieces of equipment we have $200 invested and have made that back many times over. Obviously it adds 1 other step since it is 2 different devices but its not much more time and doesn't require the high priced tools. Worse case if that fails, our Maxisys scanner will write the IDs as well.
I can't really compare the TS601 to other tools since I've only used this one. But what I absolutely love is not having to write down ID's anymore. You walk around the car and scan all the sensors wirelessly (It will let you pick if the car has 4 or 5 sensors). Say you find one bad or has a low battery (the 601 will tell you if a sensor is still working but has a low battery). After you replace that bad sensor, you walk around the car and scan all the sensors again. Plug the 601 tool into the OBD port, select write ID's, and it automatically writes all the new ID's to the car. You don't have to punch them in manually since it remembers all the ID's. It's also super handy because two more clicks, and it will write it to a '2nd set' if the car has the option for 2 sets of tires. This prevents someone accidently pressing the '2nd set' switch in the car and causing a tire light since no sensors are programmed.
Hopefully that wasn't confusing. Is it worth $750? I dunno, I have nothing else to compare it to. I do know I have no complaints so far with it. I bought mine as a package deal with the maxisys pro, so I got a pretty good deal I think.
If this helps any, when a car now comes in with a tire pressure light, I reach for the 601 instead of the tire pressure gauge. I walk around the car and in 30 seconds I know if it's just low tire pressure or a bad sensor.
      Thanks to our Partner, NAPA Auto Care Part 2 of the "Unstoppable" series, the episode focuses on "Mastering Your Finances." Maryann Croce emphasizes the importance of understanding financial statements, calculating profit margins, and managing cash flow. She shares practical advice on building financial reserves and separating personal and business finances. The conversation aims to empower shop owners with financial literacy, enabling them to make informed decisions and ensure business sustainability. Maryann, Small Biz Vantage. Maryann’s previous episodes HERE. Show Notes Watch Full Video Episode Unstoppable Framework for Auto Shop Owners Part 1: Core Values and Vision [RR 997]: https://remarkableresults.biz/remarkable-results-radio-podcast/e997/ Here is the link to the worksheet for Episode 2: Mastering Your Finances https://bit.ly/3BBCOnb Mastering Your Finances (00:01:19) Understanding Financials (00:02:10) Importance of Healthy Profits (00:03:24) Mastering Financial Dashboard (00:05:04) Calculating Profit Margins (00:07:02) Industry Benchmarking (00:09:11) Understanding True Profit (00:10:08) Cash Flow Management (00:12:42) Personal Story on Cash Flow (00:13:49) Invoicing Best Practices (00:17:51) Emotional Aspects of Money (00:19:45) Cash Flow Management (00:20:02) Expense Control Strategies (00:21:06) Personal vs. Business Accounts (00:22:16) Normalizing Profit and Loss Statements (00:22:18) Building Financial Reserves (00:24:21) Cash Reserve Calculation (00:25:36) Strategic Decision-Making (00:26:28) Financial Literacy Development (00:28:45) Learning Financial Concepts (00:30:09) Building Cash Flow Confidence (00:31:20) Encouragement to Seek Help (00:32:21)
      Thanks to our Partner, NAPA Auto Care Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
