Shift Happens
Jo was a new customer referred by an old-time regular. Her little KIA had a transmission problem that seemed to be getting the best of the transmission shop. The story goes that the SUV was constantly in limp mode, and would never shift properly… ever. As it always seems to be the case when a simple problem can’t be solved simply, somebody started the diagnostics off in the wrong direction. Little did I know this was a simple problem…. But, as I see it, each and every type of diagnostic work that you do requires a certain step by step procedure that you must follow. Miss a step, or completely overlook a step, usually means you’re going to miss that simple problem all together. This was no exception.
From what information I could gather the person who diagnosed it at the transmission shop wasn’t the same person who installed it. So after the tech put the last bolt in the transmission, he set the car out front, and told the front office, “Got the transmission in that KIA.” The front office considered it done, and the call went out for Jo to pick it up. She didn’t make it around the block before she was back at the front counter in a “not-so” pleasant mood. You can just imagine the situation at the counter… not pleasant I’m sure. After some deliberation, and very little diagnostics the transmission shop came up with the conclusion that it must be a bad transmission. Luckily, Jo’s ride that had brought her there was still in the parking lot, so she left the KIA for them to re-do the whole job again.
A week later, it was supposedly done. This time a different tech had installed the second transmission. Unfortunately, he made the same mistake as the first tech. When Jo came to pick up her car the shop owner took her for a ride to be sure that the repairs were made to her satisfaction. It was a short drive… This time, the owner said he was going to pay for the transmission, and would even purchase one from the dealership just to be sure it wasn’t their mistake in rebuilding it. But even the dealer transmission failed to shift properly. The tranny shop was at a loss, they decided to make a few calls for some help, and that’s when my phone rang.
Now, I’m not one to diagnose anything over the phone. I just don’t think it’s a smart way of taking care of such problems, because you never quite know what you’re getting into. But the tranny shop owner sounded desperate, and now the repair costs were coming out of his pocket. From his frantic explanations of no codes, no shift, and no idea of the problem, he kind of put me on the spot … so … I suggested a computer. Heck, why not… ya’ changed the tranny 3 times for Pete’s sake, obviously that ain’t’ it. I probably shouldn’t have done that, but I think he wanted to try and save as much money as possible without resorting to taking it to another shop.
Well, a new TCM didn’t work either…. Now, the car is finally coming my way. Jo was a little unsure whether or not there was anyone out there who could find the problem, but her friend told her that it couldn’t hurt to let me see what I could do for her. I’ll give it a try.
When the car showed up at the shop I took it around the block once to verify the condition, and then put it up on the lift. While it was on the lift I decided to drop it into gear and check it against the scanner. To my surprise, it shifted perfectly. I’m not kidding… absolutely perfect. I dropped it back on the ground, and went for a ride again. I didn’t even make it around the first corner… stuck in limp mode just as it was before, this dang thing can’t pull itself out of a pot hole.
Back up on the lift, and wouldn’t ya know it, shifts perfectly… AGAIN! What’s the deal here? I did it several times, just so I could be sure of the results I was getting. After a few trips I checked the wiring to the transmission while it was on the ground. Oh, oh, the main ground to the TCM wasn’t there. How in the world was it there when it was in the air? AH HA! It’s moving the wire! Yes, it was moving the wire alright, and a few more than just the TCM ground lead. The locator page showed the TCM ground wire was bundled with several other ground leads that were all attached to the main chassis ground… which wasn’t attached to a thing, but was dangling by the battery box.
Turns out the whole problem started when she had her battery changed at a department store repair shop, and they didn’t have the right size to fit the car. They disconnected the chassis ground wire, so the taller battery would fit.
When I told Jo what I found, the two of us pieced together the how and why it happened. Her only comment was, “Well, shift happens”.
All said and done with, the transmission shop paid for the entire repair, and gave her back what she spent with them. Everyone involved was glad to have the problem solved, and the car back on the road as good as new. I like this gal, she’s become a regular at the shop these days. What a card! Always has some sarcastic comment for me, but at the same time a very understanding nature and takes life in stride. I’d love to have a couple of dozen customers just like her.
