Rigged and Runnin’
People have been modifying their family car since the automotive industries began. No matter what the car, or its condition, somebody will modify something to suit their needs or their artistic interpretation of what their car should be. On occasions, these changes are brilliant and far better than what the designers could have ever thought. However, there are those rigged up and overly engineered home modifications that can leave the original designers and engineers in shock. Not to mention the mechanics that service them.
It’s amazing how the human mind has such an endless imagination to even dream up some of these wild and outlandish contraptions. They are more than just four wheels and transportation to the creators of the masterful works of art. Although at times, some of these wacky rides might appear a bit unorthodox to the onlooker. Art cars for example, don’t follow any technical bulletins or accepted engineering practices that any sane professional mechanic would understand. Safety and performance issues are put aside for the sake of artistry. Whatever looks good is good enough for them. Whether it’s modifying an old car to look like a cow or stretching a limo so far that it can’t possibly turn at an intersection are all in the name of creativity.
Then there are the backyard engineers who are not into the artistic side of the cars anatomy, but are merely after cheap functionality, no matter what it looks like. Sometimes it’s back to nature for spare parts. Logs for bumpers, wood slats for truck beds and fenders made from a sheet of plywood, just to name a few. Maybe it’s the cost of the repairs, or perhaps there are no parts to be found, so the only resource available is what they have on hand.
But, not all of these intrepid designers stick with natural products to modify their rides. Some use whatever is available at their local hardware store. Bathroom faucets for heater controls, PVC pipe made into shifter handles and things like door hinges to hold a gas pedal in place. Of course, there are the “traditional” DIY fixes that everyone has tried at one time or another. You know, duct tape, coat hangers, and bailing wire. But, we can’t leave out those fixes that seem to generate from the household kitchen either. I’ve even seen repairs made using a fork, knife or a spoon from their very own kitchen to supplement the loss of an inside door handle.
There are those more sophisticated modifiers who still leave me gasping. Like the large wheel rims and thin tires, or the lift kits on a family sedan that leave one wondering how much time these folks spend at their local chiropractor. Others, will spend a fortune on things like huge stereo systems or ultra-bright headlights, but never take in account the load they are putting on the electrical system of the car. Then they wonder what could be wrong with their car when they come into a professional repair shop and tell the mechanic, “I burned out four alternators in a row. So, there must be something wrong with the charging system.” Yes, you’re right. There is something wrong, but it’s not the charging system.
To go to even more extremes, there are the aftermarket modifications for the engine computer control systems. There are all kinds of computer programs out there that can modify the factory specifications. Some are for racing applications, some for better towing capabilities, and some are for street performance. With all of these updates and reprogramming for the car’s computer, you better know what you’re doing before downloading them into the vehicle’s data stream. It’s kind of late to find out your car won’t run correctly or not start at all after you’ve installed some back door program from parts unknown.
Maybe some people are thinking things are like they were in the early days of the car computer systems. Back then it was as simple as changing out the chip in the computer, but the chip has been done away with a long time ago. Now it’s a matter of installing a program with new data and information for the computer to interpret. Not as simple as changing a carburetor or putting in a different size cam. These days it’s all about the electronics.
Just the other day a guy called and told me he has this special computer flash program that he bought to modify his diesel engine. “All you’re supposed to do is download this software into the car’s computer, but every time I hook it up it says there is no communication with the car,” he told me, “But, I had it checked at another shop and they said their computer will talk to the car. They told me to call you and see if you can make my stuff work.” Now, I’m not the kind of mechanic who would pass up a challenge, but I think this guy has a problem with his aftermarket device, and it might be wise to go back to the company he bought it from and see if their little gizmo is having some issues. (Seen this before, been there, done that.)
Whether it’s a chain welded onto the car with a padlock attached because the door locks quit, or a computer modification that might end up as a malfunction it all leaves me just shaking my head sometimes. But my all-time favorite rigged up repair has to be the guy who used an old fashion horn button mounted on top of his brake pedal. This guy had two wires hooked to this horn button and taped them to the brake pedal support arm which traveled up to the factory brake light wires. So, when he put his foot on the button and mashed down on the pedal he could apply the brakes and the brake lights at the same time. Crude, but ingenious. That one made me giggle for sure.
