I did a free trial with them a year or two ago. I don't remember much about it honestly. So it must not have been something I saw as worthwhile. EDIT, I was thinking this was a labor guide and repair data thing like all data. I agree with Mspec, it's a terrible thing for the industry. They can sign up some lowball shops, then people can check those prices and tell you that your too high.
Whether it is the worst thing or the best thing for the industry it is here. We are going to have to deal with these type of sites. Find a way to make it work for you and your business.
Edited by Tires Too
I use it periodically to make sure I'm charging enough. I find some times I'm under charging for some things, even though I might be hitting my margins. I never lower my prices to match it though. My warranty is better than what they call for
I don't believe that is necessarily true. I have not seen these sites/service gain much traction. I have only heard RepairPal spouted once in 10 years of operation.
Work's great for me. Well worth the $200 a month I spend. I get 8-10 new customers a month. I don't know if any of my customers use the estimator. I use it a few times a week just to make sure I am charging properly or if someone questions the price.. They are a review site and they will get you some reviews to start out with. They will vet your shop. Verify training and equipment. They will also call your customers to verify you are on the up and up. They will ask those customers for reviews as well and then publish them for you. If you don't have a lot of reviews out there, this is a great place to start. They are partnered with AARP and now USAA. I never got an AARP member, but I have got a few from USAA. They record all of the customers calls they send you (which you can listen to) and send you an email as well. Very easy to track what they are doing for you.
It probably works better in metro areas where there is a lot of competition. Maybe not so well in small towns or rural areas.
we have it as well and have the estimator on our website as well. what yall afraid of? the way you talk would make me fear going to some of your shops.
Is price the only deciding factor in where you get your car serviced or does trust play into the decision? Repairpal trains customers to focus on the price and assumes that the car has already been PROPERLY diagnosed and that all repairs are the same.
I was a Master Lexus Technician, ASE Master Certified with my L1, and have over 9 years experience working exclusively on Lexus vehicles. I will tell you that the dumbest thing I can do is act cocky enough to give a price before properly inspecting the car. That's a sure fire way to piss off a customer. Quote them one price, then have them leave paying more, and that is exactly what repairpal does.
*Oh, wait, they will also charge you to do it if you're willing to sign up.
so you deal with the customers too? Yall sound like you never talk with your customers, if you want clarity, discuss it. If you take a job in and they got a quote are you just gonna do it without discussing anything with them?? Plus, have you even seen what it says on their site? Here is what it says on a water pump.
Best Practices
When replacing the water pump, the drive belts and/or timing belt may need to be removed. The belts should be replaced if they show signs of wear or coolant damage.
The entire cooling system—including all the coolant hoses and fittings, radiator, coolant fan(s), and fan clutch (if equipped)—should be inspected when replacing the water pump.
To help prevent future issues, we recommend replacing the thermostat when the cooling system has been opened for repairs (e.g. water pump or radiator replacement) or during a system flush.
Common Symptoms
Water pumps require replacement if they begin to leak coolant or become noisy. Leaking water pumps can result in damage to the drive and timing belts.
A failed water pump can be caused by problems in the cooling system, such as a failing thermostat, radiator, or head gasket.
So, it seems to me you just need to talk with your customers, we do and dont have problems, we are also priced to be within their ranges, if you want to price your repairs out of their range then thats your business.
You want to make this confusing or so detailed people dont understand it or what? i dont understand the concept of what exactly are you going to do that makes this a really bad thing? i bet i know :)
Sorry, I just don't understand all of the angst going on in this thread. How they come up with estimates. They poll several shops in your zip code or immediate area (that's why they ask for the zip code). They find the lowest shop rate and the highest shop rate in that area. They take OEM list parts prices for the high end and available aftermarket parts list prices for the low end. Hens your high and low end. Theory is you should be in that price range cut and dry. If your too high on your quote there is not much to say, your going to have to sell the difference.. Too low, you may be leaving money on the table. It's no more perfect then the flat rate guides. It's just a tool for the customer to try and gauge if their getting a fair shake.