As she always tells me… “If you can’t live on the bright side of life… start polishing the dull one.”
Last week I got an email from a repair shop in Ohio that used this story as a way to fix their customers car. Almost identical situation.
Makes a guy smile from ear to ear thinking that a silly little story helped out a fellow repair shop.
awesome.
For the old timers around here, you've seen this story before. Ok Ok, got lazy this week... LOL didn't get anything worthwhile wrote down, but... this story kept me thinking of what the other repair shop did to fix the car. So, I thought I'd share it again.
Gonzo, I loved it! You had me reminiscing about a 2006 Nissan Altima that came in with a crazy electrical problem.
I am an electronics kinda guy, so I will give the $1,000,000 dollar secret away to you guys. After I tell you about this Altima.
The customer came in and told us the car had been to the dealer and other numerous shop and they could not fix her car. The problem was that the car would go into limp mode from time to time and it would become "undriveable".
It didn't do it all the time, but just some times when it would rain or the weather was cold. There would be no codes, but when it failed it would light up like a Christmas tree and a whole slew of codes would pop up on the scanner.
When we checked it, the first thing I noticed was that the battery terminals were heavily sulfated. This was the first clue that the prior techs checking this car didn't do proper diagnostics. I also noticed that there had been some cosmetic repair work. I asked the customer if the car had been in an accident, and she said that yes, there had been a fender bender that required the car a/c condenser replaced and some other "front" parts.
I used Mitchell to find all the grounding points and found a plastic shim on one of the main ground points for the wire harness. Having seen a problem similar to this before, I took the car for a drive to see if I could reproduce the problem. I turned on all electrical loads and while driving on a vacant back road slammed on the brakes. Guess what, when the ABS activated the car when berserk, lights flickered and then shut off. I knew right then, I had an electrical grounding problem.
Limped back to the shop, cleaned the battery terminals and re-grounded the harness, went back out and did my little test, no problem. Had the master tech give it the "second pair of eyes" once over, and called the customer to pick up her car, She has been a regular for about four years, and has become one of our biggest fans.
So, the $1,000,000 secret is to always begin with the very basics, don't assume anything, always check for clean solid power, this will solve a good 80% of your problems.
awesome.
Great story, and I agree - that's the best feeling in the world getting an email like that.
HarrytheCarGeek, I had a similar problem not to long ago, a 3.5 nissan don't recall if it was a maxima or altima, but it kept having multiple cylinder missfires that kept changing cylinders. The car had been two at least two other shops and along the way it had all the coils and plugs replaced the owner was told it had a bad computer.
I got the car in the shop took it for a test drive noticed two things right off the bat, when first started the instrument cluster was a second or so behind the starting of the engine (didn't register for a split second), then when driving the car it didn't feel right shifted a little funny just felt off.
Pulled the car back in the shop and started with basics power and ground connections, found that the ground cable from the battery goes to a little bracket bolted to the back of the transmission, the bracket and the cable end were very rusted. I took the bracket and cable off took them over to the wire wheel cleaned them nice and shiny gain took some sand paper cleaned the trans up applied a very thin coat of dielectric grease put everything back together presto car started fine gauges right in time with the engine and it drove great.
The customer came back two days after picking the car up and gave me a $100 dollar tip said he had spent hundreds of dollars trying to get the car fixed and I charged him 1.5 hours labor . He said the car had not run that well in a long time he was so pleased with the price and the out come. I find that now a days with all the electronics in cars a lot of people over look the basics and that is where we all need to start sometimes the strangest problems are the easiest to fix. We have to learn to crawl before we walk , start with the basics first.
