Hello all,
After two years, Our shop would like to start servicing TPMS services lights preset on most vehicles we encounter at our facility. I can't even imagine how much income we lost from not thinking about this earlier.
What scanners do you use to scan\flash TPMS sensors and how much do you charge?
Thanks in advance for your thoughts and opinions.
Nick
Just yesterday I was using our Autel TS601 for the first time (I haven't worked in the shop in a long time, but were short handed right now). Absolutely love the thing! I replaced 2 sensors on a Lexus ES350 and it was such a breeze. Installed new sensors, walked around and scanned each sensor in the tire, plugged it in, and it automatically writes the sensor IDs to the car.
We've used it before to diagnose faulty sensors for other shops. The other guys in the shop had nothing but good things to say about it too.
It was included when we bought our Autel Maxisys pro
I'd say go with the top model. It's a one time purchase you're going to use for years. Spend the little extra so there are no regreta later on. What's the price difference?
You might want to check into the Wurth TPMS reader and their universal sensors. We are primarily a Euro shop, and we switched from OEM sensors to the Wurth ones, and we use their tool to read and register to the vehicle. They've saved a lot of time and money, and they work on everything from Audi to VW
I agree with Dave, the NAPA sensors worked out well for us using the NAPA tool and my Snap-On Solus Edge scanner when needed. Unfortunately all NAPA stores in our area changed over to CarQuest so we needed a new supplier. One of our wholesale tire suppliers had a special that included a free Smart Sensor Pro tool with the purchase of (8) Smart Sensors. So far the tool and sensors have worked great, they are clonable and have very good coverage. I had a few questions initially and their support is very good. Another bonus - updates are free for life. The Smart Sensor Pro has an OBDII connection useful not only when replacing sensors but also for TPMS resets post rotation which is required on many vehicles. In the rare case we use an OEM sensor then we use the Solus Edge to introduce the new Sensor (if required).
Our shop uses the TS401 to read the sensors. It will tell us which sensor is faulty (will not activate it if it is faulty) and will show the PSI & ID for each sensor that responds. The scanner is pretty good. Then to replace the sensor we use the clone tool from Napa which you use on their brand TPMS sensors. With that you type in the ID from the faulty sensor (usually printed on the sensor) and then type it in on the napa device and it writes it to the new sensor. All in, for both pieces of equipment we have $200 invested and have made that back many times over. Obviously it adds 1 other step since it is 2 different devices but its not much more time and doesn't require the high priced tools. Worse case if that fails, our Maxisys scanner will write the IDs as well.
I can't really compare the TS601 to other tools since I've only used this one. But what I absolutely love is not having to write down ID's anymore. You walk around the car and scan all the sensors wirelessly (It will let you pick if the car has 4 or 5 sensors). Say you find one bad or has a low battery (the 601 will tell you if a sensor is still working but has a low battery). After you replace that bad sensor, you walk around the car and scan all the sensors again. Plug the 601 tool into the OBD port, select write ID's, and it automatically writes all the new ID's to the car. You don't have to punch them in manually since it remembers all the ID's. It's also super handy because two more clicks, and it will write it to a '2nd set' if the car has the option for 2 sets of tires. This prevents someone accidently pressing the '2nd set' switch in the car and causing a tire light since no sensors are programmed.
Hopefully that wasn't confusing. Is it worth $750? I dunno, I have nothing else to compare it to. I do know I have no complaints so far with it. I bought mine as a package deal with the maxisys pro, so I got a pretty good deal I think.
If this helps any, when a car now comes in with a tire pressure light, I reach for the 601 instead of the tire pressure gauge. I walk around the car and in 30 seconds I know if it's just low tire pressure or a bad sensor.
