We have been getting by without any type of smoke machine. Now with the small leak codes its become a challenge. What smoke machine does anyone recommend? What features are important?
I have an older snapon smoke machine I got a good used deal on from the snapon truck. Has to blow smoke out a hose. Got mine a year ago and can't believe how often I use it. Intake leaks, exhaust leaks, gas tank leaks on small engine tanks. And of course, evaporated leaks. Could never go back to not having one.
Sent from my SM-N920V using Tapatalk
Re: Smoke machines. We make a lotta money with our smoke machine. I don't remember what brand it is, because to me they're all the same. They make smoke and it flows into the system you're checking, and wherever it comes out is where you put the fix!!
When a car comes in with the "service engine" light on, and we read an evap leak, we explain that we need to hook up the smoke machine to the car, and it's $89.95 to smoke it.
Cha-Ching$$
Hi-Gear
For the record is difficult to accurately diagnose evap codes without it. The other uses like lean codes, wind inside the car all are super useful. Had a 1995 Buick with lean codes. Thought since it was old it was gna be easy to check for vac leaks.... Car spray the hoses. We'll after chasing my tail I put the smoke machine to use. 3 tiny hoses were cracked.... Fixed in 5 minutes once bought some more hose. In conclusion, this isn't just for new cars, it's for anybody who is SERIOUS about diagnostic and accuracy!
I use a Blue Point machine I bought a few years ago. It has worked grate and comes with some dye and a black light to make small leaks a little easer to find. It was around $800 from the Snap-on guy.
I have the cheaper snapon, it was $1300 or so. Before that I had a DIY machine for about 2 years. Before that I would fill the evap systems with 1.5psi of air and use soapy water to find leaks. Both worked, but the snapon is much easier.
Whatever smoke machine you get I would suggest you charge a separate fee for that test alone or package it together with a series of tests. For instance we package a smoke test into our level 1 diag which comes out to $150 before tax and fees. We used to charge $99-119 alone for a smoke test but we have since developed a tiered system for our diag process which makes us more profitable, streamlines the process, and has much more detailed explanation of all the tests and procedures we are doing which equates to value for our clients.
We have both an OTC smoke machine (which I'd like to upgrade) for our regular smoke tests and also a high PSI smoke machine by redline for boost leaks.
Edited by mspecperformance
A little off topic but how do you structure your diagnostic tiers? I need to find a better way to bill diagnostic time, especially a way to give the customer an idea of what they are in for before the job starts. Currently we bill most diagnostic fees hourly and tell the customer they should be prepared for at least an hour of time. I'm sure there is a better way though.
As for a smoke machine, get one, who cars what brand. I can't imagine getting by without one. We have an OTC and it gets used nearly every day. To be safe you should get a nitrogen generator or a smoke machine that has one built in. Its technically dangerous to pump a fuel tank full of compressed air. Most modern cars have pump modules so the pump is never exposed to air but if you try it on something old there is a chance for explosion if you're not using nitrogen. I use the machine to find intake air leaks on metered air systems. Probably the #1 cause of fuel trims being long.
Ours is a vacutech 2000e, same one in the Toyota dealer. $1500 or so and works great. One tank of fluid lasts literally years using it daily. We use it for everything.
Agree with Redline. Yes, we fix cars & make a ton of money with it. Use it almost every day.
Start at 1.0 labor charge for smoke test plus for the initial code check then go from there for repairs.
Dave
You really need a smoke machine! not sure how you get by without one?
But if you are looking to evap testing take a look at this.
Hello Everyone,
If you are able to buy any sort of smoke machine, you are lucky because most people use a cigarette or anything to produce smoke. If you do have the extra hundred bucks to spend than you can find great deals on craigslist or any classified website. My smoke machine is simple and does the job to catch for emission leaks. Most cars have an area were you can connect the hose. In most cases it's located under the hood and covered with a green top screwed on.
Good Luck!
