Heater Core Replacement for a 96 Ford E350
We just performed a heater core replacement for a 96 Ford E350. All Data book time for the job is 7.3 hours. The job took a considerable amount of time LONGER to complete the service. This job ended up taking 12 man hours to complete. Just wanted to get input from some other shops that have performed heater core replacements and if they all take longer than the estimated book time. Also, do you typically charge X hours over book time for a job like this for the estimate?
We always mark up book time 20%, except maintenance items. We also do our best to make sure we build an accurate quote before presenting to the customer. On big jobs like that, I usually ask the guys if the time I'm getting ready to sell sounds accurate and if we can think of anything else we should charge for. I've toyed around with marking up stuff more once they reach a certain age, but nothing in writing yet.
Agree, book time is accurate...if your working on new cars! We always mark it up a touch and if it's a problem (corrosion, tough job, etc) we explain to the customer were increasing the labor for these reasons over what we typically would charge. We've recently done a job one a lifted vehicle (custom 15"+ lift) - that customer was charger almost double the labor. I explained to him we weren't actually interested in doing the job - but if I was going to do it that it was going to be how much it was. Obviously he didn't like it, but we did the job!
I should have added, I never ever tell a customer how many hours the job calls for, or how much I've marked it up. I only speak in dollars to fix the car. I might indicate that the job is very labor intensive, but that's it.
You failed to give exact info for the vehicle but when I checked Mitchell, Motor and Chilton with various engine, transmission and sub-model configurations for a 1996 Ford Econoline I fail to see any time estimates anywhere near your stated 7.3 hours. In fact they are all much less which confuses me. Is it possible that the vehicle was mis-identified on your post?
For a 1998 5.4 Expedition Mitchell allows 7.0 for the core + 1.4 for evac/recharge of A/C = 8.4 hrs.
Was anything else required such as hoses, coolant flush, initial review/diagnosis?
Either way this is a long, tedious job that I would normally recommend go to the dealer. I happen to be busy enough to have that luxury. If I had to do the job I would go in at 9-10 hours PLUS the unknowns which I noted above. Sorry you wound up short but your tech possibly learned something during that job and you definitely did.
book time (Mitchell) is 7.0 or 4.3 warranty time. That means it takes an experienced tech 4 hours to do the job when the truck is fairly new, 7 hours for everyone else with a service manual. If it took your guy 12 hours he is either slow or inexperienced or didn't review the proper R&R procedure before starting the job.
That being said we rarely do heater cores that call for more than 3 hours because we don't do them every day, old cars have plastic parts that break easily, and it just ties up too much time. I can do 10 control arms or brake jobs in the time it takes to do one nasty Jeep or S10 heater core.
I go by Chilton labor guide times as long as it's a stock vehicle. Certain things will extend the time, rust, aftermarket add-ons, etc..those have to be added on. My inexperience cannot be a factor, though...
If it is stock, and I have never performed the job....it may take longer...just the way it is. Other jobs I can beat time on....it all evens out and makes it honest.
Next time that job comes around I may know a shortcut and will do the job quicker, thus gaining my time back from the previous job.
Just noticed i had a similar situation involving heater core. What i tend to do is add .2 per year of vehicle for most of my repairs. in the case of a 1996 it would add approx 4 hrs to labour guide. gives room for rust,siezed componants etc.. seems to work well. I try to monitor repairs like that closely so if i am in it at 5 hrs and know i will be over,i consult the customer. most people understand as long as they are kept in the loop so to say as what is going on..
Love Chucky112233 idea. Just did a heater core on an Audi, multiplied time by 1.5 and still lost our butt. Took over 20 man hours to get the dumb thing out. Never again. I agre with JimO and will send to dealer next time....
Richard
Edited by Truett
Quote it high always. If your tech blows the time out of the water then comp the next oil change to make up for the increase of price with th customer. Never told them you quoted high or they will think you quote everything high, just coupon a oil change and everybody is happy
Swag Master, I know what you mean. We installed both lower control arms yesterday on a Nissan Quest, performed the alignment, and took less than two hours. Client was happy and we were happy!!
