We have been getting by without any type of smoke machine. Now with the small leak codes its become a challenge. What smoke machine does anyone recommend? What features are important?
I have an older snapon smoke machine I got a good used deal on from the snapon truck. Has to blow smoke out a hose. Got mine a year ago and can't believe how often I use it. Intake leaks, exhaust leaks, gas tank leaks on small engine tanks. And of course, evaporated leaks. Could never go back to not having one.
Sent from my SM-N920V using Tapatalk
Re: Smoke machines. We make a lotta money with our smoke machine. I don't remember what brand it is, because to me they're all the same. They make smoke and it flows into the system you're checking, and wherever it comes out is where you put the fix!!
When a car comes in with the "service engine" light on, and we read an evap leak, we explain that we need to hook up the smoke machine to the car, and it's $89.95 to smoke it.
Cha-Ching$$
Hi-Gear
For the record is difficult to accurately diagnose evap codes without it. The other uses like lean codes, wind inside the car all are super useful. Had a 1995 Buick with lean codes. Thought since it was old it was gna be easy to check for vac leaks.... Car spray the hoses. We'll after chasing my tail I put the smoke machine to use. 3 tiny hoses were cracked.... Fixed in 5 minutes once bought some more hose. In conclusion, this isn't just for new cars, it's for anybody who is SERIOUS about diagnostic and accuracy!
I use a Blue Point machine I bought a few years ago. It has worked grate and comes with some dye and a black light to make small leaks a little easer to find. It was around $800 from the Snap-on guy.
I have the cheaper snapon, it was $1300 or so. Before that I had a DIY machine for about 2 years. Before that I would fill the evap systems with 1.5psi of air and use soapy water to find leaks. Both worked, but the snapon is much easier.
Whatever smoke machine you get I would suggest you charge a separate fee for that test alone or package it together with a series of tests. For instance we package a smoke test into our level 1 diag which comes out to $150 before tax and fees. We used to charge $99-119 alone for a smoke test but we have since developed a tiered system for our diag process which makes us more profitable, streamlines the process, and has much more detailed explanation of all the tests and procedures we are doing which equates to value for our clients.
We have both an OTC smoke machine (which I'd like to upgrade) for our regular smoke tests and also a high PSI smoke machine by redline for boost leaks.
Edited by mspecperformance
A little off topic but how do you structure your diagnostic tiers? I need to find a better way to bill diagnostic time, especially a way to give the customer an idea of what they are in for before the job starts. Currently we bill most diagnostic fees hourly and tell the customer they should be prepared for at least an hour of time. I'm sure there is a better way though.
As for a smoke machine, get one, who cars what brand. I can't imagine getting by without one. We have an OTC and it gets used nearly every day. To be safe you should get a nitrogen generator or a smoke machine that has one built in. Its technically dangerous to pump a fuel tank full of compressed air. Most modern cars have pump modules so the pump is never exposed to air but if you try it on something old there is a chance for explosion if you're not using nitrogen. I use the machine to find intake air leaks on metered air systems. Probably the #1 cause of fuel trims being long.
Ours is a vacutech 2000e, same one in the Toyota dealer. $1500 or so and works great. One tank of fluid lasts literally years using it daily. We use it for everything.
Agree with Redline. Yes, we fix cars & make a ton of money with it. Use it almost every day.
Start at 1.0 labor charge for smoke test plus for the initial code check then go from there for repairs.
Dave
You really need a smoke machine! not sure how you get by without one?
But if you are looking to evap testing take a look at this.
Hello Everyone,
If you are able to buy any sort of smoke machine, you are lucky because most people use a cigarette or anything to produce smoke. If you do have the extra hundred bucks to spend than you can find great deals on craigslist or any classified website. My smoke machine is simple and does the job to catch for emission leaks. Most cars have an area were you can connect the hose. In most cases it's located under the hood and covered with a green top screwed on.
Good Luck!
Erik Gonzalez
EEE Auto Repair in Tracy
24/7 Roadside Assistance & Towing in Tracy
      Optimize Your Marketing & Stop ARO Drops NOW!
      Welcome to another episode of the Auto Repair Marketing Podcast! I'm your host, Brian Walker, and I’m excited to have my co-host, Kim, back with me after her recovery. Today, we’re diving into a topic that can change the game for your shop: Stop Playing Small.
      If you’re tired of feeling stuck or just getting by, this episode is for you. We'll be talking about the mindset shifts and practical steps needed to build a thriving, impactful business. It’s time to break free from the limits we place on ourselves and dream bigger.
      From overcoming the unique challenges of the auto repair industry to redefining what true success means, we’ll share real stories, honest advice, and strategies you can use to push your business to new heights. Plus, you’ll hear how the right mentors, clarity breaks, and a supportive community can make all the difference.
      Get ready to challenge yourself, take a fresh look at your goals, and start building a business that’s more than just getting by—it’s an empire.
      Let’s jump in and stop playing small together!
      Are you ready to convert clients to members? App fueled specializes in creating custom apps tailored specifically for auto repair businesses. Build client loyalty. Get started today with your own customer loyalty app. Visit https://appfueled.com/
      https://en.wikipedia.org/wiki/Start_with_Why  - Start with Why by Simon Sinek
      https://youtu.be/u4ZoJKF_VuA?si=8yihKPEDRkFErdeN
      https://shopmarketingpros.com/kim-and-brian-tell-their-story/  - Episode 2 : Kim and Brian Tell Their Story
      https://shopmarketingpros.com/walkers-hierarchy-of-marketing-needs/ - Walkers Hierachy of Marketing Needs (Blog)
      https://shopmarketingpros.com/ep-101-walkers-hierarchy-of-marketing-needs/ - Podcast Episode 101
      https://shopmarketingpros.com/ep-084-failing-forward-in-marketing/ - Failing Forward in Marketing - Episode 84
      Thanks to our Partners, Shop Boss, and 360 Payments Recorded at the 2024 Automotive Aftermarket Retailers of Ontario (AARO) Business Management and Lindertech Training Trade Show, Murray Voth explores the idea of transferable skills for automotive shop owners making the shift from technician to business owner. He highlights how their technical knowledge can be applied to efficiently use shop management software and offers strategies to overcome any intimidation they may feel. By adopting a structured approach to learning key performance indicators (KPIs) and generating business reports, shop owners can gain the confidence needed to manage their businesses. Voth encourages them to use their diagnostic abilities to analyze business metrics, ultimately improving their effectiveness in running their shops. Murray Voth, RPM Training. Listen to Murray’s previous episodes HERE. [email protected] Show Notes: Watch Full Video Episode Automotive Aftermarket Retailers of Ontario (AARO): https://www.aaro.ca/ Intimidation with Software (00:00:29) Shop Management Software Overview (00:02:08) Transferring Diagnostic Skills (00:03:36) Key Business Metrics (00:05:20)
      Thanks to our Partners, Shop Boss and 360 Payments Shop Boss – Shop Management Software built by shop owners for shop owners. It works the way you need it to, right out of the box. Find on the web at https://shopboss.net Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/             Click to go to the Podcast on Remarkable Results Radio
