Hello all,
We recently had a customer cancel a repair that was authorized over the phone. This was a rather labor intensive job and about 45-50% through the service, customer calls in to cancel stating he was not told what the problem was by our service advisors. We had already ordered all the parts and I had the head mechanic start the disassembly process.
How would you go about handling such a situation? What are your policies and procedures for cancellation of repairs?
In regards to paperwork, the vehicle was towed in by a wrecker service. We have been in business for quite sometime now and are located in a busy area in Los Angeles, but have never experienced such a customer before.
Thanks for your thoughts and opinions in advance.
Nick
Hello all,
Nick
I think for starters I'd locate the actual reasoning and do a bit of an investigation.
You need to determine if he was properly informed of they repair and the cost (in accordance with your policies), and if there isn't any evidence to suggest a issue with your employees - side with the employees.
More often than not, the customer found another shop that'll do the work cheaper.
I'd offer some type of "consolation " prize to the customer - a discount on completing the job or allowing the parts to be returned and customer pays the original labor quote to reassemble the vehicle and the shop accepts no liability.
Obviously don't give the farm away, but if he feels cheated try and help within reason.
I think it would be extremely rare to have a situation where the staff is at fault. They could have possibly set better expectations or communicated cost and job description better, but I doubt that's the actual cause of this situation. If it is, unfortunately the right thing to do is return the parts and eat the labor or come to modified agreement in regard to the customers concern with fixing the vehicle.
Edited by ncautoshop
yeah, just work with the customer towards a resolution, if one cannot be made, charge for what you have done and move on. They DID give approval so its not your fault for starting the repairs, parts are not an issue as they can be returned. It mainly sounds like he he second thoughts and got an estimate from someplace else and chose to let them do the repairs?
More then not They were explained what was what was wrong with the vehicle and what it detailed for repair . I agree with the other post they found someone that says they will do for less.
We would talk with them and explain the process over again and find out what the true reason for declineing completion. Obviously we would charge any time and materials used up to the point of canceling, this usually sways them from going else where due to thier is no savings.
If it is price - Explain the benifits you give over others this is why you charge what you charge - Warranty , Quailty of products , 12 months same as cash , etc.
With out knowing type of repair and real reason hard to give to much help.
Thanks Dan
I was in court once for something like this and the Judge told my customer that if she had the car towed to my shop it was obvious that there was an expectation for me to fix it and for her to pay for my services. If they have found another shop that will do this work for less I think you need to take the savings out of the equation. When they find out how much It will cost for you to undo what you have already done they may tell you to keep going.
They authorized. No ifs ands or buts after its started. To late.
They will leave unhappy and won't return however, they wouldn't anyway.
They may have more tricks up there sleeve after you put it back together.
Get the money or get the lien process started. No sympathy for cold feet after you're invested.
Sent from my SM-N900P using Tapatalk
I agree with other posters that they probably found someone who said they would do it for less. If they previously authorized the repair they have made an express agreement or contract that is legally binding. Your State may have different rules about recording this but in NY you have to record the time and date the the phone authorization as well as who you spoke with. If they want to cancel half way though they owe you for work performed and materials ordered. That is pretty standard precedent when it comes to contract disputes and if it went to court that would be the result.
Of course the best resolution is to discuss with the customer and help them come to terms with the situation. Remember that diagnostic time is part of your service and if they called someone else to quote the job it would likely not include this time. Offer to them to shut the job down as is and write it up for time spent plus parts and allow them to have it towed if they so choose. I doubt they will do that though, and maybe be explaining it well you might even get a return customer out of the deal.
I would not discount them under any circumstances. Simply the fact that you had to halt your tech think it over enough and come here for to help think it though means it has already cost you more than it should have. There is no way you are at fault and you should express to the customer how costly this event was, but you will still complete the job for the price quoted if they decide to do so.
For future reference, email them an explanation of what work is needed and request authorization. All they need to do is reply back giving you authorization to do the work. If they call in, be sure to instruct them to reply back via email. Don't proceed without that reply. The reply email will stand in court as strongly as an actual customer signed authorization. At least in Tennessee it does.
I think you are correct, I has this happen before.
Christian, excellent pro tip!
Hello all,
Thanks for the responses. I think our company has came to a resolution to add a page on our website that a customer can type their info in and state what services are needed and authorized. We do have an actual form they fill out while at the shop, but as in this case the vehicle was towed in by the customer.
