Had a young customer come in this morning and said that his 2013 Mitsubishi Lancer Evolution has a vibration in the steering wheel under acceleration. He says, "When you accelerate there's a weird vibration in the steering wheel when you accelerate. It starts when you hit 60 and goes away at 80 then starts at 100 and disappears when it hits 120." He then proceeded to tell me that he replaced the tires, wheels balanced, alignment, etc...
I don't even know how to answer someone like that, I politely told him that I would look at the vehicle to see if there's anything obvious. But it's not like I'm going to go drive this thing at 100 to see what he's on about.
Well, that was my interesting story of the day.
We had a guy in a while back who wanted me to test drive his jeep wrangler at high speeds in the rain because he said "it wobbled so bad I thought I was going to roll it" Sorry man I like my head attached to my body we'll check it on the lift. Lol.
I knew it, I knew it... I knew it. I didn't think I was the only one who ever had somebody wanting me to test drive a car at some outrageous speed.
But, I did have one guy who said he kept hitting his head on the roof when he would go over this bump real fast. I told him to wear his seat belt and perhaps slow down, or I could cut a whole in the roof and let his head stick through... choose an option.
Well....Guilty as charged, Your Honor!!
When I was 25 I bought a new Porsche. It was smooth driving all the way up to 150. After the tires got some wear on them a few months later, it started vibrated at about 110 & up. I went to a performance tire shop about 90 miles away and had them balanced, but still had a vibration on the way home. Now this was in 1980, before the internet, before I was in the tire business, so I looked in the back of Car and Driver Magazine for tire ads. I ordered a set of $800 (1980 price) Pirelli's and had them shipped to me. When they came in I drove to Atlanta and had them mounted and balanced. On the way home it drove smoothly up to 150, and I learned then that just because a tire is not worn out that it may not be balanceable to ride smoothly. This lesson has served me well through the years.
So nowadays when someone tells me they have a high speed vibration, and they've had them balanced already, I can steer them toward investing in some new rubber!
Hi-Gear
At my shop we always use the FINE setting and balance to .1 oz. instead of the normal .25 and that makes a HUGE difference. If the tires are within .1 oz. static AND dynamic (both sides) they should be smooth to just over 100 mph (I amateur car race in case you were wondering). Other than that I would agree with the above post!
As an aside - my best ever apprentice (dammit, he enlisted in the Coast Guard) was taking classes at the local community college. He was balancing his tires in class with a weight and side-cuts in his hand. The Instructor asked him what he was dong about the same time he looked at the read-out on the balancer. Scott (my apprentice) told him he was balancing tires as he had been taught and the instructor stuck around to see how to set the machine on FINE and how that all worked out! Never been prouder of one of my guys...
steve
steve
You can balance to .1 oz and still have a bunch of vibration from road force variation. We do that and check the 1st. 2nd and 3rd harmonics on all tire/wheels we do as well as lateral force. I wasn't wondering but I also race. Drag and road racing.
Spence
I'm not disagreeing with the value of road force or fine balancing, but we've balanced literally tens of thousands of tires and you can't feel a 1/4oz or 10g imbalance. Even a half ounce on the back is not going to be noticeable on public roads.
Bent rims are the #1 cause of vibration. They balance out but they still don't go down the road smooth. #2 is garbage tires, the cheapo district of china makes square tires. (Not all Chinese tires are bad) They balance ok but will flatten out overnight. #3 is CV axles or stuck brake calipers. Get a rotor hot and it will warp, and if you have a stuck caliper it will shake with your foot off the brake. #4 is caked on mud, so obvious to most...
Incidentally loose tie rods and ball joints don't cause a vibration, they actually reduce it by absorbing it before it reaches the steering wheel. That's a Sinse-Ya moment when you rebuild a front end and now they feel their bent rim.
I took a class on NVH noise/vibration/harshness or something like that a while back, way back actually, and I recommend attending one of its offered. I went when I worked at Acura. You'd be surprised at what causes these "tire balance" issues. That's when ford was hanging large weights on the exhaust pipes.
Edited by alfredauto
We looked over everything and we found an axle that was a tiny bit loose. We mentioned that to him and he took it to the dealer.
The quality of the tires is a huge factor. You can balance and balance a cheap set of tires and they still won't ride as well as a better set of tires. I have worked at numerous Goodyear stores and saw this time after time regardless of the balancer used. As Frank said, just because tires are new does not make them smooth.
      In this episode of "The Weekly Blitz," host Coach Chris Cotton delves into the critical topic of enhancing customer experience within the auto repair industry by effectively merging cutting-edge technology with personalized service touches. Drawing from his own life, Chris shares vivid personal anecdotes that illustrate the profound impact of customer service on brand perception and loyalty.
      He begins by recounting his contrasting experiences with two tech giants, Apple and Lenovo. Through these stories, Chris highlights how Apple's commitment to seamless, customer-centric service left a lasting positive impression, whereas Lenovo's lackluster support fell short of expectations. These anecdotes serve as powerful examples of how excellent customer service can significantly influence customer satisfaction and brand loyalty.