I have to admire the people out there who have thought through a problem and found a way to rig up something that gets the job done without heading down to the local repair shop or parts store. However, as a professional mechanic, I can’t justify repairing anything that way. It’s just not the way it’s supposed to be done. Problems are repaired and diagnosed with a factory manual that explains not only how the system works, but the proper procedures to make the appropriate repairs. When it comes to these home grown modifications on the other hand, all bets are off.
Somehow, someway these home grown engineered cars with all their whatchamacallits and thingamajigs still managed to do the one thing the owner was really after, and that’s to keep their rigged up rigs runnin’ down the road. That is, until it messes up, then it’s off to a professional shop to solve the problem. Will there be some new doohickey added onto a car next week or next year that I haven’t seen before? Oh, you can bet there will be.
Gonzo: Used to be more mechanical modifications, as now with electronics, especially software it is more tempting to go in and make changes without getting into will it fit, meaning you don't need a machine shop to modify anymore! If you can make it look easy to do, there out and willing to try.
What I get a kick out of these DIY mods. is when they bring their car in with a problem and I tell them it's do to their add on they look at me as if I'm an idiot. Cause, they all the same thing, "I just put that on. So, that can't be the problem." amazing, simply amazing.
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Recorded at the 45th annual Mobile Air Climate Systems Conference (MACS 2025) in Orlando, Florida, Rob Bollinger shares the unique story of his third-generation family business, emphasizing their commitment to personal service and the legacy of his grandfather, who invented the overflow bottle system. The discussion also touches upon industry trends, the challenges of price competition, the evolution of AC systems with electric vehicles, and Bollinger's future plans for the business. Rob Bollinger, ABC Radiator, Baltimore, MD. https://www.facebook.com/abcradiator401 Show Notes Watch Full Video Episode MACS Training Event & Trade Show: https://macsmobileairclimate.org/ National Automotive Service Task Force (NASTF): https://wp.nastf.org/ Koura: https://www.kouraglobal.com/ Honeywell: https://www.honeywell.com/us/en Introduction to MAC Conference (00:00:00) Guest Introduction: Rob Bollinger (00:02:17) Rob's Family Business Legacy (00:02:52) Personal Touch in Deliveries (00:03:52) Customer Engagement During Deliveries (00:04:30) Rob's Background in the Business (00:06:08) Regrets About Family Business (00:06:22) Coolant Reservoir Bottle Invention (00:07:40) Patenting the Invention (00:08:25) Legacy of the Invention (00:09:48) Cash vs. Cashless Transactions (00:10:05) Honesty in Business (00:15:46) Future of Specialty Shops (00:16:20) Customer Outreach (00:16:30) Changes in Radiator Industry (00:16:54) Hiring Challenges (00:18:11) Golfing and Business Balance (00:18:39) AC Industry Challenges (00:20:10) Leak Detection Methods (00:20:57) Future Plans (00:21:50) Real Estate and Business Stability (00:22:28) Family Support (00:23:33) Training and Industry Updates (00:24:26) Vendor Interaction at Conferences (00:25:08) AI Repair Discussion (00:25:55) Reflection on the Conversation (00:26:09)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network This episode covers the critical role and impact of AI on marketing, the importance of persona marketing, and effective branding strategies. Learn about "watering holes," referring to identifying where potential customers spend their time online and offline, and how to effectively use persona marketing to target specific demographics. Dan stresses the importance of branding and community involvement, asserting that successful shops prioritize building brand recognition and relationships within their local areas. He also warns about trusting AI implicitly, referencing instances of AI being inaccurate. Dan Vance, Shop Dog Marketing.com Show Notes Watch Full Video Episode TST Big Event, March 29th, 2025: https://www.tstseminars.org/ Shop Dog Marketing at Shop Dog