Engineering Flashback
Let’s just assume you’re one of the engineers who designs part of the modern automobile. Your job is to follow the guide lines and concept ideas the other engineers have put together. All you have to do is make whatever component or section you’re assigned fit into the space provided. You also have to keep the cost down and keep in mind the design restraints. Then, make sure it can be manufactured in such a way it can easily be installed and sent down the assembly line at the quickest pace possible.
I’m sure it’s a nerve-racking job. So much pressure is put on you to come up with something that will work, easy to assemble, and cost effective. You’ve strained your brain to come up with something, worked long hours to design it, built the prototype, and checked the results. You’re positive it will work. Now, it’s all up to the guys and gals on the assembly line to get it put together and out the door.
This time around, let’s pretend you’re the consumer. You’ve checked out this latest model and it’s just what you were looking for. It’s got the right styling, the right size, and it’s in your price range. So, you buy it. Ya take it home and enjoy the comforts of owning your brand new car. Then, several years go by. You’ve almost got it paid off and hoping for a few years without car payments. But, all of a sudden you’ve got car problems. You’ve followed the maintenance schedule to the letter, but something has still gone wrong. It’s out of warranty, which means it’s not going to be free, but you’ve got to get it repaired. You can’t fix it; in fact you don’t have any idea what is wrong. But, your favorite mechanic will. So, it’s off to the repair shop to have it diagnosed.
Let’s change gears again. Now we’re the mechanic. You get the car into the shop, you run the needed diagnostic tests, and find out that a little bitty part buried behind the dash has failed. The only way to get to it is removing the entire dash. Before diving into the nuts and bolts side of it, you’ve got to call the customer. This is not going to be an easy call, because you know the labor cost alone is not going to make for a happy car owner, for sure. You give them the figures for the R&R and there is a moment of gasps and shock. Then, reality settles in, and the owner tells you to go ahead with it.
Now, we’re back to being the engineer. Reports start coming in about how this little bit part that you designed and stuck inside the dash is failing left and right. The amount of backlash from all these repairs from all over the country are flooding your desk. What can you do about it? Probably nothing. Other than not designing anything like that again. So, you keep your head to the grindstone and persevere. Onto your next project. But, the memory of that little bitty part behind the dash haunts you day and night. In fact, you might even have flashbacks of the numerous reported failures, and you certainly don’t want to relieve that again.
This time around you’re asked to design a similar system on the latest car from the concept team. Those flashbacks of that little bitty part you stuck behind the dash is still fresh on your mind. This time, you’ve changed the design a bit so that same issue doesn’t happen again. Or, at least you hope not.
We’re back to being the consumer again. This time you’ve done your homework and looked at the new models to replace your present car. You’ve also kept in mind that huge repair bill for some silly little bitty part that could have been easily repositioned somewhere else. You’d like to avoid anything like that on your next new car. You talked in great detail about it to your salesman and he assures you there isn’t any problem like that anymore. If anyone would know about the inner workings of the modern car it would be the guy selling it to you right? With the salesman’s stamp of approval you write that check for your new car, and off you go to enjoy your new ride.
It’s the mechanics turn to return to the mix. That new car is now a few years old and it’s having problems. This time it’s a different problem than before, but the cost of the repair is even higher. It seems our engineering friend forgot to think of how many things are overlapping and concealing the components he designed. Simple things like changing a headlamp bulb require an afternoon at the repair shop. The anti-lock brake system is incorporated with the cruise control. The air conditioning system is aware of the exhaust fumes from the car in front of you and automatically regulates the fresh air dampeners. Radar systems, GPS, and so on and so on. Nothing is even remotely simple anymore, and nearly everything costs more than it should. The mechanic has to spend even more time in training classes keeping up with what the engineers are designing, as well as dealing with the next shock and awe from the customer over the price of repair.
And you wonder why a mechanic rolls their eyes back in their head when you bring a car in with a certain type of problem. Yep, they’re having flashbacks of pulling the dash to get to that little bitty part.
