The other day I listened to a fellow service writer talking to a customer about the A/C inspections we did for him. He explained the process of evacuating and recharging and that we injected dye into the system. The system held vacuum and we didn't find a leak that day. He then told the customer to make an appointment for us to take a second look at the A/C system, to find the leak. However he told the customer to make that appointment after the system goes warm.
After the customer left I asked him why he made the "When the system goes warm" recommendation because, I have always recommended that the customer returned in 3-4 weeks for the UV dye inspection. He told me that the owner of our shop said that it was stupid, to have the customer come back if they were not experiencing a problem, hence when the system becomes warm again.
What is the process at your shop?
We tell them to come back if the system fails. I don't want/need to look at it if it's working OK. As a side note, our techs are required to soap test the ports after servicing. It's amazing how often you create a leak just by putting your hoses on the ports.
  • Like 5
We explain how we added the dye and to return if the AC stops cooling. Like the post above, there is no point in the customer returning if the AC is functioning ok.
Scott
I soap test after installing anything under pressure. That includes any hydraulic lines. (just picky I guess) But, any and every A/C job has a disclaimer on it. Which states "To avoid loss of excessive amounts of refrigerant we recommend returning in two weeks (or if it stops cooling within the two weeks) for a FREE leak check. Any problems found at that time (as far as leaks) can be diagnosed and estimated for further repair."
Found lots and lots of leaks that way, but... I wouldn't wait for it to stop cooling, unless it is within the two weeks. Besides, as most people do, they'll put things off until it's "convenient" by then the oil/dye has dried up and it makes it harder to spot the leak.
Having freon levels drop over several years is normal and doesnt mean there is anything wrong, it will permeate thru the seals and is nothing to worry about. Add dye, top it off and, come back if it gets warm again, that way, you will know its something more.
I recommend 2-4 weeks. It's a quick check and if dye shows up, you have a potential sell. If you tell them to wait it may be a slow leak, leaks over winter when they don't know and comes back in the spring and you have to recharge and dye it again, will the customer be happy?
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
      In this episode of "The Weekly Blitz," host Coach Chris Cotton delves into the critical topic of enhancing customer experience within the auto repair industry by effectively merging cutting-edge technology with personalized service touches. Drawing from his own life, Chris shares vivid personal anecdotes that illustrate the profound impact of customer service on brand perception and loyalty.
      He begins by recounting his contrasting experiences with two tech giants, Apple and Lenovo. Through these stories, Chris highlights how Apple's commitment to seamless, customer-centric service left a lasting positive impression, whereas Lenovo's lackluster support fell short of expectations. These anecdotes serve as powerful examples of how excellent customer service can significantly influence customer satisfaction and brand loyalty.
      Chris also shares his positive interactions with Starlink, the satellite internet service provider. He emphasizes how Starlink's proactive communication and dedication to resolving issues made him feel valued as a customer. This experience underscores the importance of making customers feel appreciated and respected, which can transform a one-time transaction into a long-term relationship.
      Introducing the concept of "relationship coins," Chris encourages auto repair shops to view customer interactions as opportunities to invest in building strong, lasting relationships. He explains that each positive interaction adds to a metaphorical bank of goodwill, which can pay dividends in terms of customer loyalty and repeat business.
      Sponsored by Shop Marketing Pros, the episode underscores the necessity of providing exceptional service to foster customer loyalty and drive business growth. Chris argues that in an industry where trust and reliability are paramount, auto repair shops must prioritize customer experience by integrating technology that enhances service efficiency while maintaining the personal touch that makes customers feel valued and understood.
      Throughout the episode, Chris Cotton passionately advocates for a balanced approach that leverages technology to streamline operations and improve service delivery, while also emphasizing the irreplaceable value of human connection in creating memorable customer experiences. By doing so, auto repair shops can not only meet but exceed customer expectations, ultimately leading to sustained business success.
      Introduction to Supercharging (00:00:09)
      Coach Chris Cotton introduces the podcast and its focus on enhancing auto repair business through innovative insights.
