Had a young customer come in this morning and said that his 2013 Mitsubishi Lancer Evolution has a vibration in the steering wheel under acceleration. He says, "When you accelerate there's a weird vibration in the steering wheel when you accelerate. It starts when you hit 60 and goes away at 80 then starts at 100 and disappears when it hits 120." He then proceeded to tell me that he replaced the tires, wheels balanced, alignment, etc...
I don't even know how to answer someone like that, I politely told him that I would look at the vehicle to see if there's anything obvious. But it's not like I'm going to go drive this thing at 100 to see what he's on about.
Well, that was my interesting story of the day.
We had a guy in a while back who wanted me to test drive his jeep wrangler at high speeds in the rain because he said "it wobbled so bad I thought I was going to roll it" Sorry man I like my head attached to my body we'll check it on the lift. Lol.
I knew it, I knew it... I knew it. I didn't think I was the only one who ever had somebody wanting me to test drive a car at some outrageous speed.
But, I did have one guy who said he kept hitting his head on the roof when he would go over this bump real fast. I told him to wear his seat belt and perhaps slow down, or I could cut a whole in the roof and let his head stick through... choose an option.
Well....Guilty as charged, Your Honor!!
When I was 25 I bought a new Porsche. It was smooth driving all the way up to 150. After the tires got some wear on them a few months later, it started vibrated at about 110 & up. I went to a performance tire shop about 90 miles away and had them balanced, but still had a vibration on the way home. Now this was in 1980, before the internet, before I was in the tire business, so I looked in the back of Car and Driver Magazine for tire ads. I ordered a set of $800 (1980 price) Pirelli's and had them shipped to me. When they came in I drove to Atlanta and had them mounted and balanced. On the way home it drove smoothly up to 150, and I learned then that just because a tire is not worn out that it may not be balanceable to ride smoothly. This lesson has served me well through the years.
So nowadays when someone tells me they have a high speed vibration, and they've had them balanced already, I can steer them toward investing in some new rubber!
Hi-Gear
At my shop we always use the FINE setting and balance to .1 oz. instead of the normal .25 and that makes a HUGE difference. If the tires are within .1 oz. static AND dynamic (both sides) they should be smooth to just over 100 mph (I amateur car race in case you were wondering). Other than that I would agree with the above post!
As an aside - my best ever apprentice (dammit, he enlisted in the Coast Guard) was taking classes at the local community college. He was balancing his tires in class with a weight and side-cuts in his hand. The Instructor asked him what he was dong about the same time he looked at the read-out on the balancer. Scott (my apprentice) told him he was balancing tires as he had been taught and the instructor stuck around to see how to set the machine on FINE and how that all worked out! Never been prouder of one of my guys...
steve
steve
You can balance to .1 oz and still have a bunch of vibration from road force variation. We do that and check the 1st. 2nd and 3rd harmonics on all tire/wheels we do as well as lateral force. I wasn't wondering but I also race. Drag and road racing.
Spence
I'm not disagreeing with the value of road force or fine balancing, but we've balanced literally tens of thousands of tires and you can't feel a 1/4oz or 10g imbalance. Even a half ounce on the back is not going to be noticeable on public roads.
Bent rims are the #1 cause of vibration. They balance out but they still don't go down the road smooth. #2 is garbage tires, the cheapo district of china makes square tires. (Not all Chinese tires are bad) They balance ok but will flatten out overnight. #3 is CV axles or stuck brake calipers. Get a rotor hot and it will warp, and if you have a stuck caliper it will shake with your foot off the brake. #4 is caked on mud, so obvious to most...
Incidentally loose tie rods and ball joints don't cause a vibration, they actually reduce it by absorbing it before it reaches the steering wheel. That's a Sinse-Ya moment when you rebuild a front end and now they feel their bent rim.
I took a class on NVH noise/vibration/harshness or something like that a while back, way back actually, and I recommend attending one of its offered. I went when I worked at Acura. You'd be surprised at what causes these "tire balance" issues. That's when ford was hanging large weights on the exhaust pipes.
We looked over everything and we found an axle that was a tiny bit loose. We mentioned that to him and he took it to the dealer.
The quality of the tires is a huge factor. You can balance and balance a cheap set of tires and they still won't ride as well as a better set of tires. I have worked at numerous Goodyear stores and saw this time after time regardless of the balancer used. As Frank said, just because tires are new does not make them smooth.
      Episode 200 - Balancing Customer Service & Profitability in Auto Repair With Rick White & Mike Himes
      Thanks to our Partner, NAPA Auto Care Join Maryann Croce in the fourth episode of the Unstoppable Framework for Auto Shop Owners series. Discover essential strategies for building trust, loyalty, and a thriving business by staying customer-focused and adaptable. Learn about gathering and acting on customer feedback, streamlining customer experiences, offering added services, building referral networks, and staying current with industry trends and training. Maryann Croce, Small Biz Vantage. Maryann’s previous episodes HERE. Show Notes Watch Full Video Episode Here's the downloadable worksheet link: https://bit.ly/3Yq4S4J Unstoppable Framework for Auto Shop Owners Part 1: Core Values and Vision [RR 997]: https://remarkableresults.biz/remarkable-results-radio-podcast/e997/ Unstoppable Framework for Auto Shop Owners Part 2: Mastering Your Finances [RRR 1004]: https://remarkableresults.biz/remarkable-results-radio-podcast/e1004/ Unstoppable Framework for Auto Shop Owners Part 3: Optimize Processes and Empower Your Team [RR 1012]: https://remarkableresults.biz/remarkable-results-radio-podcast/e1012/ MACS Training Event & Trade Show, Jan 30 – Feb 1, Orlando, FL: https://macsmobileairclimate.org/ The Unstoppable Framework (00:00:41) Part Four Overview (00:02:32) Importance of Customer Feedback (00:03:22) Client Story: Sarah's Transformation (00:05:51) Building Trust through Referrals (00:08:01) Shifting Perspective on Complaints (00:09:32) Customer Experience Walkthrough (00:10:27) The Gallon of Paint Analogy (00:12:58) Uplifting Shop Environment (00:13:53) Attracting the Right Customers (00:14:53) Staying Current with Training (00:16:07) Communication Trends and Customer Preferences (00:17:01) Practical Steps for Customer Focus (00:17:03) Streamlining Customer Experience (00:18:27) Building Referral Networks (00:19:43) Staying Open to Change (00:19:46) Thriving Through Change (00:20:25) Reframing Negative Reviews (00:21:36) Focus on Customer Training (00:24:07)
      Thanks to our Partner, NAPA Auto Care Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
