My All-time Worst Spark Plug R&Rs
I’ve been changing spark plugs almost as long as I’ve been able to hold a socket wrench. I’ve changed plugs on everything from the family lawn mower to huge engines, and over the years there have been a few of them that are memorable only because they were such a pain in the toolbox to get out. A few were rusted into place, or the threads were stripped, and a few that broke off in the head, but the ones I remember the most are the ones that had you muttering to yourself that you’d never do another one again.
Now, I could mention the trouble with getting the spark plugs out of the Ford Triton 3 valve engines and how difficult those can be, but they are only tough because of the design aspects of the engine. Not that they are that difficult to get too. I’ve tried taking them out with the engine cold and with the engine hot. I prefer the hot method. Once I started taking them out that way I haven’t had near the hassle as taken them out cold (as per the procedure from Ford). Although, they are tough enough to extract, and a few choice words for the engineers may be in order, they don’t require the dexterity of a gymnast to get them out.
The transverse engines, any thoughts? Yea, I’ve got a few, especially the ones that half the intake has to be removed to get to the back plugs. What a genius design from a maintenance stand point. Yea, it sure does make for a compact engine bay, and yes, they don’t need changed as often as the older models do, but still.... what a hassle. Some of the transverse engines required you to remove the upper engine mount (the dog bone) and rock the engine in one direction to gain access the back plugs. A lot of guys would rock the engine back and forth, and when the engine was in the right spot they would jam on the emergency brake. It worked, but holy cow... dangerous! If the E-brake didn’t hold in the middle of your changing them, it could be even more difficult to extract the mechanic than just the spark plugs! The best method was to get the proper tool (Oh, gee another tool to buy) and use it to crank the engine to the right spot.
All those weird spark plug designs and sideways motor layouts had their issues, but nothing compared to the contortionist you had to be on other vehicles, or even worse how a job that looks to be only an hour or two turns into an all-day affair. One in particular that I remember so well is the mid 70‘s Chevy Vega. You know, the little car with the aluminum engine and the notorious oil consumption, yea that one. Well, there is another Vega that was available that didn’t have the little 4 cylinder engine in it. It came from the factory with a V8 squeezed under the hood.
Why do I remember this so well? I had a customer with one who wanted the spark plugs replaced. Back in the day, there was a national chain of tune up shops that was offering a 29.95 tune up for any factory original car. My customer had already asked me what I would charge and he didn’t like my price at all. The 29.95 looked like a bargain so he headed right over there.
A day or so later I got a call from the tune up place. They were questioning whether or not it was a factory set up, because they couldn’t even see the plugs. In fact, they couldn’t find it in their labor guides, either. The customer told them I did all his work, so they assumed I must have been the guy who “shoe-horned” this V8 in there. I laughed, and told them it was definitely factory assembly. The problem was the only way to remove all the plugs was to first remove the entire motor. Hey, they advertised it; they said they would do any factory car for that price, so do it!
They ended up pulling the motor and changing the plugs for the advertised price, but with one stipulation. Never to bring it back.
Another fabulous design that needs to be put on the list of all time dumb designs is the mid 80‘s GM 4WD van with a V8 engine. Now here’s one that you’ll get a work out trying to get to all the plugs. One from the deck lid, one from inside the wheel well, one with the dog house removed. Oh, and the last one... good luck. It’s buried in there to the point that you have to put your socket, swivel, and extension onto the spark plug in sections and then you might manage an eighth of a turn with the ratchet. You’ll need a change of clothes before going home on this one, because you’ll be covered in grease from head to toe as you bear hug the cross member, steering linkage, and countless other components just to get to the plugs.
It’s one of those jobs when the customer tells you they need a tune up the mechanic starts questioning their career choice. The customer says, “How come every time I ask a mechanic about tuning up my van they don’t want to do it?” Try it sometime… you’ll find out why.
What can be even more frustrating is when a car comes in with a misfire and it’s diagnosed as a faulty spark plug. The dead hole is the one that is just a fraction of an inch from the evaporator case. You can’t even see the plug, but you gotta get to it somehow. After what seems to be hours you manage to find the right combination of sockets and swivels to get that sucker out only to find the plug is completely shot. You suggest to the customer that it’s time for a tune up, and they tell you that it was just done a week ago. A little more investigating and you find that all the other plugs are brand new...except for the one you just wrestled out. Now, I have two people I want to have a little wall to wall conversation with. The engineer who designed this fiasco and the *#@^! mechanic who only changed 7 plugs.
