Just over the wire today is all nys inspection stations will be required to test window tint as part of the inspection starting Jan 1. Anything blocking more than 30% light fails. More equipment to buy, more time, not to mention how does the average shop deal with removing window tint? I'm not opposed to keeping police safe from thugs with limo tint on the drivers window but I feel that's the police's job not the "safety/emissions" inspector.
we have had to measure tint for a long time here in MD. Anything below 35% has to go.. removal is messy but not to bad.. just pull off the film and use a solution of dish soap and water saturate the window let it sit for a few minutes keeping it very wet . With a razor blade remove the glue comes off pretty easily this way.(I use a plastic blade for the rear window and am very gentle over the defroster). After all the glue is activated with a soap solution so removal is the same.. just be careful around the defrost lines in the rear glass. As far as the equipment I recall it not being to expensive two hand held monitors one on each side of the glass very simple takes half a second to do. I usually charge an hours labor to remove all the tint. Here in Md. all AS3 windows can have tint in fact they can be blacked out, you only find this on suv's .
In NC we have to check aftermarket tinting also. It is the first item we check. If it is too dark, we inform the customer and let the customer deal with taking it off. Most of the time we send them to a local stereo shop that does a good job tinting for removal.
Been there, done that. Be prepared for angry customers and learn how to handle them. We do not offer removing the window tinting... in the past we have had customers accuse use of "scratching" the glass, leaving the adhesive behind, etc... Not worth the labor we charged.
Follow the law regardless of the outcome of loosing a customer.
We actually install and remove window film. We use a chemical that helps dissolve the adhesive left behind after removal of window film. You should be aware though that some film does not come off in one sheet and will crumble/break as you are removing it. This extends the time to remove the film by HOURS. We let customers know when this happens as you can tell almost immediately and charge appropriately.....
Yeah, saw this when they passed the law back in June, took Cuomo this long to sign it. We only need to check the front two windows and the windshield, which means we need a two piece unit. Just started shopping for them. Looks like there are only a few available.
For you guys that have had to do this for a while, any suggestions on what measurement tool to buy, or maybe better, which one to avoid? So far the state hasn't issued any equipment guidelines, just the spec (at least 70% light transmittance), which has been the regulation for ages, just not enforced by Inspection stations. The vast majority of cars won't need to be checked as you can visually see they don't have tint, so I don't see the tool being used very often. you just need it when you need it.
Since I already loose about $10 for each inspection we do how many do we need to do to make up for the $200 tool I need to buy :rolleyes:
Unbelievable we are suppose to perform this law with no increase in fees but that is Albany. Buy a cheap tester so you can show it to the inspector & carry on.
Charge for removal to the few cars we see with dark tint & recoup the cost.
Dave
Unbelievably the first inspection of this year the car had dark tint that would not pass the meter test.
I called the customer & she said the police had told her the same. I charged $150.00 to remove all side window tint.
We needed to razor blade the sticky glue off, it took about 2 hours total. Not a bad job but I will charge more next time.
Dave
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Recorded at the 45th annual Mobile Air Climate Systems Conference (MACS 2025) in Orlando, Florida, Rob Bollinger shares the unique story of his third-generation family business, emphasizing their commitment to personal service and the legacy of his grandfather, who invented the overflow bottle system. The discussion also touches upon industry trends, the challenges of price competition, the evolution of AC systems with electric vehicles, and Bollinger's future plans for the business. Rob Bollinger, ABC Radiator, Baltimore, MD. https://www.facebook.com/abcradiator401 Show Notes Watch Full Video Episode MACS Training Event & Trade Show: https://macsmobileairclimate.org/ National Automotive Service Task Force (NASTF): https://wp.nastf.org/ Koura: https://www.kouraglobal.com/ Honeywell: https://www.honeywell.com/us/en Introduction to MAC Conference (00:00:00) Guest Introduction: Rob Bollinger (00:02:17) Rob's Family Business Legacy (00:02:52) Personal Touch in Deliveries (00:03:52) Customer Engagement During Deliveries (00:04:30) Rob's Background in the Business (00:06:08) Regrets About Family Business (00:06:22) Coolant Reservoir Bottle Invention (00:07:40) Patenting the Invention (00:08:25) Legacy of the Invention (00:09:48) Cash vs. Cashless Transactions (00:10:05) Honesty in Business (00:15:46) Future of Specialty Shops (00:16:20) Customer Outreach (00:16:30) Changes in Radiator Industry (00:16:54) Hiring Challenges (00:18:11) Golfing and Business Balance (00:18:39) AC Industry Challenges (00:20:10) Leak Detection Methods (00:20:57) Future Plans (00:21:50) Real Estate and Business Stability (00:22:28) Family Support (00:23:33) Training and Industry Updates (00:24:26) Vendor Interaction at Conferences (00:25:08) AI Repair Discussion (00:25:55) Reflection on the Conversation (00:26:09)
