Shock/Strut sales...
Go to solution Solved by alfredauto,
Looking at my year to year sales comparison. We're up 2% from last year overall but I'm down in two areas - Fluid Flush/Maintenance and Shocks/Struts. I know why we're down on the maintenance services and that is being addressed. What I'm asking for is thoughts on how we might increase sales on shocks/struts.
I'm not comfortable recommending them to customers simply based on miles. If we see leakage we show customers and recommend replacing. If we see abnormal tire wear we show our customers and recommend them. But outside of damage or tire wear are there any tests (aside from test drives and bouncing the vehicle) that can reveal wear? It seems there should be some tool or method to measure what the pressure within the shock/strut is producing and where it should ideally be. I've asked Technicians and so far no one has any ideas.
Perhaps designing a tool to test out shocks/struts...Thanks for any input!
I remember a tool for shocks many years ago. Late 70s or early 80s. It was a gauge that attached to the fender by a magnet. You jounced the vehicle and it would measure the oscillations up and down and pass/fail the unit. Problem is it wouldn't work for struts because of the way strut/spring assembly is engineered.
The only "test" I know of is how the unit reacts on a test drive.
Obviously it's easy to recommend a leaking, bent, or obviously weak unit for replacement. But don't discount a "soft" recommendation based on mileage. We start to recommend replacement at 80mo/80k miles. Studies have shown that ride, braking, and tire wear can all be improved by replacing oem units above a certain mileage.
Edited by tyrguy
Curious as to how many shops around here are using 'complete strut assemblies' instead of replacing just the strut itself. Anybody have feedback on these?
As far as struts go, we ALWAYS use "Quik Struts" when available. We tell the client that we are replacing the entire assembly with strut, coil spring, mount, and bearing, and that it will restore original ride height and ride, brake better, and handle better. Once we complete the installation we perform a 4-corner alignment so that it drives properly and gives the utmost in tire life.
We definitely sell the sizzle more than we sell the steak, and we install a lot of strut assemblies.
Hi-Gear
Hi-Gear
We do likewise, and here is some background into the sale process.
1. Profile your customer, are they the type of customer that keeps their car well maintained? Would they benefit from keeping the car for a couple more years? These are excellent candidates.
2. Are they emotionally attached to their vehicle?
3. Is the car sound enough structurally to accept a new suspension, for example a rusted out 2003 Maxima may not be worth the investment for the customer.
4. Are the other suspension components good enough to to avoid comeback complains, e.i, are the control arm bushings sturdy, anti-swaybar links and bushings not excessively worn, tie rods and ball joins at an acceptable condition etc.
We set the expectations, and then once the car is done and it drives and feels like a new car, customers are often extremely happy. This is one of those jobs where they can actually feel they are getting their money's worth.
-Harry
Edited by HarrytheCarGeek
-Harry
Harry, That's a great sales process list, and I'm going to print it and post it and start using it Monday!! Thank you,
Hi-Gear
So last month my shop sold a total of 45 sets or 90 shocks and struts. I personally sold aproximately 30 sets. We generally start talking to customers about them at 70K miles. They key with this is consistency and a understanding of why they should be replaced. Shocks should be replaced not because of a bouncy ride. The job or function of a shock or strut is to hold or push a tire to the ground after hitting a bump. This is not something that can be replicated or measured in a shop setting. Ride control replacement is a preventative maintenance repair. It should be done before problems arise. If you wait till after the problem arises you are actually doing your customers a disservice. As a car goes down the road the piston articulates thousands of times every minute. The internal valves wear out and the fluid breaks down due to heat and pressure. Seals on modern struts and shocks do not usually leak. This is an outdated sales technique. Seals on modern shocks and struts can handle much more pressure and tend to last much longer than the useful life of the shock or strut. I typically get a 50% margin on the parts and charge a flat fee for installation. If you are trying to sell shocks and struts at book time you are probably pricing yourself out of the market. You should call a few local shops near buy you and see what they are charging then structure a system that works based on your demographic. Where I work our labor rate is $97.16 an hour. We charge one and a half hours to install a set of struts a half hour to install a set of shocks and one hour to install a set of quick struts. This may seem low however, this should be more of a gross prophit sale than a margin sale.
A set would be 4 units. A pair would be 2 units. I'm assuming what you are referring to as a set is only 2? Also I don't understand your last sentence.
