Joe Friday Diagnostics
"How would Sgt. Friday explain auto repair and diagnostics…
Que the music: "
The story you’re about to read is true; the names have been
changed to protect the innocent.
Monday morning, it was cold that day. I was working day shift out
of the repair division. There’s a suspicious vehicle at the front of the shop.
A customer walks in the door. I’ll take it from here. I’m a mechanic, the name’s Friday.
It was a 2003 Ford, 5.4 liter, fully loaded and sounded like it was running rough. The lady came to the counter.
“Good Morning ma’am, what can I do for you,” I said to the complaintant.
“Yes, I’m here about my car,” she answered.
“There’s a problem with the car, I see. What can you tell me about it?” I asked, in my usual non-threatening, but confident monotone voice.
“I was on my way to deliver my recyclables to the east side collection area, because I’m a concerned citizen you know, when my car started to make a coughing and clattering sound. I thought I would bring it in to have it checked out,” the owner answered.
“Coughing and clattering, hmm, not a problem. I’ll get it investigated, I can interrogate the pursuant this morning, especially for a concerned citizen such as yourself,” I answered while maintaining my professionalism.
“Well, do you need any other information from me?” she asked.
“Just the facts ma’am, just the facts,” I said.
“The check engine light came on,” she reported.
“This could be of some help. Sounds like a possible 0300 (engine misfire). But I’ll check it out first, I’ll need to finish my investigation in order to give you any proper results,” I said to her, while my pen was busy jotting down the facts onto the always present handy notepad.
She left the car with me for further interrogations. Using the scanner made the results easy to locate. It wasn’t long before I got an answer. It was a P0302 in progress… misfire on no#2 cylinder… normally an open and shut case.
09:30 Am, working on the assumption that the perpetrator was somewhere near the 2nd cylinder; I went in for further investigations. I checked the usual suspects. Pulling the plug didn’t yield any new clues. The plug was good and answered all the standard questions. The coil was a more likely suspect; a simple test could answer the problem.
I’ll set up a little sting operation by using a decoy. Taking the nearest coil and replacing it with the suspected faulty coil, and put the known good coil on the other plug. I was hoping to see the miss move to the other cylinder. It didn’t. In fact it was gone.
10:05 Am, Now the challenge was on. I’ll have to go back over my facts and check the crime scene again. There’s something I must have overlooked that might be the key to this investigation. Two things come up as good possibles; the connection or terminals at the coil, or the spark plug boot attached to the coil. The plug boot had a good alibi… it had just been changed, in fact so was the spark plug. That left the coil connection.
A more in-depth interrogation of the connector is needed. My years of technical diagnostics work told me to look closer at the wire and the connector. The guilty party in this case appears to be one of the wires at the connector. It was barely hanging onto the housing. Only the plastic sheath was still connected, and the wire itself was not answering to any of the standard questioning or interrogative tactics.
Under the intense glow of the high powered shop light the investigation continued. Resorting to some strong arm tactics I pulled on the wire while using a few choice investigative words, the plastic sheathing kept getting longer and longer. Soon, it snapped under the pressure to expose the desperado for the perpetrator it really was.
11:45 Am, The repair was completed, and tested to verify the repairs were effective. The car in question was back with its rightful owner by the end of the day. I now can close the file on this one, another job well done.
In conclusion: With the P0302 in question deleted from the computer history, the coil connector was then convicted of failure to cooperate. With her car back on the road she could once again be a productive concerned citizen of this great metropolis.
Case closed and now, back to the front desk waiting for that next problem to come through the door. This city is full of broken, non-maintained, and poorly running cars. As a concerned citizen I’ll be on the lookout for these suspicious misfires and other infractions of the auto world.
There are thousands of men and women in this city, who know that being an auto tech is an thankless, grease covered job that's done everyday without any fan fare. Then again, I'm part of that glamour-less, grease covered world... my names Friday, I'm a mechanic.
Brought this story back just for Joe... :)
(originally published in 2011)
      Thanks to our Partners, NAPA TRACS, and Today's Class Tim Iezzi and Ira Waldman introduce their upcoming training class, "Labscope Essentials for the Ball Joint Guy," designed to build strong foundational skills in labscope diagnostics. Aimed at bridging the gap between hands-on mechanical work and advanced technology, the class offers practical, hands-on learning with ongoing support. Tim and Ira break down the curriculum, target audience, and the importance of real-world application to reinforce concepts. They also highlight the critical role of continuous education and why shop owner involvement is key to technician growth and long-term success.
      Tim Iezzi, Iezzi’s Auto Service, Reading, PA
      Ira Waldman, Mallue's Automotive, Manasquan, NJ
      Watch Full Video Episode TST Big Event 2025: https://www.tstseminars.org/ "Labscope Essentials for the Ball Joint Guy" 9:00 AM - 5:00 PM on May 3-4, 2025. $495 per person (includes food and refreshments) Event Address: MACS Training Facility- 225 S Broad St, Lansdale, PA 19446 (back of the building). Contact us at: (484) 509-1494 or [email protected] Guest Introductions (00:00:00) Training Class Announcement (00:02:04) Class Focus Discussion (00:03:16) Investment in Training (00:05:07) Hands-On Learning Approach (00:05:47) Understanding Good vs. Bad Data (00:08:40) Foundation of Skills (00:10:48) Target Audience for the Class (00:12:01) Electricity Basics Requirement (00:12:14) Limitless Potential of Labscopes (00:13:10) Remote Refresher Training (00:14:00) Career Pathing and Continuous Education (00:15:16) Testing Techniques for Diagnostics (00:16:32) Supporting Students Post-Class (00:17:12) Creating a Comfortable Learning Environment (00:20:10) Assessments in Training (00:22:18) Hands-On Labs as Assessment (00:24:30) Accountability in Learning (00:26:22) Engaging Shop Owners in Training (00:27:46) Incentives for Technicians (00:27:58) Upcoming Training Classes (00:28:31)
      Thanks to our Partner, NAPA TRACS NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Thanks to our Partner, Today's Class Optimize training with Today's Class: In just 5 minutes daily, boost knowledge retention and improve team performance. Find Today's Class on the web at https://www.todaysclass.com/ Connect with the Podcast: -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on X: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/
      Episode 202 - A Conversation with Launch Tech's Haresh Gobin On The Future of Diagnostics
      Matt Fanslow welcomes mobile diagnostic technician Rich Falco to explore the intriguing parallels between poker strategies and automotive diagnostics.
      Watch Full Video Episode Discussion on Poker (00:01:02) Evolution of Poker Strategies (00:02:22) Game Theory and Diagnostics (00:04:35) Common Misunderstandings (00:12:07) Real-World Diagnostic Scenarios (00:13:26) Electric Vehicle Training (00:15:46) Power Window Diagnosis (00:16:44) Poker Predictions (00:18:05) Understanding Poker Players (00:19:01) Reading Opponents (00:20:14) Experience in Diagnostics (00:22:03) The Importance of Training (00:23:22) Shop Culture Changes (00:26:09) Technology in Poker (00:30:21) AI and Diagnostics (00:31:08) Access to Training Resources (00:32:07) Young Technicians' Knowledge (00:33:05) Poker vs. Automotive Diagnostics (00:33:24)