Hopefully we will never encounter such a scenario again.
Regards,
Nick
CA Auto Group
      Join host Brian Walker as he welcomes Mauro Stara to explore the transformative connection between your health and business success. In this episode, Mauro shares his expertise on why your body is your ultimate business card and how optimizing your well-being can take your professional performance to the next level.
      Discover actionable strategies like improving sleep quality, managing stress, and fine-tuning your diet for better energy and focus. Plus, learn how personalized blood work and hormone optimization can help you achieve sustainable results.
      Don’t miss this insightful conversation packed with practical tips to help you elevate your health and your business. Tune in now!
      How To Get In Touch With the Guest
      https://www.instagram.com/maurostaraofficial/ - Instagram
      https://www.facebook.com/mauro.stara.944/ - Facebook
      https://www.linkedin.com/in/mauro-stara-4b4295217/ - Mauro Stara
      https://6packceo.com/start - Six Pack CEO
      Introduction to the Episode (00:00:01)  Brian Walker introduces the podcast and guest Mauro Stara, discussing the episode's theme. Body as a Business Card (00:01:08) Mauro shares insights on how physical appearance impacts business perceptions and relationships. Judgment by Appearance (00:02:10)  Discussion on the subconscious judgments people make based on appearance in business settings. Health vs. Wealth (00:04:13)  Mauro emphasizes the importance of prioritizing health alongside pursuing wealth for long-term success. First Impressions Matter (00:05:08)  Mauro explains how health influences trust and credibility in business interactions. Changing Perceptions of Successful Individuals (00:06:45)  Brian and Mauro discuss how successful figures are increasingly prioritizing their health and fitness. Metabolic Panels Importance (00:09:37)  Mauro explains why he starts with metabolic panels for clients to assess health effectively. Transformation Through Blood Work (00:12:29)  Mauro shares his experience of using blood work to optimize client health and weight loss results. Introduction to RepairPal (00:15:34)  Discussion on how RepairPal helps auto repair shops gain customer trust and grow their business. App Fueled Overview (00:16:40)  Introduction to App Fueled, a customer loyalty app for auto service shops to enhance customer retention. Blood Work and Hormone Optimization (00:17:48)  Mauro discusses the importance of hormone optimization through blood work and the pitfalls of standard health ranges. Changing Testosterone Ranges (00:19:09)  Comparison of historical and current testosterone levels, highlighting the impact of societal health trends. The Importance of Feeling Good (00:21:01)  Emphasis on personal health and how it affects business performance, beyond just numerical test results. Five Pillars for Testosterone Optimization (00:23:45)  Discussion of five key areas to address for naturally increasing testosterone levels. Sleep's Critical Role (00:25:01)  Importance of quality sleep in maintaining healthy testosterone levels and overall well-being. Diet and Mineral Deficiencies (00:26:04)  Focus on diet quality and addressing mineral deficiencies as crucial for testosterone production. Body Fat and Hormonal Balance (00:26:18)  Explaining how excess body fat affects hormones and overall mental health. Chronic Stress and Hormonal Prioritization (00:27:18)  Impact of chronic stress on hormone levels and the body's reproductive priorities. Environmental Factors (00:28:32)  Discussion on how environmental factors can subtly influence hormone health. Business Lifestyle and Sleep (00:28:39)  Reflection on the business owner's lifestyle and its negative impact on sleep and health. Effective Workout Strategies (00:29:25)  Mauro advocates for a manageable workout routine of three times a week for optimal health. The Importance of Recovery (00:31:25)  Discusses the need for balanced workout frequency to avoid fatigue and maintain testosterone levels. Walking vs. Running (00:32:23)  Explains the benefits of walking for long-term sustainability over high-intensity workouts like running. Personal Experience with CrossFit (00:34:09)  Shares insights on how intense training can lead to difficulties in maintaining a diet. Actionable Health Advice (00:35:07)  Suggests starting with blood work to assess health and identify potential issues. Nutritional Framework (00:36:22)  Recommends a balanced diet focusing on protein and fats to stabilize blood sugar levels. Program Information (00:37:17)  Provides details on the "Six Pack CEO" program and how to get more information. Blood Work Offer (00:38:04)  Mentions a special offer for blood work analysis to help assess health conditions.
