Shop/Technician licensing
Timestamps:
(00:00) – Intro
Quotes
Tools & Resources Mentioned:
Final Thoughts:
Email Matt: [email protected] Diagnosing the Aftermarket A - Z YouTube Channel
In this episode of Business by the Numbers, Hunt Demarest, CPA, dives into the world of financial projections—what they are, why they matter, and how to build a solid financial story that banks will take seriously. Whether you’re looking to secure a loan, expand your shop, or simply set better financial goals, this episode will help you navigate the process with confidence.
The biggest mistake shop owners make when creating financial projections. Why your story matters more than the numbers when pitching a loan request to a bank. The three key levers you can adjust in a financial projection: sales, margins, and expenses. How to build a realistic projection that a bank will trust. Why working with an accountant on projections can save you from financial disaster. Common red flags that make banks reject loan applications.
Remarkable Results Radio Podcast with Carm Capriotto https://remarkableresults.biz/
Diagnosing the Aftermarket A to Z with Matt Fanslow https://mattfanslow.captivate.fm/
Business by the Numbers with Hunt Demarest https://huntdemarest.captivate.fm/
The Auto Repair Marketing Podcast with Kim and Brian Walker https://autorepairmarketing.captivate.fm/
The Weekly Blitz with Chris Cotton https://chriscotton.captivate.fm/
Speak Up! Effective Communication with Craig O'Neill https://craigoneill.captivate.fm/
