We just performed a heater core replacement for a 96 Ford E350. All Data book time for the job is 7.3 hours. The job took a considerable amount of time LONGER to complete the service. This job ended up taking 12 man hours to complete. Just wanted to get input from some other shops that have performed heater core replacements and if they all take longer than the estimated book time. Also, do you typically charge X hours over book time for a job like this for the estimate?
We always mark up book time 20%, except maintenance items. We also do our best to make sure we build an accurate quote before presenting to the customer. On big jobs like that, I usually ask the guys if the time I'm getting ready to sell sounds accurate and if we can think of anything else we should charge for. I've toyed around with marking up stuff more once they reach a certain age, but nothing in writing yet.
On a 96 I probably would have charged at least 10 hours, plus evac and recharge, plus coolant service. So probably about 11.5
Agree, book time is accurate...if your working on new cars! We always mark it up a touch and if it's a problem (corrosion, tough job, etc) we explain to the customer were increasing the labor for these reasons over what we typically would charge. We've recently done a job one a lifted vehicle (custom 15"+ lift) - that customer was charger almost double the labor. I explained to him we weren't actually interested in doing the job - but if I was going to do it that it was going to be how much it was. Obviously he didn't like it, but we did the job!
I should have added, I never ever tell a customer how many hours the job calls for, or how much I've marked it up. I only speak in dollars to fix the car. I might indicate that the job is very labor intensive, but that's it.
You failed to give exact info for the vehicle but when I checked Mitchell, Motor and Chilton with various engine, transmission and sub-model configurations for a 1996 Ford Econoline I fail to see any time estimates anywhere near your stated 7.3 hours. In fact they are all much less which confuses me. Is it possible that the vehicle was mis-identified on your post?
For a 1998 5.4 Expedition Mitchell allows 7.0 for the core + 1.4 for evac/recharge of A/C = 8.4 hrs.
Was anything else required such as hoses, coolant flush, initial review/diagnosis?
Either way this is a long, tedious job that I would normally recommend go to the dealer. I happen to be busy enough to have that luxury. If I had to do the job I would go in at 9-10 hours PLUS the unknowns which I noted above. Sorry you wound up short but your tech possibly learned something during that job and you definitely did.
book time (Mitchell) is 7.0 or 4.3 warranty time. That means it takes an experienced tech 4 hours to do the job when the truck is fairly new, 7 hours for everyone else with a service manual. If it took your guy 12 hours he is either slow or inexperienced or didn't review the proper R&R procedure before starting the job.
That being said we rarely do heater cores that call for more than 3 hours because we don't do them every day, old cars have plastic parts that break easily, and it just ties up too much time. I can do 10 control arms or brake jobs in the time it takes to do one nasty Jeep or S10 heater core.
I go by Chilton labor guide times as long as it's a stock vehicle. Certain things will extend the time, rust, aftermarket add-ons, etc..those have to be added on. My inexperience cannot be a factor, though...
If it is stock, and I have never performed the job....it may take longer...just the way it is. Other jobs I can beat time on....it all evens out and makes it honest.
Next time that job comes around I may know a shortcut and will do the job quicker, thus gaining my time back from the previous job.
Just noticed i had a similar situation involving heater core. What i tend to do is add .2 per year of vehicle for most of my repairs. in the case of a 1996 it would add approx 4 hrs to labour guide. gives room for rust,siezed componants etc.. seems to work well. I try to monitor repairs like that closely so if i am in it at 5 hrs and know i will be over,i consult the customer. most people understand as long as they are kept in the loop so to say as what is going on..
Love Chucky112233 idea. Just did a heater core on an Audi, multiplied time by 1.5 and still lost our butt. Took over 20 man hours to get the dumb thing out. Never again. I agre with JimO and will send to dealer next time....
Richard
Edited by Truett
Quote it high always. If your tech blows the time out of the water then comp the next oil change to make up for the increase of price with th customer. Never told them you quoted high or they will think you quote everything high, just coupon a oil change and everybody is happy
Swag Master, I know what you mean. We installed both lower control arms yesterday on a Nissan Quest, performed the alignment, and took less than two hours. Client was happy and we were happy!!
I can personally have had heater cores I have done in and out in a single day. I know techs I have had working for me sometimes will take 12 hours. If you have your guys do a few of them then they get the experience and the time to do it starts to drop, just like with any job.
I personally would be happiest if we never did another heater core ever. With the exception of oil leaks which we shy away from cooling system problems cause the most headaches. The heater core failed because of an acidic cooling system. Caused by neglect. Every other gasket/seal/part has been affected. We provide a service our regular customers that's the only reason we do these garbage jobs.
I have access to all the book times but we always go with Chilton severe time- they are the highest and never let me down.
Once I quote a customer, unless there is a really good reason, I stick to it. Last time we did a heater core, customer had aftermarket radio he installed himself and there were wires EVERYWHERE. Lost our butt on it but kept the price the same. SHould've charged more but didn't- we ended up cleaning up the wires for him as well. Our shop is rated 4.9 out of 5 with over 130 reviews and that's how we keep it.
