We just performed a heater core replacement for a 96 Ford E350. All Data book time for the job is 7.3 hours. The job took a considerable amount of time LONGER to complete the service. This job ended up taking 12 man hours to complete. Just wanted to get input from some other shops that have performed heater core replacements and if they all take longer than the estimated book time. Also, do you typically charge X hours over book time for a job like this for the estimate?
We always mark up book time 20%, except maintenance items. We also do our best to make sure we build an accurate quote before presenting to the customer. On big jobs like that, I usually ask the guys if the time I'm getting ready to sell sounds accurate and if we can think of anything else we should charge for. I've toyed around with marking up stuff more once they reach a certain age, but nothing in writing yet.
On a 96 I probably would have charged at least 10 hours, plus evac and recharge, plus coolant service. So probably about 11.5
Agree, book time is accurate...if your working on new cars! We always mark it up a touch and if it's a problem (corrosion, tough job, etc) we explain to the customer were increasing the labor for these reasons over what we typically would charge. We've recently done a job one a lifted vehicle (custom 15"+ lift) - that customer was charger almost double the labor. I explained to him we weren't actually interested in doing the job - but if I was going to do it that it was going to be how much it was. Obviously he didn't like it, but we did the job!
I should have added, I never ever tell a customer how many hours the job calls for, or how much I've marked it up. I only speak in dollars to fix the car. I might indicate that the job is very labor intensive, but that's it.
You failed to give exact info for the vehicle but when I checked Mitchell, Motor and Chilton with various engine, transmission and sub-model configurations for a 1996 Ford Econoline I fail to see any time estimates anywhere near your stated 7.3 hours. In fact they are all much less which confuses me. Is it possible that the vehicle was mis-identified on your post?
For a 1998 5.4 Expedition Mitchell allows 7.0 for the core + 1.4 for evac/recharge of A/C = 8.4 hrs.
Was anything else required such as hoses, coolant flush, initial review/diagnosis?
Either way this is a long, tedious job that I would normally recommend go to the dealer. I happen to be busy enough to have that luxury. If I had to do the job I would go in at 9-10 hours PLUS the unknowns which I noted above. Sorry you wound up short but your tech possibly learned something during that job and you definitely did.
book time (Mitchell) is 7.0 or 4.3 warranty time. That means it takes an experienced tech 4 hours to do the job when the truck is fairly new, 7 hours for everyone else with a service manual. If it took your guy 12 hours he is either slow or inexperienced or didn't review the proper R&R procedure before starting the job.
That being said we rarely do heater cores that call for more than 3 hours because we don't do them every day, old cars have plastic parts that break easily, and it just ties up too much time. I can do 10 control arms or brake jobs in the time it takes to do one nasty Jeep or S10 heater core.
I go by Chilton labor guide times as long as it's a stock vehicle. Certain things will extend the time, rust, aftermarket add-ons, etc..those have to be added on. My inexperience cannot be a factor, though...
If it is stock, and I have never performed the job....it may take longer...just the way it is. Other jobs I can beat time on....it all evens out and makes it honest.
Next time that job comes around I may know a shortcut and will do the job quicker, thus gaining my time back from the previous job.
Just noticed i had a similar situation involving heater core. What i tend to do is add .2 per year of vehicle for most of my repairs. in the case of a 1996 it would add approx 4 hrs to labour guide. gives room for rust,siezed componants etc.. seems to work well. I try to monitor repairs like that closely so if i am in it at 5 hrs and know i will be over,i consult the customer. most people understand as long as they are kept in the loop so to say as what is going on..
Love Chucky112233 idea. Just did a heater core on an Audi, multiplied time by 1.5 and still lost our butt. Took over 20 man hours to get the dumb thing out. Never again. I agre with JimO and will send to dealer next time....
Richard
Edited by Truett
Quote it high always. If your tech blows the time out of the water then comp the next oil change to make up for the increase of price with th customer. Never told them you quoted high or they will think you quote everything high, just coupon a oil change and everybody is happy
Swag Master, I know what you mean. We installed both lower control arms yesterday on a Nissan Quest, performed the alignment, and took less than two hours. Client was happy and we were happy!!
I can personally have had heater cores I have done in and out in a single day. I know techs I have had working for me sometimes will take 12 hours. If you have your guys do a few of them then they get the experience and the time to do it starts to drop, just like with any job.
I personally would be happiest if we never did another heater core ever. With the exception of oil leaks which we shy away from cooling system problems cause the most headaches. The heater core failed because of an acidic cooling system. Caused by neglect. Every other gasket/seal/part has been affected. We provide a service our regular customers that's the only reason we do these garbage jobs.
I have access to all the book times but we always go with Chilton severe time- they are the highest and never let me down.
Once I quote a customer, unless there is a really good reason, I stick to it. Last time we did a heater core, customer had aftermarket radio he installed himself and there were wires EVERYWHERE. Lost our butt on it but kept the price the same. SHould've charged more but didn't- we ended up cleaning up the wires for him as well. Our shop is rated 4.9 out of 5 with over 130 reviews and that's how we keep it.
    • By Transmission Repair
      Shop Boss – Shop Management Software built by shop owners for shop owners. It works the way you need it to, right out of the box. Find on the web at https://shopboss.net Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/             Click to go to the Podcast on Remarkable Results Radio
      Thanks to our Partner, NAPA Auto Care Welcome to a special milestone episode of "Remarkable Results Radio," hosted by Carm Capriotto. As we celebrate our 1000th episode, we're not only reflecting on the incredible journey we've taken together, but also unveiling something special—12 Success Strategies From Professional Auto Service Ceo's, distilled from over 2,000 podcast episodes that have shared invaluable insights from industry leaders, shop owners, and experts. Over the past nine years, Carm has gathered a wealth of knowledge from the brightest minds in the automotive aftermarket. Each episode has contributed to a deeper understanding of what drives success in this ever-evolving industry. These 12 strategies are drawn from the real-world experiences and lessons shared by our remarkable guests. This episode is more than just a celebration—it's a resource for you. These strategies are designed to help you evaluate and strengthen your business, ensuring long-term success in the automotive aftermarket. Thank you to our loyal listeners for your continued support, engagement, and feedback. You’ve helped shape the conversations that have led to these key takeaways. Download the full copy of 'The Top 12 Success Strategies from Professional Auto Service Ceo's': remarkableresults.biz/ceo We gathered episodes based on each of the 12 strategies. Find them on our Collections page HERE. Show Notes Watch Full Video Episode Download the full copy of 'The Top 12 Success Strategies from Professional Auto Service Ceo's': remarkableresults.biz/ceo
      Thanks to our Partner, NAPA Auto Care Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Special episode collections: https://remarkableresults.biz/collections         Click to go to the Podcast on Remarkable Results Radio