Marketing.com. "Want to see your auto repair shop thrive? Let Shop Dog Marketing be your guide. Our customer-first approach, combined with AI-driven creative content, ensures top rankings. Introduction to the Episode (00:00:00) AI in Marketing (00:01:02) The Importance of Networking (00:02:02) Consumer Behavior and Marketing (00:04:04) Bullet Points vs. Detailed Content (00:05:54) Creating Memorable Customer Experiences (00:06:32) Identifying Customer "Watering Holes" (00:08:29) Privacy Concerns in Marketing (00:09:41) The Rise of Persona Marketing (00:10:55) AI's Impact on Search Results (00:11:59) The Role of AI in Marketing Strategies (00:13:08) Caution with AI Information (00:14:12) Human Element in Marketing (00:17:34) Client Review Analysis (00:18:46) Women’s Expectations in Service (00:21:20) Impact of Professional Image (00:22:57) Targeting Ideal Customers (00:25:12) Purposeful Marketing Strategies (00:25:43) The Need for Customer Understanding (00:26:26) AI’s Role in Content Creation (00:28:07) Changing Landscape of AI (00:28:29) User Behavior and Decision Making (00:31:11) Branding in the Automotive Industry (00:31:55) Community Involvement for Branding (00:32:57) Conclusion and Call to Action (00:34:38)
      Thanks to our Partners, NAPA TRACS, and Today's Class Recorded at the 45th annual Mobile Air Climate Systems Conference (MACS 2025) in Orlando, Florida, this episode dives into the evolving world of thermal management in vehicles. Our panel discusses the shift from traditional air conditioning to a more advanced approach, driven by the growing complexity of modern vehicles, especially EVs. They explore why maintaining optimal temperatures for batteries, electric motors, and other components is just as critical as passenger comfort. The conversation also covers alternative refrigerants, particularly blends, as a way to boost efficiency, reduce environmental impact, and adapt to changing battery technologies. With these advancements, the need for technician training and industry adaptation is greater than ever. Our experts emphasize the importance of collaboration across the industry to ensure a smooth transition and deliver effective solutions for both OEMs and aftermarket service providers.
      Adam Kimmel, Koura, [email protected] Ryan Kooiman, Director of Training, Standard Motor Products. Ryan’s previous episodes HERE. Chuck Abbott, Global Marketing Manager, Koura Show Notes Watch Full Video Episode MACS Training Event & Trade Show: https://macsmobileairclimate.org/ National Automotive Service Task Force (NASTF): https://wp.nastf.org/ Koura: https://www.kouraglobal.com/ Honeywell: https://www.honeywell.com/us/en Introduction and Sponsors (00:00:00) Evolution of Thermal Management (00:02:28) Consultative Role of Shop Owners (00:02:10) Rise of Thermal Management Specialists (00:03:08) Importance of Battery Temperature Control (00:03:46) Impact of Electric Compressors (00:05:45) Training on Thermal Management (00:12:19) Future of Refrigerants (00:09:52) Concerns with Flammable Refrigerants (00:11:04) Thermal Management in Electric Vehicles (00:14:04) Training Demand for Electric Vehicle Systems (00:15:26) Battery Chemistry and Future Developments (00:17:02) Shifting Priorities in Funding (00:18:27) Changing Thermal Management Needs (00:18:57) Service Recommendations for Blends (00:19:18) Collaboration in Industry (00:19:58) New Components in AC Systems (00:20:50) Complexity of Thermal Management Systems (00:22:15) Career Opportunities in Automotive Technology (00:23:06) Investing in New Refrigerant Machines (00:24:30) Consumer Benefits of Blend Refrigerants (00:25:05) Leakage Characteristics of Blends (00:26:14) Future of Refrigerant Machines (00:27:35) Importance of Thermal Management Knowledge (00:29:02) Final Thoughts on Education and Collaboration (00:32:57)
      Thanks to our Partner, NAPA TRACS NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Thanks to our Partner, Today's Class Optimize training with Today's Class: In just 5 minutes daily, boost knowledge retention and improve team performance. Find Today's Class on the web at https://www.todaysclass.com/ Connect with the Podcast: -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on X: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/
