For all the shop owners that perform a considerable amount of oil changes, where do you look to find the correct oil filter? We use All Data Repair and All Data Manage as our repair information/shop management software and it is not currently located anywhere in the system. The OEM oil filter part number is available but we do not use OEM oil filters and it requires an additional step to cross reference to an aftermarket filter, like Purolator. Is there an easy way to find this information in Mitchell or any other auto repair program other than cross referencing this information in another online webpage?
It would be nice to have all of the relevant information (oil filter, oil weight, oil capacity, tire pressure, tire torque) all in one area in the same system so there would not need to be any additional work (having to look it up on a supplier's website or book). I was hoping that some of the Mitchel users would respond and tell me that the oil filter number is available in Mitchell? We do a large amount of oil changes here at our shop and any place that you can shave off time/additional work helps......
We use Champ brand filters. They have a free "lookup" on their website that lists the part numbers for the oil filter, air filter, cabin air filter, fuel filter, and transmission filter (all, if equipped). Since we use this brand, and know that one of our broadline suppliers stocks it, a simpke lookup and use of the Copy/Paste command, and we can easily "dump" all the filter information into the Memo field for the customer's vehicle.
You're correct, I think - Mitchell only references the OE numbers. If you can't find a similar lookup tool for the manufacturer of the line of filters you use, the OE numbers can at least be used in the interchange field in any Nexpart electronic catalog. If you have the catalog installed in Mitchell...it's just a few extra clicks before you're looking at the filter numbers associated with the OE number....and all the ones that your supplier stocks for you.
Happy hunting!
Agreed on Champ filters. Their website lookup is great.
With that said, any POS software system worth its salt will be able to build an oil change with the filter, oil type, and capacity.
Two off hand that I know about are Vast and RO Writer.
I was thinking the same thing ATLAuto. I would have ASSUMED that All Data and Mitchel being the largest shop management / repair software that is geared towards the aftermarket repair shops would have a cross reference functionality built into the program as most independent repair shops do not use OEM oil filters for oil changes. I know that there are numerous websites available that my techs can access to do the cross referencing but its one more step in the process I was hoping to eliminate.
ATLAuto, do you know if Vast and RO Writer only include the OEM filter number or is the cross reference after market filter (Purolator, Champ, etc) built into the software?
Stowintegrity, the Nexpart catalog that you are referring to, once it is installed will it cross reference Purolator oil filters? We are using All Data and I do not believe there is any catalog that we can install in All Data to do the cross referencing. Once installed in Mitchel, do you access the the interchange field in the Mitchel software itself?
Edited by 5 Star Auto Spa
The answer is yes, but I don't want to mislead you...
Nexpart is the electronic catalog "platform" used by several of my aftermarket suppliers. Essentially, it connects my POS software (Mitchell1) with their electronic inventory on their end, so I can pick & choose what parts to drop to my estimate. Knowing that they sell me Champ filters, for instance, I used the Mfr. lookup to get ALL the filter numbers in a single lookup, then once it's added to the vehicle's info, we always now what parts that car uses.
The Nexpart catalog interface will, in fact, interchange Purolator numbers...absolutely. There's a "tool" built into the catalog that let's me enter the number I already have (OE, Champ, whatever), and even if my supplier doesn't normally carry the other brands (Fram, Purolator, Napa, Carquest, etc.) it will give me a list of all the filters matching the number I entered. I didn't want you to think that I've found a way to automate the filter selection completely...I just know what numbers I need after our first contact with a customer.
I know there's a piece of software (It doesn't link to Mitchell1 that I'm aware of...) That you purchase one time called Chek-Lube. It's target market is the quick-lube industry, and when you enter a year/make/model car, it will return the following: ALL filter numbers (Oil, fuel, air, cabin air, transmission), ALL belt numbers (serpentine, accessory), ALL automotive fluid capacities (in quarts or liters), Wiper blade sizes (front, rear)...and more. The parts numbers returned from the lookup are chosen from a pretty good list of aftermarket manufacturer's brands that you select in the software setup. The page can be printed, if you want, or the information copied/pasted into your POS. The data is based on the Motors database, and furthermore, includes limited labor time information and chassis lube points. I think it was a couple hundred dollars.
Happy hunting!
We use Napa filters, we have a Napa filter book. While using a book may be old school it really is the fastest and easiest way to put the right filter on the car. That being said 99% of oil change customers are repeats, so we just look at the number of the filter coming off the car. The frustrating part is stocking 50+ oil filter numbers.
Wow, 50 filters? I can never get a bearing on the scope of my business as it stacks up against other successful shops. We only stock 20 oil filters, and have a car count of about 55-60 weekly. We'll probably do an oil change on 50-75% of those (in addition to whatever other service/repair they need), and we probably only run into 1-2 filters a week that don't happen to be one's we stock.
Am I likely missing a large part of the market's potential?
I'm doing the same. We average 250 cars per month and I stock about 25 filter and this includes euro # s as well. It is rare that I have to order anything. I'd be happy to post what I stock if it would help anyone.
I'm in a college town, you name it from 1990-2016 we get them. I have 15 #'s that I stock 6 of, the rest I keep 1. I don't anticipate getting 2 diesel Benz's or BMW 540i's in one day, so one is enough. Subaru's or Caravans are a different story. We might do 5 a day. I'm also in a rural area where the parts stores don't stock European or even some Japanese filters. If I don't have a filter in stock when the college kid is heading out of town I miss the opportunity to get them as a customer.