      Closing Remarks (00:39:51)  Encourages listeners to reach out with questions and highlights the value of health assessments
      Episode 204 - How Misconceptions in Auto Repair Pricing Impact Business With Jason Quillin
      In episode 202 of "The Weekly Blitz," Coach Chris Cotton takes a deep dive into the financial performance of auto repair shops, offering listeners a comprehensive analysis based on insights from the January edition of Ratchet & Wrench magazine. Throughout the episode, Coach Chris emphasizes the critical importance of tracking key performance indicators (KPIs) such as annual revenue, gross profit margins, and net profit margins. These metrics are essential for shop owners who aim to understand and enhance their business's financial health.
      Coach Chris shares compelling survey statistics that reveal significant revenue growth within the auto repair industry over the past 15 years. This growth underscores the dynamic nature of the industry and the opportunities available for shop owners who are proactive in managing their finances. He highlights the necessity for shop owners to focus on improving their financial metrics, as doing so can lead to increased profitability and long-term success.
      In addition to discussing financial performance, the episode also promotes Shop Marketing Pros, a specialized marketing company dedicated to serving auto repair shops. Shop Marketing Pros offers tailored marketing solutions designed to help shop owners attract more customers and build a strong brand presence in their local markets.
      Listeners of this episode will gain valuable insights into the financial aspects of running an auto repair shop and learn strategies to boost their business's performance. Coach Chris's expert advice, combined with the resources provided by Shop Marketing Pros, equips shop owners with the tools they need to thrive in a competitive industry.
      Introduction to the Episode (00:00:08)
      Coach Chris Cotton introduces the podcast and its purpose to supercharge auto repair businesses.
      Overview of Ratchet & Wrench Magazine (00:01:04)
      Discussion on insights from the January edition of Ratchet & Wrench magazine regarding shop performance.
      15-Year Industry Comparison (00:02:15)
      Chris highlights changes in annual revenue and profit margins in the auto repair industry over 15 years.
      Importance of Tracking KPIs (00:03:15)
      Emphasis on the significance of key performance indicators for making informed financial decisions.
      KPI Awareness Among Shop Owners (00:04:20)
      Chris shares his experience teaching shop owners about KPIs, revealing a lack of awareness.
      Current Revenue Statistics (00:05:20)
      Over 50% of surveyed shops now report annual revenues exceeding $1 million, a significant increase from 15 years ago.
      Gross Profit Margin Insights (00:06:18)
      Discussion on gross profit margins, with over 50% of shops reporting margins above 50%.
      Revenue Breakdown of Surveyed Shops (00:07:17)
      Detailed statistics on revenue ranges among surveyed shops, highlighting growth trends.
      Industry Consolidation Factors (00:09:35)
      Analysis of industry consolidation and growth potential as more shops exceed $25 million in revenue.
      Gross Profit Margin Categories (00:10:49)
      Breakdown of gross profit margins among surveyed shops, with insights on profitability levels.
      Net Profit Margin Overview (00:12:59)
      Discussion on net profit margins, noting a concerning percentage of shops not generating profit.
      Encouragement for Improvement (00:14:07)
      Chris encourages shop owners to make small tweaks for improved profitability and performance.
      Tracking and Measuring KPIs (00:16:12)
      Final thoughts on the importance of tracking KPIs and using data to drive business improvements.
      Craig O’Neill, welcomes his friend and communications expert, David Boyd, as our guest.  Listen up to hear the thoughtful conversation between David and Craig across a variety of topics and questions related to the phones skills of your staff, AI use in the world today, and the outlook for the future.
      A key question:  “Will the job of the service advisor still exist?”
      As AI solutions seem to become more and more sophisticated - the question has career advisors wondering this aloud.
      The conversation should be encouraging for anyone who takes their professional role as a service advisor seriously, and the future, according to David and Craig, appears bright.
      According to David, the service advisor is the person we should be empowering further, and developing, as this is the role focused on building relationships.
      The conversation draws on additional points related to what we learned during Covid and the real value of actual connection, as well as some of the pitfalls for what occurs when a productive technician is forced to answer phone calls.
      Listeners will walk away with some practical advice from this episode, and more clear vision for a coachable front counter that is focused on connecting!
      The WOTD Today:
      Affable
      Noun-
      Friendly - good natured - easy to talk to
      Email Craig O'Neill: [email protected] Watch Full Video Episode Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters
