The Refrigerator Light
Did ya ever find yourself at the service counter trying to explain to a customer how you diagnose an intermittent problem? I know I have. Intermittent problems can vary and the explanations of these problems are just as diverse as the problems. Typically, I’ll ask the standard questions: When does it seem to happen most often, how often does it occur, is it more likely in the morning or afternoon, and does it happen when the engine is cold or hot? Those type of questions. The usual answer in most cases is, “I don’t know”.
The big issue is that a lot of people don’t understand that even though they have seen a failure, and the fact that it doesn’t occur very often, doesn’t mean the mechanic is going to be able to find it without some background or investigative research. Take for instance this guy who came in and told me his car doesn’t start. I asked, “Where’s the car? I’ll have a tow truck pick it up?” His answer, “I don’t need one, I drove it here.” Then, of course, I’m back to the questions again, “So, when does it not start?” I’m confronted with the typical answer, “I don’t know”. The more I tried to dig into the history of this “no start” condition the more “I don’t know” seemed to come up. At best the only clear cut answer I got was that it did it once last summer. (This is no help at all nearly a year later.)
Apparently this guy (along with many others) was informed there is this magical diagnostic tool that can not only tell the date and time of a past failure, but can also predict the future demise of any component in the car. So, now my “intermittent” explanation is side tracked with explaining that there is no magical machine. Eventually, I went through the normal “intermittent” spiel, and how duplicating the failure was the most appropriate method beyond looking at the numbers and PID’s on the scanner. I could use a travel recorder that will record pertinent information and give it to the customer to drive around with it hooked up to the car for a bit, but since the last failure was the previous summer I don’t think leaving the recorder in his car would do any good. Since that’s not really an option, I did my best to explain how I diagnose intermittent problems with something that most people could relate to -the refrigerator light.
“Let’s say your refrigerator light is the intermittent problem. It’s working now, and should work every time you open the door, but at some point it’s not. The bulb could burn out, or it may get jarred loose and intermittently come on. But, the very next time you open the door the light may come back on, even though it didn’t come on the last time. So, if you stand in front of the refrigerator and can tell me when it’s going to fail, or know precisely when the next swing of the door in which the light isn’t going to work, then it’s no longer intermittent, but predictable,” I told him, “So, before you swing that door open for that midnight snack, ask yourself this, “Is the light going to be on, or is this the day it burns out?”
Keep in mind those light bulbs last a long time, and even if you are the type of person who calculates the exact hours of use that the bulb is predicted to last, I doubt you could ascertain the appropriate day and time it will actually occur. Without a pattern, or being able to duplicate the problem, a lot of intermittent problems are just plain impossible to solve. You need facts, figures, and a good diagnostic background to tackle them. And yes, with the right information they can be solved.
Everything has a fail point; everything has a lifespan. The problem is I can’t predict a failure any more than the man on the moon can. Oh sure, I can take a few “SWAG’s” at it, and I might even have some insight on which parts will fail more often than the next, but that doesn’t mean I can find the reason your car failed to start nearly a year ago.
This guy seemed to understand and was happy to keep track of his car under the conditions it failed to start. In the meantime, we did an overall checkup of his car just to be on the safe side. But, I did warn him even with the best checkup out there, it doesn’t mean you’re free from a failure. It could be something that was totally unexpected and wasn’t seen during the checkup, or it could be something that is internal in a computer that you can’t see at all.
A few days later he was back. He had this grin on his face a mile wide. There was something he was dying to tell me. “Did it finally not start for ya?” I asked. “Nope, car is fine,” he said.
“So what brings you here today?” I asked.
He jokingly told me, “My refrigerator light burnt out last night. I thought of you when it happened. I was standing in front of the refrigerator, and before I opened the door I would make a bet with myself whether or not the light was going to be on or off.”
Peculiar to say the least, someone actually drove across town to tell me about their refrigerator light, but now I was curious. I wanted to know the outcome. “So, did ya win your bet or not?”
“I lost,” he said, “but the car has been running fine since you did the check out. In fact, I’ve got the wife and kids playing the “Guess if the refrigerator light is going to be on game” too!”
Apparently, I’m a big hit around his house. Who would of thought explaining intermittent diagnostics would be fun for the whole family. This just proves that it really does take all kinds to make the world go around. I’m just glad I chose the refrigerator light as the example and not some other common household fixture or appliance.
Now, I’m wondering, has this ever happened before, and how often? Maybe it happens more in the morning or late in the afternoon? My best diagnostic answer, “I don’t know.”
gonzo: I wish intermittent problems would be as simple as diagnosing a refrigerator light that does not come on all the time!
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
      n this episode of "The Weekly Blitz," Coach Chris Cotton delivers insightful guidance tailored specifically for auto repair shop owners. He delves into the effects of spring break on sales, underscoring the significance of having a well-planned marketing calendar to effectively navigate and prepare for seasonal slowdowns that can impact business. Chris enriches the discussion by sharing a personal anecdote about dealing with an aftermarket warranty issue, illustrating the critical importance of maintaining customer trust and satisfaction, even when it presents financial challenges for the business. This story serves as a reminder of the long-term value of prioritizing customer relationships and integrity.
      Additionally, Chris provides an exciting update on Project Alpha, a shop he acquired, showcasing its remarkable turnaround in financial performance. He details the innovative staffing strategies implemented, which have contributed to the shop's success and growth. These strategies not only improved efficiency but also fostered a positive work environment, setting a benchmark for other shop owners to follow.
      The episode is proudly sponsored by Shop Marketing Pros, a company that specializes in providing marketing solutions tailored for auto repair shops. Their expertise helps shop owners enhance their visibility and reach, ensuring they stay competitive in the ever-evolving market.
      **Spring Break Challenges (00:01:05)**
      In this segment, Chris delves into the seasonal challenges faced by repair shops during the spring break period. He explains how the influx of vacations and travel plans leads to a noticeable dip in sales, as fewer customers seek repairs during this time. To counteract this trend, Chris emphasizes the importance of having a well-structured marketing calendar. By planning promotions and outreach efforts in advance, repair shops can better navigate the slow season and maintain a steady flow of business.
      **Doing What's Right for Customers (00:06:31)**
      Chris shares a compelling personal experience that underscores the significance of exceptional customer service. He recounts a situation where he had to make a tough decision to prioritize the needs of a customer over immediate profit. This story highlights the long-term benefits of building trust and loyalty by consistently doing what's right for customers. Chris argues that by putting customers first, businesses can foster stronger relationships and ultimately achieve greater success.
      **Project Alpha Update (00:10:26)**
      In this update, Chris provides an in-depth look at the progress of Project Alpha, the shop he recently acquired. He discusses the financial performance of the shop, noting significant improvements in revenue and profitability since the acquisition. Chris also outlines the operational changes implemented to enhance efficiency and customer satisfaction. From streamlining processes to upgrading equipment, these improvements have positioned the shop for continued growth and success in the competitive market.
