Code 1391 keeps poping back on after several re-starts. We have replaces the crank shaft sensor, Camshaft sensor unit. Everything is aligned but the damn light comes on. Any help would be appreciated.
http://www.underhoodservice.com/whos-at-fault-top-10-domestic-diagnostic-codes-fixes/
  Quote
Chrysler P1391 Intermittent Loss of Crank or Cam Sensor Signal
This code can pop up if the PCM loses an input signal from the crankshaft (CKP) or camshaft (CMP) position sensors when the engine is running or cranking — but only if it caches 20 failures in two consecutive trips. The cause may be a bad sensor, a loose or corroded sensor connector, a defect in the tone wheel or flexplate, or a fault in the PCM itself.
Inspect the wires for any obvious problems, then connect a scan tool and look for an rpm signal, and/or the CKP and CMP PIDS. Or, you can use a scope to backprobe the sensors to look for a good output signal. If you are not getting a good sensor signal, remove the sensor and inspect the tone ring underneath it for debris or damage. If the sensors are producing good signals, the fault is in the wiring or PCM.
http://www.underhoodservice.com/diagnostic-dilemmas-getting-in-sync-with-a-couple-wranglers/
Synchronization Roulette
The next morning, the Jeep started perfectly. As the day progressed, the Jeep would produce a CE light and a P1391 code each time the engine was cranked. Obviously, the mechanical relationship between the CMP and the CKP was changing — sometimes a little, sometimes a lot. Further TSB and archival research indicated that the 4.0L historically has had a problem with the bearing seizing in the cam position sensor and twisting the housing out of synchronization with the crankshaft sensor and producing the DTC P1391 and the accompanying P0352, 353 and 351 DTCs.
20720agif_00000013820.gif Fortunately, many aftermarket scan tools can detect CMP synchronization problems in the 4.0L through a synch mode feature included in the scan tool menu, see Photo 2. Simply put, the CMP can be adjusted in the synch mode to within +/- 1 or 2 degrees tolerance.
In this case, the CMP synch was nearly perfect, which dismissed any problems with a seized cam sensor bearing. I might say at this point that I normally don’t start a diagnosis by disassembling components because a faulty connection might be re-established or a cracked circuit board might be reactivated. But, in this case, I removed the cam sensor only to discover the magnet stuck to the CMP’s shutter! See Photo 3.
20720bgif_00000013821.gif Clearly, I had taken the “scenic route” on this diagnosis by not inspecting the CMP for loose components in the first place, see Photo 4. But, the loose magnet clearly was causing an intermittent synchronization problem that had created a roulette wheel effect that resulted in the occasional slow-start or cranking/no-start complaint that cropped up after the vehicle came into the shop. The diagnostic curve ball in this case was clearly the unexpected issue of a magnet coming loose in the camshaft position sensor without causing a catastrophic failure.
Edited by HarrytheCarGeek
I used to have a TJ, and had this exact same issue, except my problem was excessive crankshaft end play. In my case, like yours I would only set the code during cranking. Sometimes, it would have an extended crank time before starting. I chased the problem on my free time for a couple of weekends, checking all sensors, and data pids. Found nothing out of the ordinary The refresh rate on many scantools is just not quick enough to capture any glitches during cranking. These systems are old and slow. You can also check the cam and crank sensors manually, by passing a flat bade screwdriver (without magnetic tip) across the tip of the sensors. I did this, while hooked up to a scope. I heated and cooled the sensor, nothing abnormal. eventually I got to thinking and said "ok, this only happens during cranking." I disable fuel delivery, hooked up a remote starter and just would crank it over and over while observing data. Nothing abnormal. I eventually caught the glitch inadvertently, when i jumped in and stepped on the clutch and cranked it with the key. Occasionally, I would lose an RPM signal. I said hmm. Cranked it with my remote starter, all is well. Step on the clutch? Intermittent loss of RPM signal. Checked crankshaft endplay, and it was out of spec by several thousands.
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
      RepairPal.com/shops
      Questions/Ideas - podcast@shopmarketingpros.com
      Running low on cash? Before panic sets in, it’s time to get strategic. In this episode of Business by the Numbers, Hunt explores practical steps to manage cash flow challenges, cut expenses wisely, and secure financing without sinking your business. Learn what options are available and how to make informed decisions to keep your shop running smoothly.
      Understand the root causes of cash flow issues to avoid repeating mistakes. Learn why preserving cash strategically is more effective than slashing every expense. Discover how to leverage credit lines, loans, and alternative financing options safely. Avoid common pitfalls, like cutting critical expenses, that can worsen financial struggles. Develop a plan to stabilize and grow your cash reserves for long-term success.
      Email Hunt: podcast@paarmelis.com
      How We Boosted Sales in 2023 Without Any Phone Calls #podcast #autorepairbusiness