      Chris also shares his positive interactions with Starlink, the satellite internet service provider. He emphasizes how Starlink's proactive communication and dedication to resolving issues made him feel valued as a customer. This experience underscores the importance of making customers feel appreciated and respected, which can transform a one-time transaction into a long-term relationship.
      Introducing the concept of "relationship coins," Chris encourages auto repair shops to view customer interactions as opportunities to invest in building strong, lasting relationships. He explains that each positive interaction adds to a metaphorical bank of goodwill, which can pay dividends in terms of customer loyalty and repeat business.
      Sponsored by Shop Marketing Pros, the episode underscores the necessity of providing exceptional service to foster customer loyalty and drive business growth. Chris argues that in an industry where trust and reliability are paramount, auto repair shops must prioritize customer experience by integrating technology that enhances service efficiency while maintaining the personal touch that makes customers feel valued and understood.
      Throughout the episode, Chris Cotton passionately advocates for a balanced approach that leverages technology to streamline operations and improve service delivery, while also emphasizing the irreplaceable value of human connection in creating memorable customer experiences. By doing so, auto repair shops can not only meet but exceed customer expectations, ultimately leading to sustained business success.
      Introduction to Supercharging (00:00:09)
      Coach Chris Cotton introduces the podcast and its focus on enhancing auto repair business through innovative insights.
      Guest Introduction and Technology Discussion (00:01:12)
      Chris introduces Craig O'Neill and discusses the impact of technology on customer experience in the auto repair industry.
      Personal Customer Experience Anecdote (00:02:21)
      Chris shares a personal story about his customer experience with laptop purchases and the importance of customer service.
      Switching to Apple Products (00:05:49)
      After poor service from Lenovo, Chris decides to purchase a MacBook, highlighting the positive experience he had.
      Apple's Exceptional Customer Service (00:08:00)
      Chris details his satisfaction with Apple's customer service, leading to his continued investment in their products.
      Starlink Customer Experience (00:09:14)
      Chris recounts his positive interaction with Starlink customer service while setting up internet for travel.
      Importance of Merging Technology and Personal Touch (00:12:15)
      Chris emphasizes the need for auto repair shops to blend technology with personal service to enhance customer experiences.
      In episode 202 of "The Weekly Blitz," Coach Chris Cotton takes a deep dive into the financial performance of auto repair shops, offering listeners a comprehensive analysis based on insights from the January edition of Ratchet & Wrench magazine. Throughout the episode, Coach Chris emphasizes the critical importance of tracking key performance indicators (KPIs) such as annual revenue, gross profit margins, and net profit margins. These metrics are essential for shop owners who aim to understand and enhance their business's financial health.
      Coach Chris shares compelling survey statistics that reveal significant revenue growth within the auto repair industry over the past 15 years. This growth underscores the dynamic nature of the industry and the opportunities available for shop owners who are proactive in managing their finances. He highlights the necessity for shop owners to focus on improving their financial metrics, as doing so can lead to increased profitability and long-term success.
      In addition to discussing financial performance, the episode also promotes Shop Marketing Pros, a specialized marketing company dedicated to serving auto repair shops. Shop Marketing Pros offers tailored marketing solutions designed to help shop owners attract more customers and build a strong brand presence in their local markets.
      Listeners of this episode will gain valuable insights into the financial aspects of running an auto repair shop and learn strategies to boost their business's performance. Coach Chris's expert advice, combined with the resources provided by Shop Marketing Pros, equips shop owners with the tools they need to thrive in a competitive industry.
      Introduction to the Episode (00:00:08)
      Coach Chris Cotton introduces the podcast and its purpose to supercharge auto repair businesses.
      Overview of Ratchet & Wrench Magazine (00:01:04)
      Discussion on insights from the January edition of Ratchet & Wrench magazine regarding shop performance.
      15-Year Industry Comparison (00:02:15)
      Chris highlights changes in annual revenue and profit margins in the auto repair industry over 15 years.
      Importance of Tracking KPIs (00:03:15)
      Emphasis on the significance of key performance indicators for making informed financial decisions.
      KPI Awareness Among Shop Owners (00:04:20)
      Chris shares his experience teaching shop owners about KPIs, revealing a lack of awareness.
      Current Revenue Statistics (00:05:20)
      Over 50% of surveyed shops now report annual revenues exceeding $1 million, a significant increase from 15 years ago.
      Gross Profit Margin Insights (00:06:18)
      Discussion on gross profit margins, with over 50% of shops reporting margins above 50%.
      Revenue Breakdown of Surveyed Shops (00:07:17)
      Detailed statistics on revenue ranges among surveyed shops, highlighting growth trends.
      Industry Consolidation Factors (00:09:35)
      Analysis of industry consolidation and growth potential as more shops exceed $25 million in revenue.
      Gross Profit Margin Categories (00:10:49)
      Breakdown of gross profit margins among surveyed shops, with insights on profitability levels.
      Net Profit Margin Overview (00:12:59)
      Discussion on net profit margins, noting a concerning percentage of shops not generating profit.
      Encouragement for Improvement (00:14:07)
      Chris encourages shop owners to make small tweaks for improved profitability and performance.