I know I haven’t seen the worst of the worst, but I’ll bet there are mechanics out there who have run across worse ones than me. How about you guys telling me your worst of the worst? Send an email or text, and I’ll compile a list and put it into story form for later publication. If anybody knows which spark plug changes are the worst, it’s you guys and gals out in the service bays. Misery loves company, so think about your worst spark plug changes and let me know.
gonzo: Over the years one of my considerations in owning a vehicle was how easy it is to change spark plugs. One thing they have improved on that you did not mention is on newer vehicles you see "Iridium" type plugs being used, good for over 100,000 miles, at least that's the claim! So you don't have to do it as much. If your in the business of reparing cars, I don't know if that's a good thing, but for the automobile owner I guess it is.
Also, what about the vehicles that used "wasted spark" This meant you had to change two spark plugs per cylinder. Gonzo, I bet you could come up with stories just on this one , trying to explain this to customers why a 4 cylinder needs 8 spark plugs replaced!
Edited by kenk
Most Mercedes Benz cars use 2 plugs per cylinder. That translates into 16 spark plugs on a v8. At least they're not hard to change but 16 plugs take a minute to swap out.
The biggest problems we find are when compound issues hinder the spark plug access. Get a s10 with a bad motor mount and you can't get a socket onto the middle plug, the steering shaft blocks your path. Camaro's are the absolute worst in my book, I mentally blocked out the last one I did. GM must have learned from the Vega. Anything with van in the model name means covered in grease and cuts. Now you know why I specialize in tires and not tune ups.
Ah, those camaro's and dual plug engines. A lot of people don't look at the needed repairs before they buy something, and then... they wonder why it costs so much. And, yes... the new plugs last longer Ken, I think that's why they feel it's OK to bury them below all the piping and electric stuff. So much for things being easier because their a newer design. ROFL........ :)
How about the cheapo that doesn't want to buy new wires and then the plug wire boot breaks on spark plug and the customer gives you that look like it's your fault. I forgot we let engines go 130k without removing plugs and no dielectric grease on plug to stop them from getting stuck.
I usually require plug wires with spark plug change or at least give customer the heads up that they mayfall apart. So if customer isn't prepared to handle worse ccase scenerio then I. Decline the job. Not worth the dumbfounded look n "what do we do now" moment.
What we do in our shop to remove the spark plugs from a 3 valve ford triton engine is we do a fuel / air induction service. Leave it sit overnight. Then the following day, remove the ignition coils, and using a 1/2 drive impact gun, remove the spark plugs. When they start turning, don't leave up on the gun until they are out. This has work every time for us.
How about the great design of the Chevrolet Chevette. Removing the a/c compressor to change the distributor cap, rotor , and wires. Brilliance at its best.
Dave, are y'all running them out with the engine hot or cold? We started doing it engine hot with an impact and have not broken a plug since.
I like the induction service idea. May give it a try to loosen stuff up.
We have done it both cold and hot. But mostly cold.
http://www.gonzostoolbox.com/KnowledgeFolder/3valvesparkplugremoval.html
This is an article I wrote years ago about taking out those 3 valve spark plugs. The magazine editors said they didn't want to upset Ford by telling them their method wasn't working well out in the field. But.... it may still go out later ... IF I keep bugging them to print it.
Nice one. Agreed, the Ford method is garbage in practice. Once our master tech mentioned doing it hot and seeing it work in practice, we never looked back.
My mother in law had one of those. Every time the car came back from the dealer "tune up"-The A/C was not working!
      In our episode today:
      Craig is talking about family business dynamics with Maryann Croce - Fellow Toastmaster at Remarkable Results Toastmasters, fellow Transmission Repair professional, and industry friend who knows the good - but understands the struggle so often described when you combine business and family.
      Fittingly…
      Today’s Word of the Day is:
      Neoptism
      nep·o·tism
      noun
      the practice among those with power or influence of favoring relatives, friends, or associates, especially by giving them jobs.
      Maryann brings a well earned perspective to this topic and presents many practical tips for families to work better together.
      Listeners will particularly benefit from hearing Maryann’s three questions for business owners to ask before bringing in family members.  By the conclusion you’ll be ready to better support, value, and listen to our family colleagues - making for a stronger communication and culture.
      While this topic emphasises family dynamics, all listeners will benefit with some of the topics benign applicable to any business.  Maryann also introduces the term ‘context switching’ while describing the difficulty of wearing too many hats - and explains why families tend to do this even more than other businesses.