Erik Gonzalez
EEE Auto Repair in Tracy
24/7 Roadside Assistance & Towing in Tracy
      Thanks to our Partners, NAPA TRACS, and Today's Class Recorded at the 45th annual Mobile Air Climate Systems Conference (MACS 2025) in Orlando, Florida, the focus is on the critical topic of leak detection in automotive air conditioning systems. Two main leak detection methods are compared: dye leak detection, which uses fluorescent dyes and UV lights for visual identification, and electronic leak detection (ELD), which uses sensors to detect refrigerants. The discussion also covers the compatibility of these methods with various refrigerants, including those used in electric vehicles, and explores the advantages and disadvantages of each approach. John Godden, Production Operations Manager, Spectronics Corporation Matt Farel, Business Development- Service Tools, Inficon Show Notes Watch Full Video Episode MACS Training Event & Trade Show: https://macsmobileairclimate.org/ National Automotive Service Task Force (NASTF): https://wp.nastf.org/ Koura: https://www.kouraglobal.com/ Honeywell: https://www.honeywell.com/us/en Leak Detection Discussion (00:00:00) Importance of Air Conditioning (00:02:12) Heat Pump Systems (00:03:03) Complementary Technologies (00:04:09) Tracers in Manufacturing (00:04:44) Visual vs. Electronic Detection (00:05:33) Safety of Refrigerants (00:07:50) Importance of UV Light (00:08:21) Using Multiple Detection Methods (00:09:33) Verifying Repairs (00:10:52) Preference in Detection Methods (00:12:06) Market Trends in Leak Detection (00:13:00) The Importance of Shop Management Systems (00:13:53) Training and Customization of Napa Trax (00:14:33) Leak Detection Methodologies (00:15:40) Dye Compatibility with Refrigerants (00:16:20) Tracer Gas Leak Detection (00:17:54) EVs and Leak Detection Challenges (00:19:45) Advancements in Leak Detector Technology (00:21:52) New Developments in Dye Products (00:23:38) Transition to Natural Refrigerants (00:24:29)
      Thanks to our Partner, NAPA TRACS NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Thanks to our Partner, Today's Class Optimize training with Today's Class: In just 5 minutes daily, boost knowledge retention and improve team performance. Find Today's Class on the web at https://www.todaysclass.com/ Connect with the Podcast: -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on X: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/
      Podcasting isn’t about having all the answers—it’s about sharing the journey. In this episode, we tackle the hard truth: Podcast hosts don’t have it all figured out. From the insecurities of giving advice to the challenges of staying authentic, we explore what it really means to put yourself out there as a host.
      You’ll discover how to sift through advice, find what works for you, and embrace the imperfect process of learning and leading. If you’ve ever felt like you don’t have it all together, this episode will remind you—you’re not alone.
      Listen in for an honest discussion about navigating the auto repair industry, embracing authenticity, and growing through the challenges of imperfection!
      RepairPal.com/shops
      https://shopmarketingpros.com/ep-118-doing-video-every-day-for-a-month/ - Episode 118 VEDA
      https://agencyanalytics.com/blog/how-profit-first-helped-this-agency-scale - Profit First Was the Key to Our Agency’s Financial Transformation
      https://shopmarketingpros.com/ep-125-its-ok-to-dream-big-stop-playing-small/ - It’s OK to Dream Big (Stop Playing Small)
      Introduction to the Episode (00:00:01)  Brian introduces the podcast and sets the theme about podcast hosts not having all the answers. Inspiration from Mike Allen's Post (00:00:10)  Discussion on how Mike Allen's humorous post sparked Brian's reflections on podcasting and advice-giving. Brian's Insecurities as a Host (00:01:15)  Brian shares his personal insecurities regarding his role as a podcast host and influencer. Critique of Influencers (00:02:26)  Brian expresses frustration with influencers who claim to have life figured out, relating it to his experiences. Sharing Personal Experiences (00:03:33)  Emphasis on the importance of sharing personal learning experiences rather than presenting oneself as an expert. Struggles with Advice-Giving (00:04:36)  Brian discusses his ongoing struggles with the advice he shares in his podcasts and posts. Imposter Syndrome (00:05:37)  Brian reflects on feelings of imposter syndrome when sharing advice on managing expenses and business practices. Going Against Popular Opinion (00:06:46)  Brian talks about the challenges of discussing unpopular business opinions and the reactions he receives. Sponsor Promotion: RepairPal (00:08:54)  Brian promotes RepairPal and its benefits for auto repair shops seeking new customers. Sponsor Promotion: App Fueled (00:09:55)  Introduction of App Fueled and its services for building customer loyalty apps for auto repair businesses. Rewarding Success Stories (00:10:59)  Brian shares the rewarding experience of hearing success stories from listeners implementing his advice. Discernment in Advice-Giving (00:12:03)  Brian advises listeners to discern the credibility of advice from various influencers and podcasters. Conclusion and Reflection (00:13:10)  Brian wraps up the discussion, emphasizing the importance of honesty in sharing experiences and insights.
    • By Transmission Repair