      Introduction to the Podcast (00:00:01)  The podcast begins with a welcome message from the host, Brian Walker. Guest Introduction (00:00:10)  Brian introduces co-host Kim and guest Doug DeLuca, owner of Boca Auto Fix. Overview of Boca Auto Fix (00:00:51)  Doug shares details about his auto repair shop, including its location and age. Hiring an Apprentice (00:01:09)  Doug discusses the recent hiring of an apprentice and the journey leading to this decision. Challenges in Hiring (00:02:13)  The speakers reflect on the difficulties shop owners face in finding and hiring young talent. Marketing Journey Begins (00:03:02)  Discussion shifts to Doug's initial marketing efforts and his involvement in content creation. Background in Technology (00:04:07)  Doug explains his previous technology background and how it influenced his approach to marketing. Learning SEO and Marketing (00:04:45)  Doug describes his self-taught journey in SEO and digital marketing after opening his shop. Realizing Marketing Needs (00:06:14)  Doug reflects on his initial assumptions about marketing and the reality of attracting customers. Understanding SEO Basics (00:08:09)  Doug shares his insights on SEO and the learning process involved in mastering it. Frameworks in Marketing (00:10:25)  The conversation explores the use of frameworks in both auto repair and marketing strategies. Adopting "They Ask, You Answer" (00:11:23)  Doug discusses his experience with the "They Ask, You Answer" philosophy in content creation. Writing Blogs for Customer Engagement (00:12:21)  Doug explains how he uses customer inquiries to create relevant blog content for his shop. Experience at a Quick Lube (00:13:29)  Doug shares his firsthand experience at a quick lube to highlight differences in service quality. Experience Comparison (00:14:06) Doug shares his experience of visiting a competitor's shop to understand customer perception and service quality. Proactive Client Advocacy (00:14:57) The team discusses the importance of guiding potential clients to the right service provider based on their needs. Sponsorship and Marketing Tools (00:16:13) Brian introduces RepairPal, highlighting its benefits for attracting new customers and building trust. Customer Loyalty Apps (00:17:51) Brian discusses the advantages of using App Fueled to create customer loyalty programs for auto repair shops. Incognito Visits (00:18:20) Doug talks about visiting a competitor's shop incognito to gain insights without revealing their identity. Collaboration Over Competition (00:19:09) The speakers explore the idea of referring customers to other shops and building relationships in the industry. Challenging Competition Norms (00:20:20) Brian reflects on inviting competitors to the podcast, emphasizing collaboration over traditional competition. Marketing Involvement (00:22:42) Doug explains the ad hoc nature of their marketing efforts and the role of social media in their strategy. Community Involvement (00:27:41) Doug shares their family's volunteer work and how it integrates with their business's social media presence. Engaging the College Market (00:28:51) Doug discusses how 30% of his clients are college students and their marketing strategies. Collaborating with Local Professors (00:31:18) Doug shares his experience working with a marketing professor for student analysis of his business. Challenges of Seasonal Demand (00:32:24) Discussion on the impact of seasonal changes on business demand and local marketing efforts. Starting with Marketing (00:34:02) Doug advises new shop owners to listen to podcasts and conduct online research for marketing. SEO as a Long-Term Strategy (00:35:08) Doug explains the importance of SEO and its long-term benefits for business growth. Understanding Competition (00:36:44) Doug emphasizes the need to analyze competition and not assume marketing strategies will work universally. The Importance of Data (00:39:08) Doug highlights the role of data in assessing marketing effectiveness and making informed decisions. Nuances of Market Dynamics (00:41:14) Discussion on how geographical and seasonal factors affect marketing strategies in auto repair. Client Avatar and Marketing Alignment (00:42:13) Doug explains the significance of understanding the ideal customer for effective marketing strategies.  Overcoming Diagnostic Fee Challenges (00:43:09) Discussion on how Doug has adjusted his approach to diagnostic fees to improve customer conversion. The Importance of Evaluation Fees (00:43:40) Discussion on the role of evaluation fees and their impact on shop maturity. Improving Customer Communication (00:44:09)  Insights on enhancing customer explanations regarding services and processes. Coaching and Competitive Analysis (00:45:03)  How coaching helped refine service policies and improve customer relations. Content Creation and Marketing Strategy (00:46:32)  The significance of creating content for customer engagement and marketing. Duck Duck Jeep Initiative (00:47:05)  Fun marketing strategy involving ducks to engage with the local Jeep community. Value of Customer Feedback (00:48:46)  Importance of understanding customer inquiries and improving service based on feedback. Contact Information for Doug DeLuca (00:49:29)   Doug shares how listeners can reach him for further inquiries.