There is a huge fallacy in polling shops in your area. For example my area is some of the highest cost of living in the country however we have some of the lowest labor rates for independents. We also have some of the lowest competencies when it comes to technicians. The dealerships do charge appropriately for the cost of living as well as the training and competency their techs have. With that being said if we are to be "within range" of the shops around us we would have to lower our labor rate and pricing on parts which would not allow us to provide the level of service and afford to have my techs well trained. There is just such a huge variance in many factors such as cost of living, state of aftermarket industry per area, competency of shop owner/business/technicians.
RepairPal estimator tool creates a price focusing and makes our services commodities. No matter how you look at it our services will always be different and our methods and cost of doing business will be different. My techs and service advisors are highly trained and my facility is better equipped than all the independents in my immediate area and I know this for a fact. We also provide more value, more benefits and treat our customers completely different than other shops. For all those reasons I will not be racing to the bottom with inferior outfits.
Websites like repairpal, automd and others are not going away.
Customers are using these sites to protect themselves and to
make sure they're not being taken advantage of.
So, those websites didn't create the problem. They're filling a
need the public has.
In regards to using those sites for marketing purposes...
Those sites can send traffic to shops that feel they need more
traffic.
The problem with any form of marketing is:
Unless you know how to convert that phone call or walk-in,
into an appointment...
You've wasted your money (and your time).
Let's face it. Every caller has a pen and paper in front of
them with a list of shops they're calling.
Your service advisors need to be effective at communicating
what sets you apart from all of the other shops that customer
is calling.
Otherwise, you will be competing on price.
So, in most cases, you're better off investing your money
in service advisor training rather than on more marketing.
By the way, any form of marketing based on discounts or promotions...
whether it be a coupon on your website, direct mail, PPC
or any other price-driven promotions means...
You are reinforcing the commodity mindset.
In other words, you're actually training your customers to be on
the lookout for more discounts from you - or to check with your
competition - to see if their discounts are better than yours.
I was doing an onsite training, in a shop recently. The service
advisor said to a long-time customer, in the checkout process...
"Just so you know, if you provide us with your email address,
we'll send you coupons and promotions."
The customer replied, "Wow! I never thought of looking for
coupons for auto repair services! Thanks for the idea!"
When I pointed this out to the shop owner, he realized all of
his marketing methods were teaching his customers to become
coupon clippers and unless his coupons were better than his
competitors' coupons, he was fighting a losing battle.
He was also surprised to discover that even though his traffic
was up, his sales were down, because most of the customers
weren't buying anything other than the promotion.
Since then, he's been able to cut out almost all of his marketing.
Because now, his service advisors are selling almost every
single job because they know how to communicate to the customers
what sets that shop apart from all of the competition, in his area.
Here's a video I did on one of the biggest misunderstandings about
auto repair shop marketing:
  On 3/11/2016 at 7:36 PM, Jeff said:
So Imcca you are willing to go to the low end of the quote if that is what the customer wants? As I said it wasn,t the estimate guide that drove me away from Repair Pal. And going off half cocked at the others in here dont warrant much respect. We all have our business models. If you want to cater to bottomers be my guest! Repair Pal DID NOT fulfill all they advertised!
You mad bro?
we actually are closer to the high end and have NO problem with discussing it with the customer. We show them why we are there and why we provide better service. Come out of the woods and read Elons post, especially the part in bold, just because you don't like it doesn't mean it wont work.
I tried Repairpal and decided to not keep paying for the service. On their end, they do a great job. They researched my shop, came up with honest reviews, and put my shop out there in my zip code area. Unfortunately 99.9% of the calls i got from repairpal referrals were " when can I get my head gasket done?" They got themselves a low estimate on replacing just the gasket, ignored all the other advice, and dialed me. We don't do slip and slide head gaskets so it was a lot of rejecting future customers. Ultimately I spent over $1000 in 6 months and got back exactly $83.00 on a diagnosis we did. Your results may vary.
We usually come on the high side of repairpal.
Objectively, maintenance is a commodity service. Intermittent failures and diagnostic work are not well paid if you don't have highly trained techs to bill by the job instead of by the hour. One of the priciest investments has been the four channel PicoScopes for each shop, plus master tech training to catch intermittent and difficult to diagnose problems.