      Doug@bocaautofix.com
      Introduction to the Podcast (00:00:01)  The podcast begins with a welcome message from the host, Brian Walker. Guest Introduction (00:00:10)  Brian introduces co-host Kim and guest Doug DeLuca, owner of Boca Auto Fix. Overview of Boca Auto Fix (00:00:51)  Doug shares details about his auto repair shop, including its location and age. Hiring an Apprentice (00:01:09)  Doug discusses the recent hiring of an apprentice and the journey leading to this decision. Challenges in Hiring (00:02:13)  The speakers reflect on the difficulties shop owners face in finding and hiring young talent. Marketing Journey Begins (00:03:02)  Discussion shifts to Doug's initial marketing efforts and his involvement in content creation. Background in Technology (00:04:07)  Doug explains his previous technology background and how it influenced his approach to marketing. Learning SEO and Marketing (00:04:45)  Doug describes his self-taught journey in SEO and digital marketing after opening his shop. Realizing Marketing Needs (00:06:14)  Doug reflects on his initial assumptions about marketing and the reality of attracting customers. Understanding SEO Basics (00:08:09)  Doug shares his insights on SEO and the learning process involved in mastering it. Frameworks in Marketing (00:10:25)  The conversation explores the use of frameworks in both auto repair and marketing strategies. Adopting "They Ask, You Answer" (00:11:23)  Doug discusses his experience with the "They Ask, You Answer" philosophy in content creation. Writing Blogs for Customer Engagement (00:12:21)  Doug explains how he uses customer inquiries to create relevant blog content for his shop. Experience at a Quick Lube (00:13:29)  Doug shares his firsthand experience at a quick lube to highlight differences in service quality. Experience Comparison (00:14:06) Doug shares his experience of visiting a competitor's shop to understand customer perception and service quality. Proactive Client Advocacy (00:14:57) The team discusses the importance of guiding potential clients to the right service provider based on their needs. Sponsorship and Marketing Tools (00:16:13) Brian introduces RepairPal, highlighting its benefits for attracting new customers and building trust. Customer Loyalty Apps (00:17:51) Brian discusses the advantages of using App Fueled to create customer loyalty programs for auto repair shops. Incognito Visits (00:18:20) Doug talks about visiting a competitor's shop incognito to gain insights without revealing their identity. Collaboration Over Competition (00:19:09) The speakers explore the idea of referring customers to other shops and building relationships in the industry. Challenging Competition Norms (00:20:20) Brian reflects on inviting competitors to the podcast, emphasizing collaboration over traditional competition. Marketing Involvement (00:22:42) Doug explains the ad hoc nature of their marketing efforts and the role of social media in their strategy. Community Involvement (00:27:41) Doug shares their family's volunteer work and how it integrates with their business's social media presence. Engaging the College Market (00:28:51) Doug discusses how 30% of his clients are college students and their marketing strategies. Collaborating with Local Professors (00:31:18) Doug shares his experience working with a marketing professor for student analysis of his business. Challenges of Seasonal Demand (00:32:24) Discussion on the impact of seasonal changes on business demand and local marketing efforts. Starting with Marketing (00:34:02) Doug advises new shop owners to listen to podcasts and conduct online research for marketing. SEO as a Long-Term Strategy (00:35:08) Doug explains the importance of SEO and its long-term benefits for business growth. Understanding Competition (00:36:44) Doug emphasizes the need to analyze competition and not assume marketing strategies will work universally. The Importance of Data (00:39:08) Doug highlights the role of data in assessing marketing effectiveness and making informed decisions. Nuances of Market Dynamics (00:41:14) Discussion on how geographical and seasonal factors affect marketing strategies in auto repair. Client Avatar and Marketing Alignment (00:42:13) Doug explains the significance of understanding the ideal customer for effective marketing strategies.  Overcoming Diagnostic Fee Challenges (00:43:09) Discussion on how Doug has adjusted his approach to diagnostic fees to improve customer conversion. The Importance of Evaluation Fees (00:43:40) Discussion on the role of evaluation fees and their impact on shop maturity. Improving Customer Communication (00:44:09)  Insights on enhancing customer explanations regarding services and processes. Coaching and Competitive Analysis (00:45:03)  How coaching helped refine service policies and improve customer relations. Content Creation and Marketing Strategy (00:46:32)  The significance of creating content for customer engagement and marketing. Duck Duck Jeep Initiative (00:47:05)  Fun marketing strategy involving ducks to engage with the local Jeep community. Value of Customer Feedback (00:48:46)  Importance of understanding customer inquiries and improving service based on feedback. Contact Information for Doug DeLuca (00:49:29)   Doug shares how listeners can reach him for further inquiries.
      chris@autofixsos.com