The flashbacks of these engineering designs continue. I don’t know about you, but I think the only person who might really know what’s happening in the real world when it comes to your car is the mechanic. The consumer has to pay the bill, the engineers try their best to design it, and the salesman does what he does. It all adds up to job security for the mechanics, they’re the ones keeping those little bitty things behind the dash working. In all honesty, the consumer might want to ask a mechanic about that new car or even used car they’re planning to purchase rather than the salesman or the engineer. They’re the ones who deal with the aftermath of the salesman’s claims and the engineer’s designs.
The engineer, the consumer, the salesman, or the mechanic. Who’s going to have the most flashbacks of these design debacles? Well, for me, it’s the mechanic. They’ve got to deal with the problems created by the engineering, the customer, and the salesman. Now, if the engineers wanted to really find out something about their little bitty part behind the dash, just put a few mechanics in the same room with a few of those engineers. That might make for one colossal flashback they’ll never forget.
If you have ever done an evaporator on a Mercedes S class from the early to late 90s w140 chassis (ie: 95 s500) you will be astonished at the engineering and the ammount of things you have to do to get it out. I believe it used to pay 24hrs or something like that. I have done one and can almost guarantee I will never do one again.
It all comes down to cost versus profit. When I worked at Chrysler we did evaporators in Trucks and Grand Cherokees with regualarity. When I asked an engineer at a training class why they didnt change the design I was told the cost of repalcement was still below the cost of redesign.
So, it's cost effective design it crappy and let us mechanics deal with the aftermath? Nice.... thanks engineers for the work and the ticked off customer who has to pay for your lousy design. Which of course, the customer thinks we're the ones ripping them off. Where's that engineer at? .........
I've always kinda wanted to punch the engineer responsible for the lock rings on Beetle headlights...
It's no fun telling the customer that it's going to be at least an hour and they need a new lock ring for a light bulb that's probably like 10 minutes or less by the book.
Had to do an evaporator on a Saturn Vue. By the time I got it out there was nothing between the back seats and the firewall. The center console came apart in 8 pieces. Just finished a flasher on an 02 vette. Have to remove the top part of the dash because the flasher comes out the back.grrrrr
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Dan Clark explores how emotion surpasses reason in driving action, particularly in sales, emphasizing the power of storytelling to activate specific brain chemicals. He shares personal experiences, including his recovery from paralysis, to illustrate the impact of belief and a strong "why." The conversation delves into societal stigmas around emotional expression, especially for men, and the importance of genuine connection. Clark further explains how leveraging brain chemistry through storytelling enhances influence and strengthens customer relationships. He concludes by stressing that businesses should prioritize deep human connections over mere transactions. Dan Clark, Hall of Fame Keynote Speaker, New York Times Best-Selling Author of 37 Books, Expert in Next-Level Leadership for Teams, Sales, and Life. https://danclark.com/ Show Notes Watch Full Video Episode The Institute of Automotive Business Excellence: https://www.wearetheinstitute.com/ Introduction of Dan Clark (00:00:00) The Importance of Emotion in Memory (00:02:47) Emotion vs. Knowledge in Sales (00:04:17) Statistics on Sales Persistence (00:04:47) The Role of Storytelling in Sales (00:05:13) Social Stigma Around Emotion (00:05:23) Mental Health and Emotional Prosperity (00:06:01) Creating Discomfort for Growth (00:07:05) Asking for Help in Mental Health (00:07:49) The Role of Feelings in Leadership and Sales (00:08:07) The Zone and Brain Chemicals (00:09:11) Emotional Connection in Sports (00:10:06) Impact of Storytelling on Audience (00:12:07) Overcoming Struggles and Emotional Growth (00:16:29) Authenticity and Emotional Expression (00:17:54) The Importance of Belief (00:18:30) Energy and Attraction (00:19:26) Authenticity in Connection (00:19:54) Personal Injury Story (00:20:31) Rock Foundation vs. Rock Bottom (00:21:21) Core Values in Business (00:22:22) The Power of Belief (00:23:08) Asking the Right Questions (00:23:51) Connecting Head and Heart (00:24:36) Physiological Responses to Fear (00:24:49) Storytelling in Sales (00:27:32) Self-Awareness in Customer Service (00:28:29) Identifying with Roles (00:30:22) Heart-to-Heart Connection (00:30:44) Story of Empathy (00:31:07)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/
