Mechanics Need Not Apply
It shouldn’t be that hard to find a mechanic, why everybody is a mechanic, don’t ya know. So, if there are so many mechanics out there how come finding a good one is such a challenge? Could it be that these so called mechanics have been lying to us all this time? I find it very disconcerting that after 3 decades in the repair business I haven’t ran into as many mechanics as they say are out there. There are shops and various companies out there that hire people in to fill these positions who they believe they are mechanics. But, turn out to be your typical person with a mechanical aptitude but very little in the way of training in the field. However, they can bluff their way through most common problems.
Sometime ago, a guy came in with a car that was extremely hard to start, especially after the engine was warmed up. He took it to one shop who changed a part or two, but that didn’t fix his problem. Then, he took it to another shop that stumbled around with it for a month. A month mind you! There answer to the problem was that it must be a fuel pump. And, how did they determine that? Well, like any typical backyard mechanic would diagnose it. They sprayed some fuel into the intake. So, naturally, it must be a fuel pump that’s gone bad. No, they didn’t check to see if it had any fuel pressure, no, they didn’t bother to scan it, no, they didn’t check to see if it had any injector pulse or not… no, they didn’t do anything that would resemble a reasonable attempt at diagnosing it.
Needless to say, it was still extremely hard to start. After a month of guesses the car owner’s patience’s was wearing thin. Now the car was at my door. A faulty cam sensor and an overheated crank sensor was all it was. All it took was a look on a scanner to see the various input and output controls that the computer was monitoring. From there, check the leads for any damage, and scope the sensors (under the conditions of the failure). Easy enough…didn’t take me a month though. With a little background in how each of these sensors played a part in the engines operation you could have deduced what the problem was in less than a month… seriously people. And, to this day, that shop is still in business, and has the gall to call themselves a mechanic shop.
There are a lot of parts chasers out there that shouldn’t even own a tool box as far as I’m concerned. Am I ticked off? You bet! Granted, these Neanderthals with wrenches keep my shop full, but at what cost to the consumer? This is my point. If you’re going to be in the business of repairing today’s cars, then by all means… fix them, or pass on the job (at a reasonable time level) and suggest to the customer the appropriate shop that can perform the work.
It’s not just the mechanics either; it’s the shops and companies that allow such things. Oh sure, if you talked to the higher ups in some of these large national franchised corporations they’ll tell you they have the best mechanics in the business. Honestly, I doubt any one of those executives have a clue as to what’s really going on. And, I seriously doubt any of those execs. are driving around a late model car that has seen way too many miles and is barely keeping all four tires on the ground. I wonder if they’ve ever spent any time in the service bays to actually see what’s going on or not.
Even though, most general repairs can be accomplished by anyone who calls themselves a mechanic, it’s the evaluation and diagnostic work that seems to be lacking. But, people who are looking for bargains will still cater to the shops that don’t charge a diagnostic fee or has the cheapest rates in town. Not to get a second rate repair on their car mind you, oh no, they are looking for the same kind of results that they would expect at a much more qualified (expensive) shop. They are strictly after the cost savings and not poor workmanship. They usually won’t see the difference in their decision until after they’ve picked their car up.
Today’s cars are not the kind of thing to be left to some guy who has nothing more than a hammer and a screwdriver to test the car. But, for some reason, people will still go to that type of shop thinking they are going to get top notch service. I see this every day, and every day I’m still shocked that these shops are still in business.
So where are all these mechanics at? I still haven’t found them. Most good mechanics know who the good mechanics are in their area. Good shops and good mechanics don’t need to look for work. Those cars that need their expertise will find them eventually. Usually after the owner has ran the circuit of poor diagnostic results at those other shops. The problem is by the time some of these cars finally make it to the right mechanic their bank account is tapped out, and this usually ends with the same old scenario at the service counter.
You might say, “Well, I go to the dealership because those guys are the best trained guys out there.” Not necessarily, most of your top notch independent shops have as much time in a class room or in a book as most dealer mechanics do, if not more. In fact, most independent shops have an exceptionally wider array of knowledge. Different types of tools such as scopes, various scanners, and independent training companies that aren’t offered through the dealerships.
