Its time to invest in some new tools or methods for intake valve cleaning on direct injected engines. Using picks and small brushes just doesn't cut it. The process takes way to long. We do plenty enough VW/Audi work alone to make it worth while to have a special machine for this. I've heard of people using soda or shell blasting. Is there are tool or method out there that can use this process and contain it to the intake port without getting material everywhere?
What do you guys do?
Thanks!!
We use walnut blasting
What machine do you use? Do you have a way to contain it to the intake port?
For the BMW applications we buy the factory tool which is a cast alum part that has a vacuum cleaner hookup and a small hole to insert a blasting nozzle. Works great.
Ever take a moment to consider BMW advertises the longest oil change intervals in the industry and also is the only manufacturer to train techs in walnut blasting away carbon deposits? Food for thought.
alfredauto,
I know the euro's have been dealing with this for a while, but we are starting to see both domestic and asian GDI engines that have carbon build up issues. The Valvoline product shows some ability to reduce the built up carbon on the valves, but we have not yet used it on a car with significant deposits.
Its a direct injection issue though, BMW just admits the problem. VW/Audi engines are WAYYYY worse and they don't admit its a problem ,they blame it on poor fuel quality. Which makes perfect sense since since the part effected doesn't come in contact with any fuel ever :rolleyes:
Not really related... but I saw this on my FB page.... ridiculous...I guess it would work, but I'd bet you have a better chance of burning down the shop.
https://www.carthrottle.com/post/the-coolest-possible-way-to-clean-out-a-tdi-intake-manifold/
I used to do that to clean VW TDI manifolds, they are cheap enough new now that its not even worth the time.
On another note, the products like BG and valvoline chemical cleaners might be ok if you sold them as regular preventative maintenance, but if you have a rough cold idle and a misfires already that stuff is not gonna work. Plus I don't want that huge chunk of carbon coming off and being smacked up in the cylinder. Or have it hold a valve open and have it tap the piston. That service might have you buying an engine. The only fix is the right fix, mechanical removal and inspection.
      Getting involved in your community is powerful, but how do you share your efforts without sounding boastful? There’s a fine line between successful and selfish self-promotion, and in this episode, Brian and Kim Walker discuss how to highlight your work with authenticity and gratitude—not ego.
      We’ll discuss framing your message to focus on the cause, aligning community service with your company culture and purpose, and sharing stories that connect and inspire rather than just promote. Plus, we’ll share real-life examples—like our team’s work with Our Daily Bread Food Bank—and how to encourage others to get involved.
      Tune in now to learn how to support your community while staying humble and making a real impact!
      Start with Why - By Simon Sinek
      Commission Mankind
      Introduction to the Episode (00:00:10) Brian introduces the podcast and the topic of community involvement. Topic Suggestion Acknowledgment (00:00:34) Brian mentions Doug DeLuca's suggestion for the episode topic. Sponsor Acknowledgment (00:01:00) Brian thanks RepairPal for sponsoring the episode. Technical Issues Discussion (00:01:30) Brian and Kim discuss technical issues and Brian's experience with braces. Community Involvement Concerns (00:03:44) Kim shares a friend's hesitation about promoting community involvement due to fear of appearing boastful. Successful vs. Selfish Promotion (00:05:44) Discussion about the fine line between effective promotion and self-promotion. Promoting Community Engagement (00:07:24) Kim emphasizes the importance of spacing out promotional posts about community involvement. Starting with Gratitude (00:07:46) Kim suggests starting messages about community involvement with expressions of gratitude. Importance of "Why" (00:09:09) Discussion on the significance of explaining the reasons behind community involvement. Examples of Community Involvement (00:09:15) Brian and Kim share experiences of their community service activities. Promoting Community Work (00:11:25) Brian discusses the importance of promoting community service to demonstrate business values. Messaging about Community Involvement (00:12:21) Kim provides examples of how they communicate their community involvement on social media. Team Engagement in Community Work (00:14:20) Brian reflects on the team's connection with community members during service activities.  Closing Sponsor Acknowledgment (00:15:14) Brian thanks RepairPal again for supporting the episode. Community Engagement Strategies (00:15:26)   Discussion on how RepairPal helps auto shops gain customers through certification and fair pricing. Customer Loyalty Apps (00:16:25)  Introduction of App Fueled, a customer loyalty app designed for auto service shops. Highlighting Community Work (00:17:11)  Tips on emphasizing organizational missions instead of personal achievements in community involvement. Authentic Community Involvement (00:17:54)   The importance of sharing community efforts without seeking personal recognition or return. Sharing GoFundMe Campaigns (00:18:51)  Encouragement to promote charitable causes without boasting about personal donations. Industry-Specific Support (00:19:16)  Discussion on giving back to the auto repair industry and local communities. Respecting Privacy in Sharing (00:19:39)  The balance between sharing community involvement and respecting the privacy of those served. Educating Marketing Teams (00:22:43)  The need to guide marketing teams on how to portray community involvement authentically. Collaborating with Other Organizations (00:24:17)  Benefits of partnering with local businesses for community service efforts. Celebrating Local Teams (00:25:38)  Highlighting local sports teams and community events to promote goodwill. Telling the Story of Donations (00:27:40)  Importance of sharing the personal connection behind charitable contributions. Personal Anecdotes from Mission Trips (00:28:28)  Sharing impactful stories from mission trips to illustrate the importance of community support. Personal Anecdote on Community Support (00:29:29)  Kim shares a personal story about supporting organizations that assist her brother with disabilities. Encouragement to Join Facebook Group (00:30:44)  Kim invites listeners to join their Facebook group for further engagement and community building. Request for Podcast Reviews (00:31:03)  Brian asks listeners to leave reviews for the podcast, emphasizing the importance of feedback. Closing Remarks and Sponsorship Acknowledgment (00:31:36)  Brian concludes the episode, thanking sponsors and encouraging listeners to tune in next week.