  • Solution
We charge book time to install struts. I can't justify a flat price when some take 20 mins and some 3-4 hours. We do quick struts or other brands complete units, it's better for the customer. In the rust belt 99% of the time the strut mounts and springs are shot anyway.
Really appreciate the forum replies and have begun to implement the sales process into maintenance sales first. Explained to my team that we need to be cognizant of the of mileage and to check off OEM when they're high mileage OEM. My Service Manager and myself will then begin the process of selling and informing our customers on the benefits to allow them the time to think it over and budget. It's a pipeline that continually needs filled.
My shop does a great job at repairing broken parts and fixing poor running vehicles. We do a poor job of maintenance sales and it reflects as such.
Read through the whole post- I like the idea of quick struts as well for obvious reasons. Problem seems to be that most part places do not have the modular assemblies in stock and it is hard to get. Who do you guys use as suppliers? Being able to get parts fast seems like the best way to sell as the job itself would not take long at all
  On 12/7/2016 at 2:47 PM, xrac said:
NAPA, Advance, OReilly, and two independents all sell Monroe (our ride control product of choice) in this market. We can usually find them if they are available. Loaded struts are only available for the more popular vehicles.
I ordered two struts, mounts, and rear shocks for a 2007 Kia Sedona today for tomorrow morning. Napa was 1st call: none available for tomorrow. O-R 2nd call: available but more than Advance. Advance: ordered for tomorrow and had best price. Monroe is my first choice also. I use some KYB with good results. I used some Chinese quick struts 3 times. ** !st, last and only ** for total of 3. Bad ride and made noise. You could look at them at they looked sh--ty.
Autozone/napa/advance/parts plus all stock complete units. Subaru/Kia/Toyota quick struts come from the Internet, nobody has them locally. It's much better for everyone to install a complete strut. We just had to build some for a Suzuki the cost was very high, but nobody had any complete.
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Recorded at the Institute Summit, Mike Simard dives into the challenges of recruiting and developing talent, especially in a unique setting like Alaska. He shares his innovative strategy of acquiring lube centers as entry points for new team members and highlights the critical role of strong company culture and leadership. Mike also emphasizes the importance of building the right team, balancing the visionary and integrator roles, and the need to continuously adapt in the ever-evolving automotive industry.
      Mike Simard, Simard Automotive, Alaska
      Show Notes Watch Full Video Episode The Institute of Automotive Business Excellence: https://www.wearetheinstitute.com/ Mike Simard's Background (00:00:00) Acquisition of Lube Centers (00:02:10) Energy and Problem-Solving (00:02:43) Vision for Training Talent (00:03:41) Geographic Logistics (00:05:12) Talent Development and Apprenticeship (00:05:41) Industry Comparison (00:06:32) Recruitment Challenges (00:09:04) Relocation and Recruitment Process (00:12:31) Motivation for Policy Writing (00:16:03) Understanding Unique Selling Points (00:18:05) Building a Strong Team (00:19:20) Learning from Coaches (00:21:52) Delegating Responsibilities (00:22:30) Building Company Culture (00:25:47) Understanding the 'Why' (00:27:09) Finding the Right People (00:28:34) Balancing Inner Voices (00:30:04) Breaking Barriers in the Industry (00:30:35)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
      Check out their podcast here: https://autorepairmarketing.captivate.fm/ If you would like to join their private Facebook group go here: https://www.facebook.com/groups/autorepairmarketingmastermindIn
      In this episode of "The Weekly Blitz," host Chris Cotton is joined by special guests Caroline Legrone and Kim Walker from Shop Marketing Pros to delve into the critical necessity of having a robust marketing plan for auto repair shops. The discussion centers around the pivotal role that a well-structured marketing strategy plays in the success and sustainability of these businesses.
      Chris, Caroline, and Kim explore the multifaceted aspects of marketing planning, emphasizing the importance of leveraging historical data to gain insights into the business's performance over time. By analyzing this data, shop owners can pinpoint slow periods and develop proactive marketing strategies that align with local events and seasonal trends, thereby optimizing their outreach efforts.
      Caroline Legrone underscores the significance of understanding past performance metrics, which can provide invaluable information for future planning. She explains how historical data can reveal patterns and trends that are crucial for making informed marketing decisions. This approach not only helps in identifying potential challenges but also in capitalizing on opportunities that may arise.
      Kim Walker, on the other hand, offers practical insights into the creation of a comprehensive marketing calendar. She shares her expertise on how to systematically plan marketing activities throughout the year, ensuring that the shop remains visible and engaged with the community. Kim's advice includes tips on scheduling promotions, aligning campaigns with local happenings, and maintaining a consistent presence across various marketing channels.