This whole thing just irks me to no end. If there are so many people out there that call themselves mechanics then why is it so hard to find a good one? I guess, the next time I decide to hire some help I’m going to hang a sign out front that says, “Help Wanted - Mechanics need not apply – Unless you really are one.”
Reminds me of those signs you see in small towns "Mechanic on duty" Oh is that so and how good are you!anyone can put up a sign like that!
You know, we all have our limitations as far as what type of work/repairs we are capable of and or qualified to do. I don't pull motors, change transmissions and stuff like that, but I know the right people to send that kind of work to. It's these shops that try to handle everything and fail that tick me off. They'll keep a customers car forever and charge them outrageous amountd of cash. All it does it leave a bad feeling about the automotive repair industry as a whole.
Now I'm hearing ads where a franchise transmission shop will check your "check engine" light for free, and will set up payment installments if it's a major repair. Come on now... stick to what you say you do... that is fixing transmissions. You can't convince me that their tranny guy knows enough about power window data circuits to properly diagnose them. Maybe I'm wrong, but it just doens't seem right to me.
change an electrical outlet, but i'm no electrician. I can cook a steak, but i'm not a chef. I can nail wood together but I'm not a carpenter. But let someone change their brakes and do 1 tune up on their car and suddenly they are a "mechanic".
I agree with you Gonzo, I had a customer want us to rewire his burned wiring harness. I told him we didn't do that kind of work and referred him to the electrical shop across town. When he kept insisting, I explained it to him this way. You don't go to your heart surgeon to have brain surgery done. Sure he could probably wing his way through it, but do you really want to take that chance?
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
      n this episode of "The Weekly Blitz," Coach Chris Cotton delivers insightful guidance tailored specifically for auto repair shop owners. He delves into the effects of spring break on sales, underscoring the significance of having a well-planned marketing calendar to effectively navigate and prepare for seasonal slowdowns that can impact business. Chris enriches the discussion by sharing a personal anecdote about dealing with an aftermarket warranty issue, illustrating the critical importance of maintaining customer trust and satisfaction, even when it presents financial challenges for the business. This story serves as a reminder of the long-term value of prioritizing customer relationships and integrity.
      Additionally, Chris provides an exciting update on Project Alpha, a shop he acquired, showcasing its remarkable turnaround in financial performance. He details the innovative staffing strategies implemented, which have contributed to the shop's success and growth. These strategies not only improved efficiency but also fostered a positive work environment, setting a benchmark for other shop owners to follow.
      The episode is proudly sponsored by Shop Marketing Pros, a company that specializes in providing marketing solutions tailored for auto repair shops. Their expertise helps shop owners enhance their visibility and reach, ensuring they stay competitive in the ever-evolving market.
      **Spring Break Challenges (00:01:05)**
      In this segment, Chris delves into the seasonal challenges faced by repair shops during the spring break period. He explains how the influx of vacations and travel plans leads to a noticeable dip in sales, as fewer customers seek repairs during this time. To counteract this trend, Chris emphasizes the importance of having a well-structured marketing calendar. By planning promotions and outreach efforts in advance, repair shops can better navigate the slow season and maintain a steady flow of business.
      **Doing What's Right for Customers (00:06:31)**
      Chris shares a compelling personal experience that underscores the significance of exceptional customer service. He recounts a situation where he had to make a tough decision to prioritize the needs of a customer over immediate profit. This story highlights the long-term benefits of building trust and loyalty by consistently doing what's right for customers. Chris argues that by putting customers first, businesses can foster stronger relationships and ultimately achieve greater success.
      **Project Alpha Update (00:10:26)**
      In this update, Chris provides an in-depth look at the progress of Project Alpha, the shop he recently acquired. He discusses the financial performance of the shop, noting significant improvements in revenue and profitability since the acquisition. Chris also outlines the operational changes implemented to enhance efficiency and customer satisfaction. From streamlining processes to upgrading equipment, these improvements have positioned the shop for continued growth and success in the competitive market.
      The TRUTH About Business Coaching That Companies Don't Wants You to Know!
      Why Auto Shops Are DITCHING Aftermarket Parts in 2025?