Good trusted customer service will keep you in business, but pricing will continue to be very tough with customers expecting commodity pricing.
Don't give your work away for free, stay strong, many people will go out of business in this upcoming round. Downsize if you can, cut all needless expenses, layoff the people that you don't need, and take care of the ones that are going to be with you for the long haul.
We have used Repair pal for approx a year and it does bring in calls , You do have to be good on the phone as always to bring clients in off this line - It does attract some bottom feeders which is upsetting due to most of are marketing does not bring the bottom feededer client. The phone recordings our very nice to see how your staff is treating clients and following protocal.
Towing side of it we see some , no Arrp which is ok that would cost 10 % any way's . What I have seen we are very competitive when using Repair pal price guides.
We have many features and benifits so if it is a low priced shopper they are short lived.
Thanks DanR
  On 3/16/2016 at 11:48 AM, Jeff said:
@ Immca..mad...nuttin to be mad about. And I do read/follow Elon. Have spoken to him personally as a matter of fact. Like I said I tried RP w/o success. Overpriced with no guarentees. I tend to be on the high side also. I feel tho that these type of sites "degrade" the proffessionalism (?) of our trade. Oh and I checked out your web site...couldn't find the estimator anywhere?
lol, its on the home page
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Dan Clark explores how emotion surpasses reason in driving action, particularly in sales, emphasizing the power of storytelling to activate specific brain chemicals. He shares personal experiences, including his recovery from paralysis, to illustrate the impact of belief and a strong "why." The conversation delves into societal stigmas around emotional expression, especially for men, and the importance of genuine connection. Clark further explains how leveraging brain chemistry through storytelling enhances influence and strengthens customer relationships. He concludes by stressing that businesses should prioritize deep human connections over mere transactions. Dan Clark, Hall of Fame Keynote Speaker, New York Times Best-Selling Author of 37 Books, Expert in Next-Level Leadership for Teams, Sales, and Life. https://danclark.com/ Show Notes Watch Full Video Episode The Institute of Automotive Business Excellence: https://www.wearetheinstitute.com/ Introduction of Dan Clark (00:00:00) The Importance of Emotion in Memory (00:02:47) Emotion vs. Knowledge in Sales (00:04:17) Statistics on Sales Persistence (00:04:47) The Role of Storytelling in Sales (00:05:13) Social Stigma Around Emotion (00:05:23) Mental Health and Emotional Prosperity (00:06:01) Creating Discomfort for Growth (00:07:05) Asking for Help in Mental Health (00:07:49) The Role of Feelings in Leadership and Sales (00:08:07) The Zone and Brain Chemicals (00:09:11) Emotional Connection in Sports (00:10:06) Impact of Storytelling on Audience (00:12:07) Overcoming Struggles and Emotional Growth (00:16:29) Authenticity and Emotional Expression (00:17:54) The Importance of Belief (00:18:30) Energy and Attraction (00:19:26) Authenticity in Connection (00:19:54) Personal Injury Story (00:20:31) Rock Foundation vs. Rock Bottom (00:21:21) Core Values in Business (00:22:22) The Power of Belief (00:23:08) Asking the Right Questions (00:23:51) Connecting Head and Heart (00:24:36) Physiological Responses to Fear (00:24:49) Storytelling in Sales (00:27:32) Self-Awareness in Customer Service (00:28:29) Identifying with Roles (00:30:22) Heart-to-Heart Connection (00:30:44) Story of Empathy (00:31:07)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/
      Doug@bocaautofix.com
      Introduction to the Podcast (00:00:01)  The podcast begins with a welcome message from the host, Brian Walker. Guest Introduction (00:00:10)  Brian introduces co-host Kim and guest Doug DeLuca, owner of Boca Auto Fix. Overview of Boca Auto Fix (00:00:51)  Doug shares details about his auto repair shop, including its location and age. Hiring an Apprentice (00:01:09)  Doug discusses the recent hiring of an apprentice and the journey leading to this decision. Challenges in Hiring (00:02:13)  The speakers reflect on the difficulties shop owners face in finding and hiring young talent. Marketing Journey Begins (00:03:02)  Discussion shifts to Doug's initial marketing efforts and his involvement in content creation. Background in Technology (00:04:07)  Doug explains his previous technology background and how it influenced his approach to marketing. Learning SEO and Marketing (00:04:45)  Doug describes his self-taught journey in SEO and digital marketing after opening his shop. Realizing Marketing Needs (00:06:14)  Doug reflects on his initial assumptions about marketing and the reality of attracting customers. Understanding SEO Basics (00:08:09)  Doug shares his insights on SEO and the learning process involved in mastering it. Frameworks in Marketing (00:10:25)  The conversation explores the use of frameworks in both auto repair and marketing strategies. Adopting "They Ask, You Answer" (00:11:23)  Doug discusses his experience with the "They Ask, You Answer" philosophy in content creation. Writing Blogs for Customer Engagement (00:12:21)  Doug explains how he uses customer inquiries to create relevant blog content for his shop. Experience at a Quick Lube (00:13:29)  Doug shares his firsthand experience at a quick lube to highlight differences in service quality. Experience Comparison (00:14:06) Doug shares his experience of visiting a competitor's shop to understand customer perception and service quality. Proactive Client Advocacy (00:14:57) The team discusses the importance of guiding potential clients to the right service provider based on their needs. Sponsorship and Marketing Tools (00:16:13) Brian introduces RepairPal, highlighting its benefits for attracting new customers and building trust. Customer Loyalty Apps (00:17:51) Brian discusses the advantages of using App Fueled to create customer loyalty programs for auto repair shops. Incognito Visits (00:18:20) Doug talks about visiting a competitor's shop incognito to gain insights without revealing their identity. Collaboration Over Competition (00:19:09) The speakers explore the idea of referring customers to other shops and building relationships in the industry. Challenging Competition Norms (00:20:20) Brian reflects on inviting competitors to the podcast, emphasizing collaboration over traditional competition. Marketing Involvement (00:22:42) Doug explains the ad hoc nature of their marketing efforts and the role of social media in their strategy. Community Involvement (00:27:41) Doug shares their family's volunteer work and how it integrates with their business's social media presence. Engaging the College Market (00:28:51) Doug discusses how 30% of his clients are college students and their marketing strategies. Collaborating with Local Professors (00:31:18) Doug shares his experience working with a marketing professor for student analysis of his business. Challenges of Seasonal Demand (00:32:24) Discussion on the impact of seasonal changes on business demand and local marketing efforts. Starting with Marketing (00:34:02) Doug advises new shop owners to listen to podcasts and conduct online research for marketing. SEO as a Long-Term Strategy (00:35:08) Doug explains the importance of SEO and its long-term benefits for business growth. Understanding Competition (00:36:44) Doug emphasizes the need to analyze competition and not assume marketing strategies will work universally. The Importance of Data (00:39:08) Doug highlights the role of data in assessing marketing effectiveness and making informed decisions. Nuances of Market Dynamics (00:41:14) Discussion on how geographical and seasonal factors affect marketing strategies in auto repair. Client Avatar and Marketing Alignment (00:42:13) Doug explains the significance of understanding the ideal customer for effective marketing strategies.  Overcoming Diagnostic Fee Challenges (00:43:09) Discussion on how Doug has adjusted his approach to diagnostic fees to improve customer conversion. The Importance of Evaluation Fees (00:43:40) Discussion on the role of evaluation fees and their impact on shop maturity. Improving Customer Communication (00:44:09)  Insights on enhancing customer explanations regarding services and processes. Coaching and Competitive Analysis (00:45:03)  How coaching helped refine service policies and improve customer relations. Content Creation and Marketing Strategy (00:46:32)  The significance of creating content for customer engagement and marketing. Duck Duck Jeep Initiative (00:47:05)  Fun marketing strategy involving ducks to engage with the local Jeep community. Value of Customer Feedback (00:48:46)  Importance of understanding customer inquiries and improving service based on feedback. Contact Information for Doug DeLuca (00:49:29)   Doug shares how listeners can reach him for further inquiries.