I can personally have had heater cores I have done in and out in a single day. I know techs I have had working for me sometimes will take 12 hours. If you have your guys do a few of them then they get the experience and the time to do it starts to drop, just like with any job.
I personally would be happiest if we never did another heater core ever. With the exception of oil leaks which we shy away from cooling system problems cause the most headaches. The heater core failed because of an acidic cooling system. Caused by neglect. Every other gasket/seal/part has been affected. We provide a service our regular customers that's the only reason we do these garbage jobs.
I have access to all the book times but we always go with Chilton severe time- they are the highest and never let me down.
Once I quote a customer, unless there is a really good reason, I stick to it. Last time we did a heater core, customer had aftermarket radio he installed himself and there were wires EVERYWHERE. Lost our butt on it but kept the price the same. SHould've charged more but didn't- we ended up cleaning up the wires for him as well. Our shop is rated 4.9 out of 5 with over 130 reviews and that's how we keep it.
      Thanks to our Partners, AAPEX, NAPA TRACS, and Automotive Management Network Recorded at the 2024 Automotive Aftermarket Retailers of Ontario (AARO) Business Management and Lindertech Training Tradeshow, discover how simply attending meetings can significantly improve net profit, the impact of cost management, and tips on leveraging technology for business efficiency. Murray Voth, RPM Training. Listen to Murray’s previous episodes HERE. [email protected] Show Notes Watch Full Video Episode Automotive Aftermarket Retailers of Ontario (AARO): https://www.aaro.ca/ Importance of Attendance (00:02:04) Discussion on how missing educational events can lead to lost opportunities and profits. Value of Showing Up (00:03:05) Murray emphasizes the connection between attendance and improved business performance. Networking and Community (00:04:39) The significance of in-person meetings for building relationships and sharing knowledge. Learning from Group Sessions (00:05:23) Murray shares insights on the benefits of participating in group coaching sessions. Addressing Intimidation in Coaching (00:07:50) Discussion on how some individuals feel intimidated and hesitant to participate in coaching. The Need for Continuous Learning (00:10:59) Carm stresses the importance of seeking expert guidance and accountability in business. Coaching Styles and Techniques (00:11:53) Murray contrasts different coaching approaches and their effectiveness in the industry. Utilizing Technology for Coaching (00:13:28) Murray discusses the transition to online coaching and the importance of Google Business Profile. Engagement in Virtual Meetings (00:14:17) The effectiveness of screen sharing and virtual meetings in enhancing learning experiences. Introduction to Collaboration Tools (00:15:54) Discussion on using screen sharing and collaboration tools for knowledge sharing among automotive shop owners. Resources for Business Improvement (00:18:58) Introduction to automotive management network resources such as SOPs and checklists for business advancement. Note-Taking and Organization (00:20:00) Personal experiences with note-taking and strategies for managing notes effectively in a business context. Using Google Docs for Accountability (00:23:22) How Google Docs can facilitate accountability by allowing team members to log and review action plans collaboratively. Networking and Community Support (00:27:02) Encouragement for members to utilize networking tools like Slack for better communication and support among peers. Understanding Employment Law (00:30:33) Insights into Canadian employment law regarding severance and the importance of having employment contracts to protect business owners. Understanding Severance Costs (00:32:12) Discussion on the financial impact of severance costs and the importance of understanding net income. Calculating Impact on Sales (00:33:13) Exploration of how to calculate necessary sales to cover losses in the automotive industry. Networking and Sharing Solutions (00:34:11) Importance of sharing experiences and solutions among peers in overcoming business challenges. Expense Management Insights (00:35:09) Discussion on the need for better focus on expense management in business operations. Insurance and Expense Comparisons (00:36:02) Sharing strategies for managing insurance and other recurring expenses effectively. Planning Expense Discussions (00:37:35) Proposal to plan discussions on key expenses in future meetings for better financial management. Setting Budgets and KPIs (00:38:27) Discussion on the importance of setting budgets and KPIs for various business expenses. Normalizing Income Statements (00:39:18) Explanation of how to clean up income statements for accurate financial analysis.
