First of all I would like to start by saying hello my name is Liam and I'm new here this being my first post unfortunately. I own a small shop in queens NY with a small but grate customer base. I would like to say this site has been grate on giving me some insight into how other shops run and conduct day to day operations. I would like to say thank you for that and I hope to contribute in the future. now let me tell you about my issue with this car.
A good customer of mine has a 2001 Hyundai Electra. The vehicle is in grate condition always takes care of what needs to be done. Over the past 3 weeks the check engine light has come on a number of time throwing p0455. we have smoke tested it each time passing with flaying colors the ball is pined right to the bottom. checked the purge valve working grate. so we conducted a evap system test using the versus. now ether the test passes. or the test closes the vent valve and pulls a vacuum on the system then 25 sec into the test the ecu opens the vent valve before the test is done. vacuum drops and sets the p0455. its not the CVV but the ecu itself opening the ground circuit. I've never seen a ecu/pcm fail in this way.
my question to you is why? do think the ecu is faultily?
Thank you
liam
P0455 is an evap large leak, I've really only seen this when a gas cap has failed or the large evap line on the tank. The small evap lines won't cause this fault.
Oh yeah, another possible cause is a tank that has a leak as it will not hold pressure.
Edited by phynny
Agreed. Put a new gas cap on it and clean the opening well.
We will sometimes bring a questionable cap next door to the emissions test station (aka a tent in the gas station parking lot). They've got a gas cap tester.
It's usually doing that because the ECM is seeing that it can't pull a vacuum. I've sen the canister come apart, plug the purge valve and it can't draw a vacuum so it throws that code.
Read your SI, that system uses vacuum, smoke won't help you. Test it correctly and read the code set criteria. Look at your scanner and see what's not within spec and go from three.
  • 11 months later...
fixed it... chased my tail for awhile over thinking it. ended up being an extremely same leak in one of the evap lines. But I feel it's placement was key, right at the tank pressure sensor. Witch on this car is right over the rear sub-frame and has a small rubber line that goes into the top of the tank. Even once I found It I had to look very closely to see the smoke leaking out. The vehicle has been repaired for awhile now no light returned. Sorry for the slow reply completely forgot to post the out come
thanks for the replies
You weren't slow with your reply.......it was only 11 months!!! But thanks for letting us know!!
      Introduction to the Podcast (00:00:01)  The podcast begins with a welcome message from the host, Brian Walker. Guest Introduction (00:00:10)  Brian introduces co-host Kim and guest Doug DeLuca, owner of Boca Auto Fix. Overview of Boca Auto Fix (00:00:51)  Doug shares details about his auto repair shop, including its location and age. Hiring an Apprentice (00:01:09)  Doug discusses the recent hiring of an apprentice and the journey leading to this decision. Challenges in Hiring (00:02:13)  The speakers reflect on the difficulties shop owners face in finding and hiring young talent. Marketing Journey Begins (00:03:02)  Discussion shifts to Doug's initial marketing efforts and his involvement in content creation. Background in Technology (00:04:07)  Doug explains his previous technology background and how it influenced his approach to marketing. Learning SEO and Marketing (00:04:45)  Doug describes his self-taught journey in SEO and digital marketing after opening his shop. Realizing Marketing Needs (00:06:14)  Doug reflects on his initial assumptions about marketing and the reality of attracting customers. Understanding SEO Basics (00:08:09)  Doug shares his insights on SEO and the learning process involved in mastering it. Frameworks in Marketing (00:10:25)  The conversation explores the use of frameworks in both auto repair and marketing strategies. Adopting "They Ask, You Answer" (00:11:23)  Doug discusses his experience with the "They Ask, You Answer" philosophy in content creation. Writing Blogs for Customer Engagement (00:12:21)  Doug explains how he uses customer inquiries to create relevant blog content for his shop. Experience at a Quick Lube (00:13:29)  Doug shares his firsthand experience at a quick lube to highlight differences in service quality. Experience Comparison (00:14:06) Doug shares his experience of visiting a competitor's shop to understand customer perception and service quality. Proactive Client Advocacy (00:14:57) The team discusses the importance of guiding potential clients to the right service provider based on their needs. Sponsorship and Marketing Tools (00:16:13) Brian introduces RepairPal, highlighting its benefits for attracting new customers and building trust. Customer Loyalty Apps (00:17:51) Brian discusses the advantages of using App Fueled to create customer loyalty programs for auto repair shops. Incognito Visits (00:18:20) Doug talks about visiting a competitor's shop incognito to gain insights without revealing their identity. Collaboration Over Competition (00:19:09) The speakers explore the idea of referring customers to other shops and building relationships in the industry. Challenging Competition Norms (00:20:20) Brian reflects on inviting competitors to the podcast, emphasizing collaboration over traditional competition. Marketing Involvement (00:22:42) Doug explains the ad hoc nature of their marketing efforts and the role of social media in their strategy. Community Involvement (00:27:41) Doug shares their family's volunteer work and how it integrates with their business's social media presence. Engaging the College Market (00:28:51) Doug discusses how 30% of his clients are college students and their marketing strategies. Collaborating with Local Professors (00:31:18) Doug shares his experience working with a marketing professor for student analysis of his business. Challenges of Seasonal Demand (00:32:24) Discussion on the impact of seasonal changes on business demand and local marketing efforts. Starting with Marketing (00:34:02) Doug advises new shop owners to listen to podcasts and conduct online research for marketing. SEO as a Long-Term Strategy (00:35:08) Doug explains the importance of SEO and its long-term benefits for business growth. Understanding Competition (00:36:44) Doug emphasizes the need to analyze competition and not assume marketing strategies will work universally. The Importance of Data (00:39:08) Doug highlights the role of data in assessing marketing effectiveness and making informed decisions. Nuances of Market Dynamics (00:41:14) Discussion on how geographical and seasonal factors affect marketing strategies in auto repair. Client Avatar and Marketing Alignment (00:42:13) Doug explains the significance of understanding the ideal customer for effective marketing strategies.  Overcoming Diagnostic Fee Challenges (00:43:09) Discussion on how Doug has adjusted his approach to diagnostic fees to improve customer conversion. The Importance of Evaluation Fees (00:43:40) Discussion on the role of evaluation fees and their impact on shop maturity. Improving Customer Communication (00:44:09)  Insights on enhancing customer explanations regarding services and processes. Coaching and Competitive Analysis (00:45:03)  How coaching helped refine service policies and improve customer relations. Content Creation and Marketing Strategy (00:46:32)  The significance of creating content for customer engagement and marketing. Duck Duck Jeep Initiative (00:47:05)  Fun marketing strategy involving ducks to engage with the local Jeep community. Value of Customer Feedback (00:48:46)  Importance of understanding customer inquiries and improving service based on feedback. Contact Information for Doug DeLuca (00:49:29)   Doug shares how listeners can reach him for further inquiries.
