We recently took in a 2005 golf with a hole in the oil pan. It was a big hole. I made a note on the estimate that we did not know if there was engine damage because the hole was too big to fill with oil and run. When the oil pan was down we saw what looked like a pinch of bearing material squeazed out around the #1 main. We took a picture of this bearing damage then installed the pan. Added oil and car started. No power, Turbo seized. Now customer is accusing us of running the car with no oil and ruining his turbo. How would you guys handle this situation. I really don't feel like having a horrible google review calling us idiots.
Need more info: was the estimate signed or acknowledged ? Any time we have engine damage I make sure the customer signs off on the potential for a bad engine. I also a bad experience and ended up losing on the job. No win either way.
Honestly I would have stopped once the pan was off, no way that engine was gonna be good, that one gets pushed out of the bay. Note condition of vehicle on the WO when it comes in and have the customer sign it. That's the best way to cover yourself, plus its the law here in NY
It was sent to him via e mail and he replied to the e mail with approval.
Edited by Handson
This is what i should have done.
What should I do at the stage i am at now.
You didn't build, buy it or break it. But luckily for him, you can fix it. You may take a reputation hit, but he can't do anything to you. Running a turbo for a short period of time without oil won't cause a catastrophic failure. If it goes to court your insurance company will back you. The customer is all talk, the situation may be uncomfortable but just keep your head up!
Honestly the customer is just angry that they ruined their own engine and is trying to pass the blame. They don't want to be the idiot so you're stuck being the bad guy. Some people just need to blame someone else for everything. I don't know about the laws in your state but here in NY worst case is a DMV inspector investigates from the consumer protection division, they beat you up about your paperwork and waste your time. Its clear you didn't destroy the engine, doubt even a heavily customer favorable investigator would put that on you.
I think the fact that you put it back together, and started, and ran the thing gives the customer leverage to claim liability on your part. If the rotating assembly is compromised, there will be no oil pressure, or very low oil pressure. Starting and running the engine in this condition can cause additional damage (like the turbo) to engine components that require lubrication to function. Not to mention, you could be pumping shavings, contaminants, etc all through the system. For the next go round, the INSTANT you find something you were not expecting, or something additional relevant to the outcome of the repair, you put everything down, document, and discuss with the customer immediately. Don't get caught up chasing payment for the job which many shops tend to bury themselves in. and end up costing them more in the long run.
Now, I would have a sit down with the customer, and try to diffuse the situation. Talk with them, try to find peaceful means. Maybe cut him a discount for the current repair bill, or give him a coupon for a future repair. I would err more on just having the customer remove the vehicle from my shop as peacefully as possible. if it means taking a hit on google so be it. What you don't want is to marry the car/customer.
Whoa what? I disagree wholeheartedly. All it takes is a slight hiccup of oil pressure to grenade a turbo. Especially an old, probably very used turbo. I mean some manufacturers even call for bleeding of the system just to purge the air from the oil feed lines when doing an oil change. That is how important lubrication is to the TC. You also have to figure that the system was compromised to begin with. That is a giant red flag. You don't want to be anywhere near the thing, because it is as fragile as a baby's tooth.
You don't actually work on the cars do you? Lol
  • 5 weeks later...
Seems like the job shouldn't have been performed to begin with....unless I'm misunderstanding something. If the car came in with a big hole in oil pan...wouldn't first step be to ask customer what happened? Did they run over something, etc?,bc aside from from running over something, it seems that internal damage is most likely. So before even taking down that pan...you tell the customer and then sell him an engine or roll it out! I mean the hole had to come from somewhere. Seems like maybe you didn't want to pass up the dough so you let the customer choose to proceed. Problem is that the customer is NOT the professional in this case...YOU are.
Any chance this is a road hazard issue that could have insurance coverage from their personal auto. Had a similar situation a few years ago and their insurance company bought them a used motor and turbo, even though they were two tracking in a low clearance vehicle when they hit that rock and then tried to drive it home.
Update:
The customer rolled with the car without indecent. Grumbled a bit but I have not heard back since. I imagine who ever he took it to explained to him that the damage was done a while ago.
To davine4real we typically run at capacity, sometimes we are booked out one or two days in advance, sometimes up to a week. I thought I did my best prior to taking in the job explaining to the customer that he had a good chance of motor damage. It was just one of those situations where the customer tried to forget what we had discussed and had in writing.
Edited by Hands On
the burden of proof should fall on the customer - call your insurance company they may (my does) call an outside company to inspect. Hopefully you have pictures of the oil pan before you did a teardown.
I'm surprised you are not concerned about the spun bearing.
I would have dropped the suspicious bearing and a rod bearing to review before reassembly , I also would have let the client know may be more damage before reassembly his and or her choice , to continue.
Thansk Dan R.
  • 6 months later...
I agree. When they pay for something it has to be fixed. If it is going to cost more to fix it right they need to know. Every time they are going to blame you for the problems even though they weren't your fault. Try to fix everything you possibly can and they will more often than not be happy to pay the extra money to have it fixed rather than a little money for a broken car.
      Check out their podcast here: https://autorepairmarketing.captivate.fm/ If you would like to join their private Facebook group go here: https://www.facebook.com/groups/autorepairmarketingmastermindIn
      In this episode of "The Weekly Blitz," host Chris Cotton is joined by special guests Caroline Legrone and Kim Walker from Shop Marketing Pros to delve into the critical necessity of having a robust marketing plan for auto repair shops. The discussion centers around the pivotal role that a well-structured marketing strategy plays in the success and sustainability of these businesses.