Now, if I had more time or more employees, or if the store had more delivery drivers, I would stock just one of each number and just reorder throughout the day. But with parts deliveries taking an hour on average I like to avoid waiting for an oil filter.
VAST will cross over to whatever filter you are using. When we build a work order, we click package, and it spits out filter number, oil viscosity, and capacity:
PH500 filter
5W30 Syn - 4.5qts
We use Champ, but it will cross to anything that VAST loads in. We debated Mighty for awhile, which would also work.
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
      Introduction to the Podcast (00:00:01)  The podcast begins with a welcome message from the host, Brian Walker. Guest Introduction (00:00:10)  Brian introduces co-host Kim and guest Doug DeLuca, owner of Boca Auto Fix. Overview of Boca Auto Fix (00:00:51)  Doug shares details about his auto repair shop, including its location and age. Hiring an Apprentice (00:01:09)  Doug discusses the recent hiring of an apprentice and the journey leading to this decision. Challenges in Hiring (00:02:13)  The speakers reflect on the difficulties shop owners face in finding and hiring young talent. Marketing Journey Begins (00:03:02)  Discussion shifts to Doug's initial marketing efforts and his involvement in content creation. Background in Technology (00:04:07)  Doug explains his previous technology background and how it influenced his approach to marketing. Learning SEO and Marketing (00:04:45)  Doug describes his self-taught journey in SEO and digital marketing after opening his shop. Realizing Marketing Needs (00:06:14)  Doug reflects on his initial assumptions about marketing and the reality of attracting customers. Understanding SEO Basics (00:08:09)  Doug shares his insights on SEO and the learning process involved in mastering it. Frameworks in Marketing (00:10:25)  The conversation explores the use of frameworks in both auto repair and marketing strategies. Adopting "They Ask, You Answer" (00:11:23)  Doug discusses his experience with the "They Ask, You Answer" philosophy in content creation. Writing Blogs for Customer Engagement (00:12:21)  Doug explains how he uses customer inquiries to create relevant blog content for his shop. Experience at a Quick Lube (00:13:29)  Doug shares his firsthand experience at a quick lube to highlight differences in service quality. Experience Comparison (00:14:06) Doug shares his experience of visiting a competitor's shop to understand customer perception and service quality. Proactive Client Advocacy (00:14:57) The team discusses the importance of guiding potential clients to the right service provider based on their needs. Sponsorship and Marketing Tools (00:16:13) Brian introduces RepairPal, highlighting its benefits for attracting new customers and building trust. Customer Loyalty Apps (00:17:51) Brian discusses the advantages of using App Fueled to create customer loyalty programs for auto repair shops. Incognito Visits (00:18:20) Doug talks about visiting a competitor's shop incognito to gain insights without revealing their identity. Collaboration Over Competition (00:19:09) The speakers explore the idea of referring customers to other shops and building relationships in the industry. Challenging Competition Norms (00:20:20) Brian reflects on inviting competitors to the podcast, emphasizing collaboration over traditional competition. Marketing Involvement (00:22:42) Doug explains the ad hoc nature of their marketing efforts and the role of social media in their strategy. Community Involvement (00:27:41) Doug shares their family's volunteer work and how it integrates with their business's social media presence. Engaging the College Market (00:28:51) Doug discusses how 30% of his clients are college students and their marketing strategies. Collaborating with Local Professors (00:31:18) Doug shares his experience working with a marketing professor for student analysis of his business. Challenges of Seasonal Demand (00:32:24) Discussion on the impact of seasonal changes on business demand and local marketing efforts. Starting with Marketing (00:34:02) Doug advises new shop owners to listen to podcasts and conduct online research for marketing. SEO as a Long-Term Strategy (00:35:08) Doug explains the importance of SEO and its long-term benefits for business growth. Understanding Competition (00:36:44) Doug emphasizes the need to analyze competition and not assume marketing strategies will work universally. The Importance of Data (00:39:08) Doug highlights the role of data in assessing marketing effectiveness and making informed decisions. Nuances of Market Dynamics (00:41:14) Discussion on how geographical and seasonal factors affect marketing strategies in auto repair. Client Avatar and Marketing Alignment (00:42:13) Doug explains the significance of understanding the ideal customer for effective marketing strategies.  Overcoming Diagnostic Fee Challenges (00:43:09) Discussion on how Doug has adjusted his approach to diagnostic fees to improve customer conversion. The Importance of Evaluation Fees (00:43:40) Discussion on the role of evaluation fees and their impact on shop maturity. Improving Customer Communication (00:44:09)  Insights on enhancing customer explanations regarding services and processes. Coaching and Competitive Analysis (00:45:03)  How coaching helped refine service policies and improve customer relations. Content Creation and Marketing Strategy (00:46:32)  The significance of creating content for customer engagement and marketing. Duck Duck Jeep Initiative (00:47:05)  Fun marketing strategy involving ducks to engage with the local Jeep community. Value of Customer Feedback (00:48:46)  Importance of understanding customer inquiries and improving service based on feedback. Contact Information for Doug DeLuca (00:49:29)   Doug shares how listeners can reach him for further inquiries.
      Episode 208 - Training Hurdles & Reputation Challenges in Auto Repair With Tim Iezzi & Ira Waldman
