Hello, I was wondering if there was any other shops that have a cutoff limit to repairs they will do? I specialize in undercar, Tires both new and Used, Driveability....With that being said. Ive done two engines this month, Diagnosing transmission issues..I cant say no! How do you say no to work when they are loyal customers?
We don't have the time to do engine swaps. We average 10 cars a day with 2 techs working, taking a guy and having him spend 2 days on a motor job = 10 unhappy customers minimum.
I dont have the time either, I am a one man shop. I will spend two weeks on a engine job. =everyone pissed.
Hire additional help and increase your advertising
Shop is too small for that. Two bay. I advertise alot, But I push the in and out work.
  • 5 years later...
I run a two man shop also.  (Although the shop itself has 8 bays we are still fairly new and still expanding which is why we currently only have two techs...but having the extra bays allows us to keep long term jobs around)
We do not turn away heavy line work during these uncertain times. In my mind another wave of COVID lockdowns could come at any time, so I'm taking in anything I can while I can.
The only things we turn away are things we truly can't do because we don't have the equipment and/or training: (Body Work such as dents and paint, Exhaust Welding Work, transmission rebuilds, and tires)
Even then we don't truly turn anything away. We sublet it out. I have a tire shop, transmission shop, exhaust shop, and body shop that all give me wholesale pricing on their services so I can charge the customers basically the same they would have paid at the other shop and make a small profit while the customer doesn't have to go anywhere else.  (In return I give these other shops wholesale pricing on alignments or other services they can't/prefer not to do themselves)
Anyway....
The key to these big jobs, is properly setting expectations. And good communication and status updates while the car is in your shop.
I tell the customer right up front that this is a two man shop, and we can't devote more than a couple of hours a day to any one job and properly service our other customers.
I also find that if I touch base with them every day or two to give them a quick status update they are satisfied that we haven't forgotten about them or shoved them completely to the back burner and generally speaking are pretty patient.
Last month, I had a customer come in with an Acura TL that had a blown head gasket. He wanted us to also just go ahead and replace the timing belt and water pump while we were already in there.
I told the customer up front that the job is bigger than what a two man shop would normally want to tackle, but we'd be willing to do it IF he could leave the car with us for several weeks.
He was fine with that (nobody else wanted to do it at all, and some of the other shops were booked out 2-3 weeks anyway).
When we got the heads off, we noticed it wasn't just the head gasket but he also had some burnt valves (He towed it in, so we didn't see the blue smoke to diagnose this in advance)
So, I also sold him a valve grind job. We have a great machine shop we work with that can turn these around in just a couple of days.
All in all, we got him completely taken care of in under two weeks and he was pleased as punch, and we didn't have to piss off any other customers because we only worked on his when we had time to do so.
During the same two weeks we also had a pickup truck come in with a loud tappet tick. We diagnosed it as a blown head gasket (allowing water into that cylinder causing the hydraulic lifter to collapse), but once we got the heads to the machine shop and they pressure tested them we realized he actually had cracked heads as opposed to a simple gasket leak.
Sold the customer new heads, new set of lifters and lifter trays.
We got both of these jobs done in the same two week period without ticking off any of our customers who had smaller jobs, simply through good communication and made a couple thousand dollars in GP combined that we would not have gotten if we turned them away.
Edited by Grace Automotive
I also have a two man shop.  From the very beginning, I knew that I had to focus on the jobs that I could do better than most of my competitors.  I am a BMW/Mercedes shop, but end up taking many other makes and models in as a result of my reputation for quality work.  I'm not the cheapest, not the fastest, but honest and thorough.  I turn away many types of jobs because either we don't have the tools to do it, or the job is not one that I am well enough educated/experienced on.  We take on many larger jobs, dealing with a dozen or so cars at a time.  My car count is lower than some shops, but the ARO is a hell of a lot higher than most other shops as a result.  You have to play to your strengths, and do the best you can at what you're the best at.  Trust your gut and do your research. You will be fine! Good luck!
I always add at least an extra day to big jobs, often bill at a higher rate. I also include options, for example used engine, I will have an extra optional job called re seal. 6 hours to re do all gaskets on the used engine. This way the client understands if he declines that job, we are not going to cover his oil leak 6 months from now. If they walk because the price is too high I am pleased as punch. If they decide to move forward I am still profitable that week.
  • 5 weeks later...
On 1/10/2022 at 5:38 AM, Joe Marconi said:
You bring up good points. All too often, if not all the time, the labor guides a  not even close when it comes to big jobs.
Customer: But my cousin says he can do it in 4 hours Me: Why are you wasting the good oxygen in my office.