      Listeners can reach out to Maryann through her website.
      https://www.smallbizvantage.com/
      You can hear more from Maryann at Autoleap's Amplify
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Recorded at the 45th annual Mobile Air Climate Systems Conference (MACS 2025) in Orlando, Florida, Rob Bollinger shares the unique story of his third-generation family business, emphasizing their commitment to personal service and the legacy of his grandfather, who invented the overflow bottle system. The discussion also touches upon industry trends, the challenges of price competition, the evolution of AC systems with electric vehicles, and Bollinger's future plans for the business. Rob Bollinger, ABC Radiator, Baltimore, MD. https://www.facebook.com/abcradiator401 Show Notes Watch Full Video Episode MACS Training Event & Trade Show: https://macsmobileairclimate.org/ National Automotive Service Task Force (NASTF): https://wp.nastf.org/ Koura: https://www.kouraglobal.com/ Honeywell: https://www.honeywell.com/us/en Introduction to MAC Conference (00:00:00) Guest Introduction: Rob Bollinger (00:02:17) Rob's Family Business Legacy (00:02:52) Personal Touch in Deliveries (00:03:52) Customer Engagement During Deliveries (00:04:30) Rob's Background in the Business (00:06:08) Regrets About Family Business (00:06:22) Coolant Reservoir Bottle Invention (00:07:40) Patenting the Invention (00:08:25) Legacy of the Invention (00:09:48) Cash vs. Cashless Transactions (00:10:05) Honesty in Business (00:15:46) Future of Specialty Shops (00:16:20) Customer Outreach (00:16:30) Changes in Radiator Industry (00:16:54) Hiring Challenges (00:18:11) Golfing and Business Balance (00:18:39) AC Industry Challenges (00:20:10) Leak Detection Methods (00:20:57) Future Plans (00:21:50) Real Estate and Business Stability (00:22:28) Family Support (00:23:33) Training and Industry Updates (00:24:26) Vendor Interaction at Conferences (00:25:08) AI Repair Discussion (00:25:55) Reflection on the Conversation (00:26:09)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
      Episode 205 - Preserving Lost Arts in a Changing Industry With Jeff Eddy
      Thanks to our Partners, NAPA TRACS, and Today's Class Explore the complexities of family succession in automotive businesses, featuring insights from a psychologist, a shop owner, and her father, who transitioned the business to her. The discussion covers topics such as defining roles, seeking professional guidance, addressing financial considerations, establishing boundaries, and the importance of a trusted, non-family advisor during the succession process. The conversation highlights the need for business owners to relinquish control, embrace change, and recognize the value of diverse perspectives in leadership. Jessica Carrino, Sparks Tire & Auto, St. Charles, MO. Jessica’s previous episodes HERE Ron Tinner, COO, Repair Shop of Tomorrow Dr. David Weiman is the president of Weiman Consulting, a leadership consulting firm in Philadelphia PA. Listen to David’s previous episodes HERE Show Notes Watch Full Video Episode Introduction to Family Succession (00:00:00) Importance of Defined Roles (00:02:22) Dr. Weiman's Insights on Family Businesses (00:03:15) Clarity in Decision-Making (00:06:02) Ron Tinner's Transition Story (00:07:29) Jessica's Initial Involvement (00:09:00) Coaching Dynamics (00:10:21) Jessica's Greatest Challenge (00:11:07) Motivating Gen Z Technicians (00:12:38) Finding Young Technicians (00:15:59) Challenges of Inheriting Staff (00:16:56) Boundaries in Family Business (00:17:53) Succession Planning Insights (00:20:01) Role of Non-Family Advisors (00:21:08) Identifying Successors (00:22:06) Family Dynamics and Relief (00:24:06) Financial Considerations in Succession (00:25:11) Understanding Roles in Succession (00:25:26) The Challenge of Letting Go (00:28:49) Work-Life Balance for Owners (00:29:09) Support and Learning from Failure (00:30:23) Alignment of Values (00:31:24) Understanding Communication Styles (00:33:14) Transitioning Authority (00:35:30) Succession Planning Insights (00:35:58) Future Considerations (00:36:59) Annual Succession Review (00:37:38)
      Thanks to our Partner, NAPA TRACS NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Thanks to our Partner, Today's Class Optimize training with Today's Class: In just 5 minutes daily, boost knowledge retention and improve team performance. Find Today's Class on the web at https://www.todaysclass.com/ Connect with the Podcast: -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on X: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/