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
      Episode 209 - The Path to Becoming a Rock Star Service Advisor with Samantha Higdon
      Introduction to the Podcast (00:00:01)  The podcast begins with a welcome message from the host, Brian Walker. Guest Introduction (00:00:10)  Brian introduces co-host Kim and guest Doug DeLuca, owner of Boca Auto Fix. Overview of Boca Auto Fix (00:00:51)  Doug shares details about his auto repair shop, including its location and age. Hiring an Apprentice (00:01:09)  Doug discusses the recent hiring of an apprentice and the journey leading to this decision. Challenges in Hiring (00:02:13)  The speakers reflect on the difficulties shop owners face in finding and hiring young talent. Marketing Journey Begins (00:03:02)  Discussion shifts to Doug's initial marketing efforts and his involvement in content creation. Background in Technology (00:04:07)  Doug explains his previous technology background and how it influenced his approach to marketing. Learning SEO and Marketing (00:04:45)  Doug describes his self-taught journey in SEO and digital marketing after opening his shop. Realizing Marketing Needs (00:06:14)  Doug reflects on his initial assumptions about marketing and the reality of attracting customers. Understanding SEO Basics (00:08:09)  Doug shares his insights on SEO and the learning process involved in mastering it. Frameworks in Marketing (00:10:25)  The conversation explores the use of frameworks in both auto repair and marketing strategies. Adopting "They Ask, You Answer" (00:11:23)  Doug discusses his experience with the "They Ask, You Answer" philosophy in content creation. Writing Blogs for Customer Engagement (00:12:21)  Doug explains how he uses customer inquiries to create relevant blog content for his shop. Experience at a Quick Lube (00:13:29)  Doug shares his firsthand experience at a quick lube to highlight differences in service quality. Experience Comparison (00:14:06) Doug shares his experience of visiting a competitor's shop to understand customer perception and service quality. Proactive Client Advocacy (00:14:57) The team discusses the importance of guiding potential clients to the right service provider based on their needs. Sponsorship and Marketing Tools (00:16:13) Brian introduces RepairPal, highlighting its benefits for attracting new customers and building trust. Customer Loyalty Apps (00:17:51) Brian discusses the advantages of using App Fueled to create customer loyalty programs for auto repair shops. Incognito Visits (00:18:20) Doug talks about visiting a competitor's shop incognito to gain insights without revealing their identity. Collaboration Over Competition (00:19:09) The speakers explore the idea of referring customers to other shops and building relationships in the industry. Challenging Competition Norms (00:20:20) Brian reflects on inviting competitors to the podcast, emphasizing collaboration over traditional competition. Marketing Involvement (00:22:42) Doug explains the ad hoc nature of their marketing efforts and the role of social media in their strategy. Community Involvement (00:27:41) Doug shares their family's volunteer work and how it integrates with their business's social media presence. Engaging the College Market (00:28:51) Doug discusses how 30% of his clients are college students and their marketing strategies. Collaborating with Local Professors (00:31:18) Doug shares his experience working with a marketing professor for student analysis of his business. Challenges of Seasonal Demand (00:32:24) Discussion on the impact of seasonal changes on business demand and local marketing efforts. Starting with Marketing (00:34:02) Doug advises new shop owners to listen to podcasts and conduct online research for marketing. SEO as a Long-Term Strategy (00:35:08) Doug explains the importance of SEO and its long-term benefits for business growth. Understanding Competition (00:36:44) Doug emphasizes the need to analyze competition and not assume marketing strategies will work universally. The Importance of Data (00:39:08) Doug highlights the role of data in assessing marketing effectiveness and making informed decisions. Nuances of Market Dynamics (00:41:14) Discussion on how geographical and seasonal factors affect marketing strategies in auto repair. Client Avatar and Marketing Alignment (00:42:13) Doug explains the significance of understanding the ideal customer for effective marketing strategies.  Overcoming Diagnostic Fee Challenges (00:43:09) Discussion on how Doug has adjusted his approach to diagnostic fees to improve customer conversion. The Importance of Evaluation Fees (00:43:40) Discussion on the role of evaluation fees and their impact on shop maturity. Improving Customer Communication (00:44:09)  Insights on enhancing customer explanations regarding services and processes. Coaching and Competitive Analysis (00:45:03)  How coaching helped refine service policies and improve customer relations. Content Creation and Marketing Strategy (00:46:32)  The significance of creating content for customer engagement and marketing. Duck Duck Jeep Initiative (00:47:05)  Fun marketing strategy involving ducks to engage with the local Jeep community. Value of Customer Feedback (00:48:46)  Importance of understanding customer inquiries and improving service based on feedback. Contact Information for Doug DeLuca (00:49:29)   Doug shares how listeners can reach him for further inquiries.