      Key Topics Discussed:
      Blade Runner Monologue Appreciation:
      Matt opens the episode with a reflection on the iconic "tears in rain" monologue from Blade Runner. He shares the behind-the-scenes story of how Rutger Hauer improvised the line, making it one of the most memorable moments in cinema history. Matt expresses his love for behind-the-scenes stories and the genuine, unfiltered insights into success and creativity.
      The Role of Luck in Success:
      Matt discusses the often-overlooked role of luck in achieving success. He references the "iceberg" analogy of success, where hard work, talent, and drive are below the surface, but luck plays a significant role. He emphasizes the importance of giving credit where it’s due and acknowledging the contributions of others.
      Mailbag Questions:
      Do You Believe in Ghosts?: Matt shares his thoughts on ghosts, explaining why he doesn’t believe in them and how he finds the idea more exciting than scary. Fuse Testing: Matt dives into his preferred methods for testing fuses, emphasizing the importance of using a test light with an incandescent bulb and checking for corrosion, especially in rust-prone areas. Loss Leaders in Business: Matt discusses the concept of loss leaders (e.g., free diagnostics, cheap oil changes) as a marketing strategy. He explores the pros and cons, including the risk of devaluing services and setting unrealistic customer expectations. Cell Phones in the Shop: Matt shares his perspective on allowing cell phones in the shop, acknowledging their utility as tools for diagnostics and service information but warning against distractions.
      Upcoming Events and Classes:
      Matt teases his upcoming classes, including a hands-on Pico training session with Scott Shot and a key class with Andrew Sexton. He highlights Tech Talks featuring Garrett Jacobson on HP Tuners as a diagnostic tool and Zeb Beard on diesel diagnostics.
      Behind-the-Scenes Stories: Matt’s passion for genuine, unfiltered insights into success and creativity shines through, whether discussing Blade Runner or the realities of running a business. The Importance of Evidence-Based Diagnostics: Matt emphasizes the value of using data and evidence to support recommendations, whether in diagnostics or business decisions. Balancing Loss Leaders and Profit: While loss leaders can be an effective marketing tool, they come with risks, including devaluing services and setting unrealistic customer expectations. Cell Phones as Tools, Not Distractions: In the shop, cell phones can be powerful diagnostic tools, but they must be used responsibly to avoid distractions.
      Memorable Quotes:
      "All those moments will be lost in time, like tears in the rain." – Matt reflecting on the Blade Runner monologue. "Luck plays an uncomfortably significant role in success, and people don’t like to hear it, but the data is overwhelming." "If you give away things, you start devaluing them." – On the risks of loss leaders. "Cell phones are step one in us slowly becoming more and more cybernetic."
      Call to Action:
      Check out the Aftermarket Radio Network for more shows on business, marketing, and communication. Attend Matt’s upcoming classes to learn more about diagnostics and tools like Pico and HP Tuners. Share your thoughts: Do you believe in ghosts? What’s your take on loss leaders? Let Matt know on social media or via email.
      Links and Resources:
      NAPA Auto Tech Training Aftermarket Radio Network Blade Runner (1982) – Watch the iconic "tears in rain" scene. HP Tuners – Explore this underutilized diagnostic tool.
      Introduction:
      Fuel trims are a common topic in professional forums, classes, and diagnostics, often leading to bold diagnostic decisions. Matt shares his experience of quickly diagnosing vehicle issues using fuel trims, even before leaving the parking lot.
      Key Challenges in Discussing Fuel Trims:
      The more you learn about fuel trims, the more nuanced and complex the topic becomes. It’s difficult to generalize fuel trim behavior across all vehicles, as each system has unique characteristics. Fuel trims are just one piece of data that must be factored into a broader diagnostic process.
      What Are Fuel Trims?
      Definition: Fuel trims are adjustments made to the base fuel schedule by the engine control unit (ECU). Matt credits Matt Ragsdale on iATN for one of the best explanations he’s seen.
      Two Primary Fuel Systems:
      Speed Density Systems:
      Relies on the Manifold Absolute Pressure (MAP) sensor and engine RPM as primary inputs. Engine control algorithms tend to be more complex.
      Mass Airflow (MAF) Systems:
      Uses the Mass Airflow Sensor (MAF) and crank sensor (RPM) as primary inputs. Simpler in design compared to speed density systems. Modern systems often blend elements of both speed density and MAF systems.
      Closing Thoughts:
      Matt emphasizes the importance of understanding the nuances of fuel trims and how they vary across different vehicle systems. He plans to dive deeper into the topic in future episodes, providing more detailed insights and practical examples.