      Thanks to our Partners, AAPEX, NAPA TRACS, and Automotive Management Network Set your sights on Las Vegas in 2024. Mark your calendar now … November 5th-7th, 2024. AAPEX - Now more than ever. And don’t miss the next free AAPEX webinar. Register now at http://AAPEXSHOW.COM/WEBINAR NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on X: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections             Click to go to the Podcast on Remarkable Results Radio
      Understand the financial benefits of effective training for  Service Advisors and Customer Service Reps and the importance of networking and collaboration. November 9 - 10, 2024 in Detroit/Novi, MI Learn more at serviceadvisortraining.com
      Leigh Anne Best, Might Auto Pro, Medina, OH, trainer and co-founder of Brakes for Breasts Bill Hill, Might Auto Pro, Medina, OH, trainer and coach Maverick Shop Owners Laura Frank, former shop owner, trainer and co-founder of Brakes for Breasts Gerry Frank, former shop owner, trainer and coach for Maverick Shop Owners
      Importance of Owner Participation (00:03:00) Carm emphasizes the need for shop owners to participate in training alongside their customer service representatives. Networking Benefits (00:04:22) The significance of networking among attendees at the training event for shared learning experiences. Experience of the Trainers (00:05:34) Highlighting the extensive experience of the trainers and their practical knowledge in customer service. Financial Implications of Training (00:06:04) Discussion on the financial benefits of effective customer service and training for shop owners. Technician to Service Advisor Success Story (00:09:01) Bill shares a success story of a technician who transitioned to a service advisor role and excelled. Transparency in Business Practices (00:12:00) Jerry talks about the importance of transparency and ethical practices in customer service. Hiring for Customer Service (00:14:20) Discussion on effective hiring practices for customer service representatives based on personality traits. Upcoming Live Training Event (00:16:34) Announcement of the live service advisor training event scheduled for November 9th and 10th in Detroit. Building Customer Relationships (00:20:22) Emphasizes the importance of educating customers about their vehicle issues for better service. Importance of Follow-up (00:21:20) Highlights the significance of following up with customers to encourage repeat visits. Training for All Staff (00:21:51) Stresses that training should include anyone who interacts with customers, not just CSRs. Tracking Phone Call Success (00:22:31) Discusses the importance of tracking opportunity calls to measure conversion rates effectively. Utilizing Technology for Improvement (00:23:33) Mentions the benefits of using technology to analyze customer interactions and improve service. Identifying Underlying Problems (00:24:52) Explores how phone answering issues can be mistaken for marketing problems. Adapting to Change in Business (00:26:06) Encourages business owners to evolve with industry changes and invest in staff training. Challenges in Leadership (00:27:19) Discusses difficulties in communicating effectively with staff and the importance of peer learning.The Value of Training (00:31:53) Argues that investing in training can sustain or even improve business revenue. Setting Staff Up for Success (00:33:27) Emphasizes the responsibility of leaders to properly train staff for their roles. Motivation for Collaboration (00:34:23) Explains the drive behind the coaches to organize training sessions for struggling clients. Helping Others Succeed (00:35:50) Emphasis on the joy of witnessing others' success and mentorship in the industry. Overcoming Training Paralysis (00:36:27) Addressing confusion in training and providing guidance to help shop owners move forward. Value of Training (00:41:49) Discussion on the impact of trained salespeople on business success and owner satisfaction.
    • By Transmission Repair
    • Fast Free Shipping on All Orders Over $50
      The Secret to Getting Job Authorizations In Your Auto Repair Shop #podcast