      Chris, Caroline, and Kim explore the multifaceted aspects of marketing planning, emphasizing the importance of leveraging historical data to gain insights into the business's performance over time. By analyzing this data, shop owners can pinpoint slow periods and develop proactive marketing strategies that align with local events and seasonal trends, thereby optimizing their outreach efforts.
      Caroline Legrone underscores the significance of understanding past performance metrics, which can provide invaluable information for future planning. She explains how historical data can reveal patterns and trends that are crucial for making informed marketing decisions. This approach not only helps in identifying potential challenges but also in capitalizing on opportunities that may arise.
      Kim Walker, on the other hand, offers practical insights into the creation of a comprehensive marketing calendar. She shares her expertise on how to systematically plan marketing activities throughout the year, ensuring that the shop remains visible and engaged with the community. Kim's advice includes tips on scheduling promotions, aligning campaigns with local happenings, and maintaining a consistent presence across various marketing channels.
      Throughout the episode, the conversation is geared towards empowering shop owners to take control of their marketing efforts. By doing so, they can ensure sustained growth and foster stronger community engagement, even during traditionally slow periods. The episode serves as a call to action for auto repair shop owners to prioritize their marketing strategies, highlighting the long-term benefits of a well-executed plan.
      Introduction and Importance of Marketing (00:00:09)
      Chris Cotton introduces the episode and emphasizes the need for a marketing plan in auto repair businesses.
      Guest Introductions (00:01:11)
      Chris welcomes Caroline Legrone and Kim Walker from Shop Marketing Pros to the podcast.
      Discussion on Car Count Issues (00:01:48)
      Chris expresses concern over shop owners complaining about low car counts and the lack of planning.
      Identifying Seasonal Trends (00:02:32)
      Kim discusses common excuses for slow periods and the importance of recognizing seasonal trends.
      Understanding the Marketing Calendar (00:04:23)
      Caroline explains the significance of analyzing past performance to create an effective marketing calendar.
      Proactive Marketing Strategies (00:06:11)
      Kim shares insights on developing marketing plans based on historical data and identifying slow periods.
      Creative Marketing Solutions (00:07:25)
      Kim describes a unique marketing strategy developed around the local state fair to attract customers.
      Importance of Planning Ahead (00:09:27)
      Kim emphasizes the necessity of proactive planning rather than reacting to slow days.
      Timing for Event Promotions (00:12:30)
      Discussion on how far in advance to plan marketing strategies for events like the state fair.
      Community Calendar Considerations (00:14:09)
      Caroline advises checking community calendars to align marketing efforts with local events.
      Adjusting Marketing Budgets (00:16:19)
      Kim discusses the importance of reallocating marketing budgets based on seasonal trends.
      Applicability to Different Locations (00:16:27)
      Chris challenges the notion that marketing strategies are only relevant to local events, encouraging broader application.
      Yearly Planning for Marketing (00:17:09)
      Caroline stresses the importance of yearly planning for marketing strategies, even if starting late.
      Setting Holiday Schedules (00:18:49)
      Chris shares his approach to planning marketing around holiday closures as a starting point for the year.
      Here are the extracted timestamps and their corresponding titles from the podcast episode transcription segment:
      Importance of Planning (00:19:14)
      Chris emphasizes the need for shop owners to have a structured marketing plan.
      Blocking Time for Planning (00:19:40)
      Kim advises shop owners to set aside undistracted time in October for planning.
      Using a Big Calendar (00:20:17)
      Kim suggests using a large calendar to visualize important dates and events affecting marketing.
      Analyzing Performance Data (00:22:25)
      Kim discusses breaking down historical data to identify busy and slow times for better planning.
      Setting Realistic Goals (00:24:20)
      Caroline stresses the importance of setting achievable marketing goals based on past performance.
      Understanding Marketing Budgets (00:26:17)
      Kim explains how to determine an appropriate marketing budget based on desired growth.
      Plan with the Pros Conference (00:28:49)
      Caroline introduces the "Plan with the Pros" event aimed at helping shop owners create marketing plans.
      Event Success and Expansion (00:31:01)
      Kim shares the success of last year's event and plans for expanding this year's attendance.
      Facebook Group for Marketing Support (00:33:15)
      Caroline details the Auto Repair Marketing Mastermind group for shop owners to connect and share insights.
      Final Thoughts on Marketing (00:37:02)
      Caroline encourages shop owners to create marketing calendars and utilize available resources for success.
      Do It Scared (00:37:51)
      Encouragement to start marketing despite fears of making mistakes or not knowing how to begin.
      Getting Started (00:38:11)
      Emphasis on taking action; "done is better than perfect" and scheduling time away from the shop.
      Perspective on Fear (00:38:22)
      Discussion on the urgency of creating a marketing calendar to avoid business decline.
      Final Thoughts and Thanks (00:38:41)
      Closing remarks and encouragement to utilize marketing pros for effective growth strategies.
      Sponsorship Shout-Out (00:39:11)
      Promotion of Shop Marketing Pros as the recommended marketing partner for auto repair businesses.
      Closing Remarks (00:39:11)
      Encouragement to maintain a positive mindset and a farewell from Coach Chris Cotton.
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