      Guest Introduction and Technology Discussion (00:01:12)
      Chris introduces Craig O'Neill and discusses the impact of technology on customer experience in the auto repair industry.
      Personal Customer Experience Anecdote (00:02:21)
      Chris shares a personal story about his customer experience with laptop purchases and the importance of customer service.
      Switching to Apple Products (00:05:49)
      After poor service from Lenovo, Chris decides to purchase a MacBook, highlighting the positive experience he had.
      Apple's Exceptional Customer Service (00:08:00)
      Chris details his satisfaction with Apple's customer service, leading to his continued investment in their products.
      Starlink Customer Experience (00:09:14)
      Chris recounts his positive interaction with Starlink customer service while setting up internet for travel.
      Importance of Merging Technology and Personal Touch (00:12:15)
      Chris emphasizes the need for auto repair shops to blend technology with personal service to enhance customer experiences.
      In episode 202 of "The Weekly Blitz," Coach Chris Cotton takes a deep dive into the financial performance of auto repair shops, offering listeners a comprehensive analysis based on insights from the January edition of Ratchet & Wrench magazine. Throughout the episode, Coach Chris emphasizes the critical importance of tracking key performance indicators (KPIs) such as annual revenue, gross profit margins, and net profit margins. These metrics are essential for shop owners who aim to understand and enhance their business's financial health.
      Coach Chris shares compelling survey statistics that reveal significant revenue growth within the auto repair industry over the past 15 years. This growth underscores the dynamic nature of the industry and the opportunities available for shop owners who are proactive in managing their finances. He highlights the necessity for shop owners to focus on improving their financial metrics, as doing so can lead to increased profitability and long-term success.
      In addition to discussing financial performance, the episode also promotes Shop Marketing Pros, a specialized marketing company dedicated to serving auto repair shops. Shop Marketing Pros offers tailored marketing solutions designed to help shop owners attract more customers and build a strong brand presence in their local markets.
      Listeners of this episode will gain valuable insights into the financial aspects of running an auto repair shop and learn strategies to boost their business's performance. Coach Chris's expert advice, combined with the resources provided by Shop Marketing Pros, equips shop owners with the tools they need to thrive in a competitive industry.
      Introduction to the Episode (00:00:08)
      Coach Chris Cotton introduces the podcast and its purpose to supercharge auto repair businesses.
      Overview of Ratchet & Wrench Magazine (00:01:04)
      Discussion on insights from the January edition of Ratchet & Wrench magazine regarding shop performance.
      15-Year Industry Comparison (00:02:15)
      Chris highlights changes in annual revenue and profit margins in the auto repair industry over 15 years.
      Importance of Tracking KPIs (00:03:15)
      Emphasis on the significance of key performance indicators for making informed financial decisions.
      KPI Awareness Among Shop Owners (00:04:20)
      Chris shares his experience teaching shop owners about KPIs, revealing a lack of awareness.
      Current Revenue Statistics (00:05:20)
      Over 50% of surveyed shops now report annual revenues exceeding $1 million, a significant increase from 15 years ago.
      Gross Profit Margin Insights (00:06:18)
      Discussion on gross profit margins, with over 50% of shops reporting margins above 50%.
      Revenue Breakdown of Surveyed Shops (00:07:17)
      Detailed statistics on revenue ranges among surveyed shops, highlighting growth trends.
      Industry Consolidation Factors (00:09:35)
      Analysis of industry consolidation and growth potential as more shops exceed $25 million in revenue.
      Gross Profit Margin Categories (00:10:49)
      Breakdown of gross profit margins among surveyed shops, with insights on profitability levels.
      Net Profit Margin Overview (00:12:59)
      Discussion on net profit margins, noting a concerning percentage of shops not generating profit.
      Encouragement for Improvement (00:14:07)
      Chris encourages shop owners to make small tweaks for improved profitability and performance.
      Tracking and Measuring KPIs (00:16:12)
      Final thoughts on the importance of tracking KPIs and using data to drive business improvements.
    • By marxautocenter