      Tracking and Measuring KPIs (00:16:12)
      Final thoughts on the importance of tracking KPIs and using data to drive business improvements.
      Episode 200 - Balancing Customer Service & Profitability in Auto Repair With Rick White & Mike Himes
      Thanks to our Partner, NAPA Auto Care Join Maryann Croce in the fourth episode of the Unstoppable Framework for Auto Shop Owners series. Discover essential strategies for building trust, loyalty, and a thriving business by staying customer-focused and adaptable. Learn about gathering and acting on customer feedback, streamlining customer experiences, offering added services, building referral networks, and staying current with industry trends and training. Maryann Croce, Small Biz Vantage. Maryann’s previous episodes HERE. Show Notes Watch Full Video Episode Here's the downloadable worksheet link: https://bit.ly/3Yq4S4J Unstoppable Framework for Auto Shop Owners Part 1: Core Values and Vision [RR 997]: https://remarkableresults.biz/remarkable-results-radio-podcast/e997/ Unstoppable Framework for Auto Shop Owners Part 2: Mastering Your Finances [RRR 1004]: https://remarkableresults.biz/remarkable-results-radio-podcast/e1004/ Unstoppable Framework for Auto Shop Owners Part 3: Optimize Processes and Empower Your Team [RR 1012]: https://remarkableresults.biz/remarkable-results-radio-podcast/e1012/ MACS Training Event & Trade Show, Jan 30 – Feb 1, Orlando, FL: https://macsmobileairclimate.org/ The Unstoppable Framework (00:00:41) Part Four Overview (00:02:32) Importance of Customer Feedback (00:03:22) Client Story: Sarah's Transformation (00:05:51) Building Trust through Referrals (00:08:01) Shifting Perspective on Complaints (00:09:32) Customer Experience Walkthrough (00:10:27) The Gallon of Paint Analogy (00:12:58) Uplifting Shop Environment (00:13:53) Attracting the Right Customers (00:14:53) Staying Current with Training (00:16:07) Communication Trends and Customer Preferences (00:17:01) Practical Steps for Customer Focus (00:17:03) Streamlining Customer Experience (00:18:27) Building Referral Networks (00:19:43) Staying Open to Change (00:19:46) Thriving Through Change (00:20:25) Reframing Negative Reviews (00:21:36) Focus on Customer Training (00:24:07)
      Thanks to our Partner, NAPA Auto Care Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
      In this episode of "The Weekly Blitz," Coach Chris Cotton delves into the critical need for auto repair shops to offer customer financing options, a topic of growing importance in the industry. He begins by addressing the pressing challenges that many auto repair shops face today, such as low car counts and declining repair orders. These issues can significantly impact a shop's bottom line, making it essential for shop owners to find innovative solutions to attract and retain customers.
      Chris emphasizes that offering multiple financing options can be a game-changer for both customers and auto repair shops. For customers, financing provides a way to manage unexpected repair costs without straining their budgets. This is particularly important in situations where a sudden car breakdown can lead to financial stress. By providing flexible payment solutions, shops can help alleviate this burden, making it easier for customers to approve necessary repairs.
      Throughout the episode, Chris shares valuable insights on various financing providers available in the market. He discusses the pros and cons of each, helping shop owners make informed decisions about which providers might best suit their needs and those of their customers. Chris also highlights the benefits of financing for auto repair shops, such as increased sales, improved customer satisfaction, and enhanced customer loyalty.
      Furthermore, Chris offers practical strategies for effectively communicating financing options to customers. He stresses the importance of clear and transparent communication, ensuring that customers fully understand their financing choices and the terms involved. By doing so, shops can build trust and foster long-term relationships with their clientele.
      The episode also features a sponsorship mention for Shop Marketing Pros, a marketing company specializing in services for auto repair shops. Shop Marketing Pros is recognized for its expertise in helping shops enhance their marketing efforts, attract more customers, and ultimately grow their businesses. Their sponsorship underscores the importance of strategic marketing in conjunction with offering financing options, as both elements are crucial for the success of modern auto repair shops.
      Introduction to Financing (00:01:26)
      Discussion on the importance of financing options for customers in auto repair shops.
      Current Challenges in Auto Repair (00:02:38)
      Overview of low car counts and declining average repair orders affecting repair shops.
      Importance of Customer Financing (00:03:43)
      Financing options are essential for building consumer trust and increasing average repair orders.
      Unexpected Expenses and Financing Solutions (00:04:58)
      Highlighting how financing helps customers manage unexpected repair costs effectively.
      Types of Financing Options (00:06:10)
      Introduction to various financing providers and their benefits for customers and shops.
      Making Financing Accessible (00:08:17)
      Strategies for simplifying the financing process and making it more accessible to customers.
      Communicating Financing Options (00:09:27)
      Importance of consistently informing customers about financing options at every touchpoint.
      Benefits of Offering Financing (00:12:50)
      Discussing how financing increases average repair orders and customer retention.
      Call to Action for Shops (00:13:56)
      Encouragement for shops to start offering and promoting financing options to enhance customer relationships.