      Throughout the episode, the conversation is geared towards empowering shop owners to take control of their marketing efforts. By doing so, they can ensure sustained growth and foster stronger community engagement, even during traditionally slow periods. The episode serves as a call to action for auto repair shop owners to prioritize their marketing strategies, highlighting the long-term benefits of a well-executed plan.
      Introduction and Importance of Marketing (00:00:09)
      Chris Cotton introduces the episode and emphasizes the need for a marketing plan in auto repair businesses.
      Guest Introductions (00:01:11)
      Chris welcomes Caroline Legrone and Kim Walker from Shop Marketing Pros to the podcast.
      Discussion on Car Count Issues (00:01:48)
      Chris expresses concern over shop owners complaining about low car counts and the lack of planning.
      Identifying Seasonal Trends (00:02:32)
      Kim discusses common excuses for slow periods and the importance of recognizing seasonal trends.
      Understanding the Marketing Calendar (00:04:23)
      Caroline explains the significance of analyzing past performance to create an effective marketing calendar.
      Proactive Marketing Strategies (00:06:11)
      Kim shares insights on developing marketing plans based on historical data and identifying slow periods.
      Creative Marketing Solutions (00:07:25)
      Kim describes a unique marketing strategy developed around the local state fair to attract customers.
      Importance of Planning Ahead (00:09:27)
      Kim emphasizes the necessity of proactive planning rather than reacting to slow days.
      Timing for Event Promotions (00:12:30)
      Discussion on how far in advance to plan marketing strategies for events like the state fair.
      Community Calendar Considerations (00:14:09)
      Caroline advises checking community calendars to align marketing efforts with local events.
      Adjusting Marketing Budgets (00:16:19)
      Kim discusses the importance of reallocating marketing budgets based on seasonal trends.
      Applicability to Different Locations (00:16:27)
      Chris challenges the notion that marketing strategies are only relevant to local events, encouraging broader application.
      Yearly Planning for Marketing (00:17:09)
      Caroline stresses the importance of yearly planning for marketing strategies, even if starting late.
      Setting Holiday Schedules (00:18:49)
      Chris shares his approach to planning marketing around holiday closures as a starting point for the year.
      Here are the extracted timestamps and their corresponding titles from the podcast episode transcription segment:
      Importance of Planning (00:19:14)
      Chris emphasizes the need for shop owners to have a structured marketing plan.
      Blocking Time for Planning (00:19:40)
      Kim advises shop owners to set aside undistracted time in October for planning.
      Using a Big Calendar (00:20:17)
      Kim suggests using a large calendar to visualize important dates and events affecting marketing.
      Analyzing Performance Data (00:22:25)
      Kim discusses breaking down historical data to identify busy and slow times for better planning.
      Setting Realistic Goals (00:24:20)
      Caroline stresses the importance of setting achievable marketing goals based on past performance.
      Understanding Marketing Budgets (00:26:17)
      Kim explains how to determine an appropriate marketing budget based on desired growth.
      Plan with the Pros Conference (00:28:49)
      Caroline introduces the "Plan with the Pros" event aimed at helping shop owners create marketing plans.
      Event Success and Expansion (00:31:01)
      Kim shares the success of last year's event and plans for expanding this year's attendance.
      Facebook Group for Marketing Support (00:33:15)
      Caroline details the Auto Repair Marketing Mastermind group for shop owners to connect and share insights.
      Final Thoughts on Marketing (00:37:02)
      Caroline encourages shop owners to create marketing calendars and utilize available resources for success.
      Do It Scared (00:37:51)
      Encouragement to start marketing despite fears of making mistakes or not knowing how to begin.
      Getting Started (00:38:11)
      Emphasis on taking action; "done is better than perfect" and scheduling time away from the shop.
      Perspective on Fear (00:38:22)
      Discussion on the urgency of creating a marketing calendar to avoid business decline.
      Final Thoughts and Thanks (00:38:41)
      Closing remarks and encouragement to utilize marketing pros for effective growth strategies.
      Sponsorship Shout-Out (00:39:11)
      Promotion of Shop Marketing Pros as the recommended marketing partner for auto repair businesses.
      Closing Remarks (00:39:11)
      Encouragement to maintain a positive mindset and a farewell from Coach Chris Cotton.
